poorlittle
第2楼2008/02/06
From Google, I found that the term “Flexural Modulus (Taylor's)” appeared in several websites. It is likely that Taylor’s Modulus is Flexural Modulus (弯曲模量). If positive, relevant testing standards can be found by searching in Google with the key words “Flexural Modulus, GB” or “Flexural Modulus, ASTM”
poorlittle
第3楼2008/02/07
Flexure Test Standards
ASTM
D790-02 Standard Test Methods for Flexural Properties of Unreinforced and Reinforced Plastics and Electrical Insulating Materials
D6272-02 Standard Test Method for Flexural Properties of Unreinforced and Reinforced Plastics and Electrical Insulating Materials by Four-Point Bending
C393-00 Standard Test Method for Flexural Properties of Sandwich Constructions
C78-02 Standard Test Method for Flexural Strength of Concrete (Using Simple Beam with Third-Point Loading)
C293-02 Standard Test Method for Flexural Strength of Concrete (Using Simple Beam With Center-Point Loading)
C1161-02b Standard Test Method for Flexural Strength of Advanced Ceramics at Ambient Temperature
D143-94(2000)e1 Standard Test Methods for Small Clear Specimens of Timber
D6109-97e1 Standard Test Methods for Flexural Properties of Unreinforced and Reinforced Plastic Lumber
D198-99 Standard Test Methods of Static Tests of Lumber in Structural Sizes
C1341-00 Standard Test Method for Flexural Properties of Continuous Fiber-Reinforced Advanced Ceramic Composites
D5572-95(1999) Standard Specification for Adhesives Used for Finger Joints in Nonstructural Lumber Products
ISO
178:2001 Plastics - Determination of Flexural Properties
poorlittle
第4楼2008/02/07
旧GB9341-1998《塑料弯曲性能试验方法》中关于弯曲模量的定义是:由负荷/挠度曲线的初始线性部分按Ef=L3P/(4bh3Y)计算。
式中 Ef--弯曲模量,Mpa
P --负荷-挠度曲线的初始线性部分上选定点的负荷,N
Y --与负荷相对应的挠度,mm
L --跨度,mm
b --试样宽度,mm
h--试样厚度,mm
But improvement has been made in GB9341-2000. (新)
For further details, please refer to新旧标准中塑料弯曲模量的计算方法比较 ( http://www.17-china.cn/Html/Cn/NewsView_ID13.html )
