雾非雾
第2楼2013/03/01
别名:Terbufos (Terbuphos)
化合物名称 (CAS):[(tert-butylthio)methylthio]-diethoxy-thioxophosphorane
化合物名称 (IUPAC):tert-butylsulfanylmethylsulfanyl-diethoxy-sulfanylidene-$l^{5}-phosphane
分子式:C9H21O2PS3
分子量:288.430601
CAS号:13071-79-9
分子结构数据
1、 摩尔折射率:77.32
2、 摩尔体积(m3/mol):249.8
3、 等张比容(90.2K):639.5
4、 表面张力(dyne/cm):42.9
5、 极化率(10-24cm3):30.65
氢键受体数量:2
氢键给体数量:0
总电价:0
拓扑分子极性表面积(TPSA):18.5
重原子数量:15
复杂度:206
Log P(已计算):4.5
急性毒性:大鼠口服LD50:1600ug/kg;大鼠皮肤LD50:7400/kg;小鼠口服LD50:3500ug/kg;兔子皮肤LD50:1100
ug/kg/24H;鹌鹑口服LD50:15mg/kg
分离模式 | 标题 | 色谱柱 |
Gas Chromatography | Nitrogen and Phosphorous Pesticides (EPA 507) Mix # 3 on ZB-5ms | Zebron™ ZB-5MS, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Organophosphorous Pesticides (EPA 8141) Mix # 3 on ZB-5ms | Zebron™ ZB-5MS, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Nitrogen and Phosphorous Pesticides on ZB-5MS | Zebron™ ZB-5MS, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Nitrogen and Phosphorous Pesticides - EPA Method 507 on ZB-5MS | Zebron™ ZB-5MS, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | EPA Method 8141A on ZB-5MS | Zebron™ ZB-5MS, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Organo Phosphorous Pesticides Mix 1 on ZB-5MS | Zebron™ ZB-5MS, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Nitrogen and Phosphorous Pesticides (EPA 507) Mix # 3 on ZB-5MSi | Zebron™ ZB-5MSi, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Organophosphorous Pesticides (EPA 8141) Mix # 3 on ZB-5MSi | Zebron™ ZB-5MSi, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Gas Chromatography | Pesticides by MSD on ZB-5MSi | Zebron™ ZB-5MSi, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
技术:gc,HPLC
分离模式:Gas Chromatography,Reversed Phase Chromatography
化合物类别:Environmental / Health
化合物分类:Pesticide / Insecticide,Pollutant / Contaminant
药理作用:Anthelmintics,Antinematodal Agents,Antispermatogenic Agents,Fungicides, Industrial,Herbicides,Insect Repellents,Insecticides
方法:EPA 507,EPA 525,EPA 8141
