故障提示:Current through power transistor out of tolerance
This problem may be due to a damaged transistor requiring a service visit or it may be due to improper plasma conditions.
Try the following: » Observe the plasma discharge during ignition through the viewing window. If the plasma lights, but then extinguishes right away, check the argon flows, torch condition, and test for air leaks. » If the plasma is being blown out of the torch or is unstable during ignition, then check for proper argon flow and air leaks. » If the plasma is stable during ignition, but still extinguishes, one of the transistors may have been damaged and must be replaced by service.
Try again to ignite the plasma. If you are not successful after several trials, contact Perkin Elmer service and arrange a service visit.
出现此故障之前,是冷却水的the water will not shut off【0525】。清理冷却水阀后仪器可以正常点火。然后接着出现这故障。
