大哥,咱们能说家乡话吧?
jjchan48(jjchan48) 发表:As mentioned by fengyonhe, it can be verified to be pearlite with higher magnitude.
I think it is different etching rate/pearlite spacing resulted from different orientation. Therefore, the investigation of pearlite shows different gray scale.
