[转贴]:读书笔记-Solvent Guidelines
  • Do not use any of the following solvents in the Waters Reagent Manager because they damage PEEK components.
    • Methylene chloride
    • Tetrahydrofuran (THF) at greater than 10% (v/v)
    • Freon
    • Concentrated sulfuric acid (H2SO4)
    • Concentrated nitric acid (HNO3)
    Also keep in mind the following solvent guidelines:
    • Use methanol to prime a new pump or a pump that has been stored for an extended period.
    • Use an intermediate solvent when you change between solvents that are not miscible.
    • Always keep the solvent level in the reservoir at least 4 inches ( 10cm) higher than the pump inlet. Do not place solvent reservoirs on top of the Reagent Manager.
    • Use only filtered, degassed solvents.
    • After using a buffer, purge the pump with HPLC-grade, distilled, or deionized water to prevent crystallization and damage to the piston or seal.
    • Know the properties of the solvents under different pressures.
    • Dedicate a solvent supply tube and filter assembly for each solvent. If this is not possible, purge the tube and filter of any remaining solvent before you use a new solvent.
    • To prevent cross-contamination of solvents, dedicate a set of glassware for preparing, storing, and supplying each solvent. Once a container has been used for a solvent, do not use it for any other solvent unless it has been thoroughly cleaned.
  • taomt05
    第3楼2006/03/31
    一定要好好拜读!
  • taomt05
    第5楼2006/03/31
    是你的笔记么?好象是随机的OP 吧
