找到一篇国外的注册信息资料,上面有方法验证结果 如下 a. Assay i. Precision and Accuracy 1. 7 independent solutions 6 compared to first 2. Acceptable Criteria: NLT 0.95 (Probability) 3. Calculated probability: 1.00 (Passes) a. Mean = 100.13 b. Standard Deviation = 0.13 c. % RSD = 0.13 d. Lower = 98.0, Upper =102.0% 在含量测定项下,精密度和准确度实验中,最后结果要求他写了Calculated probability: 1.00 (Passes),我想问,这里是什么意思?应该怎么翻译理解
