生长调节剂-环虫酰肼
农残检测
  • 性质可以参考。
附件:
  • rzxjz
    第1楼2011/10/08
    共存物质对虫酰肼水解作用的影响
  • 雾非雾
    第2楼2011/10/27
    中国输日葱的虫酰肼由命令检查变更为30%频度抽检
    今般、下記の食品について、命令検査を解除したことから、輸入食品監視指導計画に基づき、モニタリング検査の頻度を30%として対応すると通知。(平成23年9月21日)
    対象国・品目:中国産ねぎ
    検査項目:テブフェノジド(TEBUFENOZIDE,用途:殺虫剤、基準値:0.01ppm(一律基準))
  • 雾非雾
    第3楼2011/10/27
    ACCESSION: WA000054
    RECORD_TITLE: Chromafenozide; LC-ESI-QQ; MS2; CE:30 V; [M+H]+
    DATE: 2011.05.06 (Created 2007.08.01)
    AUTHORS: Nihon Waters K.K.
    LICENSE: Copyright 2007-2011 Nihon Waters K.K.
    CH$NAME: Chromafenozide
    CH$COMPOUND_CLASS: N/A
    CH$FORMULA: C24H30N2O3
    CH$EXACT_MASS: 394.22564
    CH$SMILES: Cc(c3)cc(cc(C)3)C(=O)N(NC(=O)c(c1)c(C)c(C2)c(OCC2)c1)C(C)(C)C
    CH$IUPAC: InChI=1S/C24H30N2O3/c1-15-12-16(2)14-18(13-15)23(28)26(24(4,5)6)25-22(27)20-9-10-21-19(17(20)3)8-7-11-29-21/h9-10,12-14H,7-8,11H2,1-6H3,(H,25,27)
    CH$LINK: CAS 143807-66-3
    AC$INSTRUMENT: QuattroPremier XE, Waters
    AC$INSTRUMENT_TYPE: LC-ESI-QQ
    AC$MASS_SPECTROMETRY: MS_TYPE MS2
    AC$MASS_SPECTROMETRY: ION_MODE POSITIVE
    AC$MASS_SPECTROMETRY: COLLISION_ENERGY 30 V
    MS$FOCUSED_ION: PRECURSOR_TYPE [M+H]+
    MS$FOCUSED_ION: PRECURSOR_M/Z 395.36
    MS$DATA_PROCESSING: FIND_PEAK ignore rel.int. < 5
    PK$NUM_PEAK: 6
    PK$PEAK: m/z int. rel.int.
    104 16 16
    119 8 8
    133 118 118
    147 16 16
    175 999 999
    176 27 27
  • 雾非雾
    第4楼2011/10/27
    Determination of 44 Pesticides in Foodstuffs by LC/MS/MS
  • 雾非雾
    第5楼2011/10/28
    The new analytical method using Quick, Easy, Cheap, Effective, Rugged, and Safe (QuEChERS) procedure for simultaneous determination of diacylhydrazine insecticide residues in fruits and vegetables was developed using ultra-performance liquid chromatography coupled with tandem mass spectrometry (UPLC-MS/MS). The four insecticides (tebufenozide, methoxfenozide, chromafenozide, and halofenozide) were extracted from six fruit and vegetable matrices using acetonitrile and subsequently cleaned up using primary secondary amine (PSA) or octadecylsilane (C18) as sorbent prior to UPLC-MS/MS analysis. The determination of the target compounds was achieved in less than 3.0min using an electrospray ionization source in positive mode (ESI+) for tebufenozide, methoxfenozide, and halofenozide and in negative mode (ESI-) for chromafenozide. The limits of detection were below 0.6 gkg(-1), while the limit of quantification did not exceed 2 gkg(-1) in different matrices. The QuEChERS procedure by using two sorbents (PSA and C18) and the matrix-matched standards gave satisfactory recoveries and relative standard deviation (RSD) values in different matrices at four spiked levels (0.01, 0.05, 0.1, and 1mgkg(-1)). The overall average recoveries for this method in apple, grape, cucumber, tomato, cabbage, and spinach at four levels ranged from 74.2% to 112.5% with RSDs in the range of 1.4-13.8% (n=5) for all analytes. This study provides a theoretical basis for China to draw up maximum residue limits and analytical method for diacylhydrazine insecticide in vegetables and fruits.
    QuEChERS方法(C18、PSA)进行前处理。
  • 雾非雾
    第6楼2011/11/01
    Simultaneous separation of pesticides by LC/MS
