出售二手扫描电镜
综合仪器采购
  • 出售二手Philips Xl30W,有意向请邮件:y.z@vip.163.com
    Configuration:
    - Source : W or LaB6
    - System from Matsushita Malaysia
    - Stage : 50mm 5 Axis
    - SE detector
    - EDAX EDS System
    - Software WinNT (can support LAN & UBS ports available)
    - Pumps – Mechanical + Oil Diffusion Pump (ODP) + Ion Getter Pump (IGP)
    Specifications:
    • Resolution: 3.5nm @ 30kV; 30nm @ 1kV
    • Tungsten gun system with 6 position auto-bias
    • Emission current: 0 – 200uA
    • High voltage range 0.2 – 30kV, continuous
    • Beam Current: 0.4pA – 4uA max, continuously variable
    • Conical final lens
    • Auto focus and auto stig
    • ET type SED detector
    • CCD Chamberscope
    Stage & Specimen Handling:
    • Drawer type door
    • 5 axis stage
    • X= 50mm / Y = 50mm
    • Z = 10mm internal, 25mm external
    • R = 360 degrees continuous
    • Tilt = -10 to +90 degrees
    • 35 degree EDX port
  • gegeyc88
    第2楼2013/08/29
    二手还是有市场的,不知楼主有没有卖出去呢,不过还是请楼主将机器购买时间,使用频率,售后等相关内容发布出来。
  • gsxu
    第3楼2013/12/30
    楼主,怎么联系呢?
