求:水化铝酸钙(CAH )PDF卡片
X射线衍射仪(XRD)
  • 今天做了个XRD,想知道里面是否有水化铝酸钙(CAH )晶相,哪位有水化铝酸钙(CAH )的PDF卡片,或告诉我它对应的d和I/I0值
  • hecaijia
    第1楼2006/04/03
    好郁闷,没人回帖
  • wdy99
    第2楼2006/04/06
    分子式或英文名称总的告诉一样吧,否则怎么查?
    [请你将该物相的化学式告诉大家,以便帮你查找,你要知道人家不都是做水泥的,不懂你那个什么东西的缩写是什么意思。
    (估计是Ca Al O H )
    下面这些都是,你要哪种?]
    PDF Overlay List (drag to shuffle, click on its column header to edit a number)
    [111.txt] 20.000 4112
    Phase ID (15 Overlays)    Chemical Formula    File ID    I%    2T(0)    d/d(0)    RIR    Wt%    Tag    XS(A)    #d/I
    Calcium Aluminum Oxide Hydrate    Ca4Al2O7!xH2O    PDF#02-0077    100.0    0.000    1.0000    ?    0.0    Major    >1000    30
    Calcium Aluminum Oxide Hydrate    Ca3Al2O6!xH2O    PDF#02-0083    100.0    0.000    1.0000    ?    0.0    Major    >1000    30
    Calcium Aluminum Oxide Hydrate    Ca2Al2O5!8H2O    PDF#11-0205    100.0    0.000    1.0000    ?    0.0    Major    >1000    32
    Calcium Aluminum Oxide Hydrate    Ca2Al2O5!6H2O    PDF#12-0008    100.0    0.000    1.0000    ?    0.0    Major    >1000    24
    Calcium Aluminum Oxide Hydrate    CaAl2O4!10H2O    PDF#12-0408    100.0    0.000    1.0000    ?    0.0    Major    >1000    44
    Calcium Aluminum Oxide Hydrate    Ca4Al2O7!19H2O    PDF#14-0628    100.0    0.000    1.0000    ?    0.0    Major    >1000    39
    Calcium Aluminum Oxide Hydrate    Ca4Al2O7!19H2O    PDF#14-0631    100.0    0.000    1.0000    ?    0.0    Major    >1000    39
    Calcium Aluminum Hydroxide Hydrate    Ca2Al(OH)7!6.5H2O    PDF#16-0339    100.0    0.000    1.0000    ?    0.0    Major    >1000    34
    Katoite, syn    Ca3Al2(OH)12    PDF#24-0217    100.0    0.000    1.0000    ?    0.0    Major    >1000    71
    Calcium Aluminum Oxide Hydrate    Ca4Al6O13!3H2O    PDF#33-0254    100.0    0.000    1.0000    ?    0.0    Major    >1000    48
    Calcium Aluminum Oxide Hydroxide Hydrate    Ca2Al(OH)7!3H2O    PDF#33-0255    100.0    0.000    1.0000    ?    0.0    Major    >1000    11
    Calcium Aluminum Oxide Hydroxide Hydrate    Ca6Al2O6(OH)6!32H2O    PDF#41-0216    100.0    0.000    1.0000    ?    0.0    Major    >1000    27
    Calcium Aluminum Oxide Hydroxide Hydrate    3CaO!Al2O3!Ca(OH)2!18H2O    PDF#42-0487    100.0    0.000    1.0000    ?    0.0    Major    >1000    45
    Calcium Aluminum Oxide Hydrate    Ca2Al2O5!8H2O    PDF#45-0564    100.0    0.000    1.0000    3.70    0.0    Major    >1000    25
    Caldecahydrite [NR]    CaAl2O4!10H2O    PDF#47-1882    100.0    0.000    1.0000    ?    0.0    Major    >1000    19
