离子液体液液分散微萃取技术/高效液相色谱检测蜂蜜样品中的菊酯类农药残留
  • jiahengzhang
    2011/10/13
厂商论坛
  • 题目:Comparison of the performance of conventional, temperature-controlled, and ultrasound-assisted ionic-liquid-dispersive, liquid-liquid microextraction combined with high-performance liquid chromatography in analyzing pyrethroid pesticides in honey samples
    摘要:This research paper presents a comparative study of the performance of conventional, ultrasound-assisted (UA), and temperature-controlled (TC) ionic liquid (IL) dispersive liquid-phase microextraction (IL-DLLME). Various parameters that affect extraction efficiency, such as type and volume of extraction and disperser solvent, centrifugation time, salt addition, effect of temperature on TC-IL-DLLME, and effect of sonication time on UA-IL-DLLME, were evaluated. UA-IL-DLLME was found to provide the best extraction efficiency. Under optimized conditions, great enrichment factors (506−515) and good recoveries (101.2%−103.0%) were obtained by analyte extraction in real samples. The limit of detections (LODs) ranged from 0.21−0.38 μg/L. Good linearity was obtained in the range of 0.5−200 µg L-1 for ethofenprox and tetramethrin, and 1−200 µg L-1 for meperfluthrin and alpha-cypermethrin. Based on optimized conditions, the UA-IL-DLLME method was applied and combined with high-performance liquid chromatography with diode array detection (HPLC-DAD) to determine the presence of ethofenprox, tetramethrin, meperfluthrin, and alpha-cypermethrin in honey samples.
    概述:对比了传统离子液体液液分散微萃取、温控辅助液液分散微萃取和超声辅助液液分散微萃取的区别,通过优化几个影响萃取实验的参数,如:萃取剂和分散剂的种类和体积、离心时间、盐效应、控温温度和超声时间等确定萃取条件,实验结果表明超声辅助液液分散微萃取的萃取效率要高于另外两种,在优化条件下四种菊酯类农药的富集倍数达到了506-515倍,在1−200 μg/L范围内具有良好的线性关系,线性相关系数在0.9990~0.9999 之间;检出限为0.04~0.10 μg/L(S/N=3),回收率为101.2%−103.0%。本方法已应用实际蜂蜜样本的检验,具有操作简单、富集效率高、灵敏度高和绿色环保等特点,可满足液体样品中菊酯类农药残留的检测要求。
附件:
  • 天瑞俱乐部
    第1楼2011/11/25
    欢迎参赛~~~~~~~~~~~
