mingbright
第5楼2006/04/03
Do you have to grow your membrane on glass?
If you membrane doesn't dissolve in water, maybe you can try to grow your sample on a smooth surface of NaCl crystal and dissolve NaCl in water , only your membrane left. It is too tedious to prepare samples by dimple, ion-milling...
