kylabs
第4楼2011/05/15
那来个LCMS的吧,没有衍生的,19种氨基酸
Method Run Conditions:
Column: 2.1 x 150 mm Cogent Diamond Hydride™
Solvent A: DI water + 0.1% formic (or acetic) acid
Solvent B: Acetonitrile + 0.1% formic (or acetic acid)
Flow rate: 0.4 mL/min
Gradient conditions:
0 min - 100 %B
0-5 min to 75% B
5 - 6 min to 60% B
6 - 7 min hold 60% B
7 - 9 min to 50%B
9 - 10 min hold 50%B
5 min post time at 100%B (for equlibration)
老多_小多
第5楼2011/05/16
有样品处理的经验分享下吗
