【求助】注射液用高效液相怎么检测??
  • liuqiasnqia
    2011/05/24
  • 土霉素注射液用高效液相怎么检测?谢谢!
  • kylabs
    第1楼2011/05/24
    注射用土霉素的稳定性分析方法:
    ColumnCogent Bidentate C18™, 4µm, 100A
    Catalog No.40018-75P
    Dimensions4.6 x 75 mm
    SolventsA: DI water + 0.1% formic acid
    B: acetonitrile + 0.1% formic acid
    Gradient
    time (min.)%B time (min.)%B
    010680
    430710
    Post time3 min.
    Flow rate1.0 mL/min.
    SampleUSP grade tetracycline HCl capsule extract (degraded).
    Stock Solution: 10.0 mg capsule contents were diluted with 10 mL 1.0 N HCl and sonicated for 10 min. 1 mL aliquot was diluted to 20 mL with DI water. Solution was heated at 80°C for 30 min. Solution was then diluted to 100 mL with DI water and filtered through a 0.45 µm nylon membrane HPLC filter (MicroSolv Technology Corp., Eatontown, NJ, USA).
    Working Solution: Stock solution was diluted 10x using 0.01 N HCl diluent.
    DetectionUV 360 nm (0? min) 430 nm (5? min)
  • 该帖子已被版主-boboenid007加2积分,加2经验;加分理由:很热心的版友!
  • kylabs
    第2楼2011/05/25
    楼主是做土霉素的杂质分析吗?
