With the column temperature at 35 to 40,rapidly inject 1 to 2 ul of nonretained compound with the split/splitless in the split mode.If using Megabore direct or cool on column modes ,delute the nonretained compound so that the sample will not saturate the detector.这段该怎么翻译,谢谢。
