生产工艺翻译 主要是第一句话
专业英语
  • The centrate, containing polysaccharide material is then filtered through both the depth and the 0.35 μm filters in series. The product is then transferred through a closed system to the
    purification area for further processing.
    然后,经串联的厚度和0.35 μm过滤器过滤含有多糖物料的分离液。然后,将产品经封闭系统转移到纯化区作进一步处理。(参考译文)
    我觉得应该是 采用深层过滤器和0.35 μm过滤器连续过滤含有多糖物料的分离液
    请各位大侠,帮忙看看!谢谢
  • 影子
    第1楼2012/05/19
    series在这里是不是连续(过滤)的意思?
  • poorlittle
    第2楼2012/05/19
    in series 有可能是 depth filter 与 0.35 μm filter 的连接方式。
    If positive, my suggested translation is to be “将深层过滤器和0.35 μm过滤器串连起来过滤含有多糖物料的分离液”
  • poorlittle
    第3楼2012/05/19
    It is difficult and inappropriate to translate the technical article based on the literal meaning of the text alone. What are the actual operation process and the setting up of apparatus?
