kylabs
第4楼2011/06/01
尿里胆酸的测定条件:
Bile Acids from Urine
Determination of Chenodeoxycholic acid (CDCA) (bile acid) in human urine using ANP (inverse gradient)
柱子 | Cogent Diamond Hydride™, 4µm, 100A | ||||||||||||||||||||
货号 | 70000-15P-2 | ||||||||||||||||||||
尺寸 | 2.1 x 150 mm | ||||||||||||||||||||
流动相 | A: DI water + 0.1% formic acid B: acetonitrile + 0.1% formic acid | ||||||||||||||||||||
Mobile Phase | Gradient t0 = 1.44 min
Flow Rate | 0.4 mL/min. | ||||||||||||||||||||
Sample | Human urine - after simple extraction | ||||||||||||||||||||
Analyte | Chenodeoxycholic acid 393.29994 m/z (M+H)+, RT = 6.26 min | ||||||||||||||||||||
Detection | ESI ?pos- Agilent 6210 MSD TOF mass spectrometer. Figure B: EIC ?extracted ion chromatogram of selected compound and corresponding spectrum |
