电迁移的微观结构
金相显微镜
  • PCBA表面污染后,在一定电压、温度和湿度条件下,污染物会产生定向迁移。图片显示为有表面保护涂层的PCBA的晶枝生长。
  • 该帖子已被版主-ldx_8261加2积分,加2经验;加分理由:感谢分享
  • ldx_8261
    第2楼2012/02/23
    像树叶,两边的是污染物吗?
  • jjchan48
    第3楼2012/02/23
    It is electrochemical migration (ECM) or electromigration.
    ECM is a failure mechanism that is manifested as a reduction in surface insulation resistance (SIR) of a printed circuit board (PCB). The occurrence of ECM requires an electrolyte, a voltage bias, and migrating metal.,
