化学物质名称 | CAS号 | |
1 | Formaldehyde 甲醛 | 50-00-0 |
2 | Aniline 苯胺 | 62-53-3 |
3 | N-Nitrosodimethylamine 二甲基亚硝胺 | 62-75-9 |
4 | n-Butanol 正丁醇 | 71-36-3 |
5 | Benzene 苯 | 71-43-2 |
6 | Vinyl chloride 氯乙烯 | 1975-1-4 |
7 | Acetaldehyde 乙醇 | 75-07-0 |
8 | Methylene chloride 二氯甲烷 | 1975-9-2 |
9 | Carbon disulfide 二硫化碳 | 75-15-0 |
10 | Methyl sthyl ketone 甲基乙基酮 | 78-93-3 |
11 | 1,1,2,2-Tetrachloroethane 1,1,2,2-四氯乙烷 | 79-34-5 |
12 | Tetrabromobisphenol A 四溴双酚A | 79-94-7 |
13 | Bisphenol A 双酚A | 1980-5-7 |
14 | Diethyl phthalate 邻苯二甲酸二乙酯 | 84-66-2 |
15 | DBP (Dibuty phthalates); di-n-butyl phthalate 邻苯二甲酸二丁酯 | 84-74-2 |
16 | Di-n-Hexyl Phthalate 邻苯二甲酸二己酯 | 84-75-3 |
17 | Phthalic anhydride 邻苯二甲酰胺 | 85-44-9 |
18 | Benzyl butyl phthalate; Butyl benzyl phthalate 邻苯二甲酸丁苄酯 | 85-68-7 |
19 | N-Nitrosodiphenylamine N-亚硝基二苯胺 | 86-30-6 |
20 | Hexachlorobutadiene 六氯丁二烯 | 87-68-3 |
21 | Propyl paraben 尼泊金丙酯 | 94-13-3 |
22 | Butyl paraben 丁酯 | 94-26-8 |
23 | 2-Aminotoluene 邻甲基苯胺 | 95-53-4 |
24 | 2,4-Diaminotoluene 2,4-二氨基甲苯 | 95-80-7 |
25 | Methy paraben 对羟基苯甲酸甲酯 | 99-76-7 |
26 | p-Hydroxybenzoic acid 对羟基苯甲酸 | 99-96-7 |
27 | Ethylbenzene 乙苯 | 100-41-4 |
28 | Styrene 苯乙烯 | 100-42-4 |
29 | 4-Nonylphenol;4-NP and its isomer 4-壬基苯酚 | 104-40-5 |
30 | para-Choroaniline 4-氯苯胺 | 106-47-8 |
31 | Acrylonitrile 丙烯腈 | 107-13-1 |
32 | Ethylene glycol 乙二醇 | 107-21-1 |
33 | Toluene 甲苯 | 108-88-3 |
34 | Phenol 苯酚 | 108-95-2 |
35 | 2-Methoxyethanol 乙二醇甲醚 | 109-86-4 |
36 | Ethylene glycol monoethyl ester 乙二醇单乙醚 | 110-80-5 |
37 | Tris(2-chloroethyl)phosphate 磷酸三(2-氯乙基)酯 | 115-96-8 |
38 | DEHP; bis(2-ethylhexyl)phthalate 邻苯二甲酸二辛酯 | 117-81-7 |
39 | DOP (Di-n-octyl phthalata) 邻苯二甲酸二正辛酯 | 117-84-0 |
40 | Hexachlorobenzene 六氯苯 | 118-74-1 |
41 | 3,3'-Dimethylbenzidine & Dyes Metabolized to same 3,3'-二甲基联苯胺 | 119-93-7 |
42 | Ethyl paraben 尼泊金乙酯 | 120-47-8 |
43 | 1,4-Dioxane 1,4-二氧六环 | 123-91-1 |
44 | Perchlororethylene;tetrachloroethylene 四氯乙烯 | 127-18-4 |
45 | Benzophenone-2 2,2',4,4'-四羟基二苯甲酮 | 131-55-5 |
46 | 4-tert-Octylphenol 辛基酚 | 140-66-9 |
47 | Estragole 4-烯丙基苯甲醚 | 140-67-0 |
48 | 2-Ethylhexanoic Acid 异辛酸 | 149-57-5 |
49 | Octamethylcyclotetrasiloxane 八甲基环四硅氧烷 | 556-67-2 |
50 | Pentachlorobenzene 五氯苯 | 608-93-5 |
51 | C.I.Solvent Yellow 14 苏丹红一号 | 842-07-9 |
52 | N-Methylpyrrolidone N-甲基吡咯烷酮 | 872-50-4 |
53 | 2,2',3,3',4,4',5,5',6,6',-Decabromodlphenyl ether 十溴联苯醚 | 1163-19-5 |
54 | Perfluorooctanyl sulphonic acid and its salts; PFOS 全氟辛烷磺酸盐 | 1763-23-1 |
55 | 4-octyl phenol对辛基苯酚 | 1806-26-4 |
56 | 2-Ethyl-hexyl-4-methoxycinnamate 对甲氧基肉桂酸辛酯 | 5466-77-3 |
57 | Mercury & mercury compounds 汞及其化合物 | 7439-97-6 |
58 | Molybdenum & molybdenum compounds 钼及其化合物 | 7439-98-7 |
59 | Antimony & Antimony compounds 锑及其化合物 | 7440-36-0 |
60 | Arsenic & Arsenic compounds 砷及其化合物 | 7440-38-2 |
61 | Cadmium & cadmium compounds 镉及其化合物 | 7440-43-9 |
62 | Cobalt & Cobalt compounds 钴及其化合物 | 7440-48-4 |
63 | Butyated hydroxyanisole 叔丁基-4-羟基苯甲醚 | 25013-16-5 |
64 | Hexabromocyclododecane 六溴环十二烷 | 25637-99-4 |
65 | DIDP; Diisodecyl Phthalate 邻苯二甲酸二异癸酯 | 26761-40-0 |
66 | DiNP (Di-iso-nonyl phthalate) 邻苯二甲酸二异壬酯 | 28553-12-0 |
依风1986
第4楼2013/07/09
化学物质名称 | CAS 号 | 应用定量限PQL(ppm) (特意添加) | 用途 | |
1 | Formaldehyde 甲醛 | 50-00-0 | 5.0 | 用作有机化工原料,用于医药、合成纤维、合成树脂、塑料防腐剂、还原剂等; 主要用于制备酚醛、脲醛、三聚氰胺和聚甲醛树脂,多用于油漆、布料等。 |
2 | Aniline 苯胺 | 62-53-3 | 1.0 | 用于医药和橡胶硫化促进剂; 制造树脂和涂料的原料。 |
3 | N-Nitrosodimethylamine 二甲基亚硝胺 | 62-75-9 | 1.0 | 医药及食品分析研究 |
4 | n-Butanol 正丁醇 | 71-36-3 | 5.0 | 主要用于制造邻苯二甲酸、脂肪族二元酸及磷酸的正丁酯类增塑剂,它们广泛用于各种塑料和橡胶制品中。也是有机合成中制丁醛、丁酸、丁胺和乳酸丁酯等的原料。还是油脂、药物(如抗生素、激素和维生素)和香料的萃取剂,醇酸树脂涂料的添加剂等。又可用作有机染料和印刷油墨的溶剂,脱蜡剂。 |
5 | Benzene 苯 | 71-43-2 | 1.0 | 用于制作苯胺的硝基苯;多用于农药的各种氯苯;合成用于生产洗涤剂和添加剂的各种烷基苯。·合成氢醌,蒽醌等化工产品。 |
6 | Vinyl chloride 氯乙烯 | 75-01-4 | 1.0 | 生产聚氯乙烯(PVC)的原料 |
7 | Acetaldehyde 乙醇 | 75-07-0 | 1.0 | 用来制造醋酸、饮料、香精、染料、燃料等;消毒剂。 |
8 | Methylene chloride 二氯甲烷 | 75-09-2 | 1.0 | 大量用于制造安全电影胶片、聚碳酸酯。 |
9 | Carbon disulfide 二硫化碳 | 75-15-0 | 10.0 | 用於制造缧萦(rayon)、土壤消毒剂、电子真空管、四氯化碳、橡胶、玻璃纸等。 |
10 | Methyl sthyl ketone 甲基乙基酮 | 78-93-3 | 1.0 | 用于润滑油脱蜡、涂料工业及多种树脂溶剂、植物油的萃取过程; |
11 | 1,1,2,2-Tetrachloroethane 1,1,2,2-四氯乙烷 | 79-34-5 | 1.0 | 主要用作生产三氯乙烯、四氯乙烯的原料,亦用作树脂、橡胶、脂肪等的不易燃烧溶剂 |
12 | Tetrabromobisphenol A 四溴双酚A | 79-94-7 | 20.0 | 大量用于溴化环氧树脂、溴化聚碳酸酯、溴化酚醛树脂、溴化不饱和树脂等。 |
13 | Bisphenol A 双酚A | 80-05-7 | 20.0 | 被用来合成聚碳酸酯(PC)和环氧树脂等材料; 含于矿泉水瓶、医疗器械及食品包装里 |
14 | Diethyl phthalate 邻苯二甲酸二乙酯 | 84-66-2 | 5.0 | 用作增塑剂、溶剂、润滑剂、定香剂、有色或稀有金属矿山浮选的起泡剂、气相色谱固定液、酒精变性剂、喷雾杀虫剂;主要用于纤维素树脂的增塑剂。 |
15 | DBP (Dibuty phthalates); di-n-butyl phthalate 邻苯二甲酸二丁酯 | 84-74-2 | 5.0 | 可用作聚醋酸乙烯、醇酸树脂、硝基纤维素、乙基纤维素及氯丁橡胶、丁腈橡胶的增塑剂。 |
16 | Di-n-Hexyl Phthalate 邻苯二甲酸二己酯 | 84-75-3 | 5.0 | 邻苯二甲酸酯类增塑剂中最重要的品种。 |
17 | Phthalic anhydride 邻苯二甲酸酐 | 85-44-9 | 100.0 | 用于制造增塑剂、苯二甲酸二丁酯、树酯和染料等。 |
18 | Benzyl butyl phthalate; Butyl benzyl phthalate邻苯二甲酸丁苄酯 | 85-68-7 | 5.0 | 用作聚氯乙烯、氯乙烯共聚物、纤维素树脂、天然和合成橡胶的增塑剂。 |
19 | N-Nitrosodiphenylamine N-亚硝基二苯胺 | 86-30-6 | 1.0 | 用作天然橡胶、合成橡胶(丁基橡胶除外)的防焦剂,也可作为已有轻微焦烧的胶料的再塑化剂,还可作高效阻聚剂。 |
20 | Hexachlorobutadiene 六氯丁二烯 | 87-68-3 | 30.0 | 用作溶剂、热载体、热交换剂、水力系统用液体、洗液,也用于合成橡胶工业。 |
21 | Propyl paraben 尼泊金丙酯 | 94-13-3 | 30.0 | 在药剂、化妆品中作抑菌防腐剂;用作防腐剂及抗氧化剂,也用于制药工业。 |
22 | Butyl paraben 丁酯 | 94-26-8 | 30.0 | 主要用作有机合成中间体,医药、食品、化妆品、胶片及高档产品的防腐剂、杀菌剂。 |
23 | 2-Aminotoluene 邻甲基苯胺 | 95-53-4 | 1.0 | 用作染料、农药、医药及有机合成中间体。 |
24 | 2,4-Diaminotoluene 2,4-二氨基甲苯 | 95-80-7 | 10.0 | 是有机合成原料之一,可制取甲苯二异氰酸酯。也用作染料中间体、毛发染黑。 |
25 | Methy paraben 对羟基苯甲酸甲酯 | 99-76-3 | 30.0 | 防腐剂;抗微生物剂。用作食品、化妆品及医药防霉剂。 |
26 | p-Hydroxybenzoic acid 对羟基苯甲酸 | 99-96-7 | 10.0 | 主要用于有机合成、染料、香料等工业,也用于制备高效防腐剂 |
27 | Ethylbenzene 乙苯 | 100-41-4 | 1.0 | 主要用于生产苯乙烯,进而生产苯乙烯均聚物以及以苯乙烯为主要成分的共聚物(ABS,AS等)。乙苯少量用于有机合成工业,例如生产苯乙酮、乙基蒽醌、对硝基苯乙酮、甲基苯基甲酮等中间体。在医药上用作合霉素和氯霉素的中间体。也用于香料。此外,还可作溶剂使用。 |
28 | Styrene 苯乙烯 | 100-42-5 | 1.0 | 最重要的用途是作为合成橡胶和塑料的单体,用来生产丁苯橡胶、聚苯乙烯、泡沫聚苯乙烯;也用于与其他单体共聚制造多种不同用途的工程塑料。如与丙烯腈、丁二烯共聚制得ABS树脂,广泛用于各种家用电器及工业上;与丙烯腈共聚制得的SAN是耐冲击、色泽光亮的树脂;与丁二烯共聚所制得的SBS是一种热塑性橡胶,广泛用作聚氯乙烯、聚丙烯的改性剂等。 |
29 | 4-Nonylphenol;4-NP and its isomer 对壬基酚 | 104-40-5 | 10.0 | 具有良好的耐酸碱,抗氧化,润湿、乳化、清洗性能,应用广泛。 |
30 | para-Choroaniline 4-氯苯胺 | 106-47-8 | 60.0 | 是偶氮染料及色酚AS-LB的中间体,也是医药利眠宁、非那西丁及农药的原料,还用于制彩色胶片成色剂。 |
31 | Acrylonitrile 丙烯腈 | 107-13-1 | 1.0 | 用于合成聚丙烯腈、尼龙66、丁腈橡胶、ABS树脂、聚丙烯酰胺、丙烯酸酯类等,也用作谷物烟熏剂。 |
32 | Ethylene glycol 乙二醇 | 107-21-1 | 5.0 | 主要用于生产聚酯树脂、醇酸树脂、增塑剂、防冻剂,也用于化妆品和炸药。 |
33 | Toluene 甲苯 | 108-88-3 | 1.0 | 广泛用作有机溶剂和合成医药、涂料、树脂、染料、炸药和农药等的原料。 |
34 | Phenol 苯酚 | 108-95-2 | 60.0 | 是重要有机合成原料,用于制酚醛树脂、双酚A、酚酞、苦味酸、水杨酸、烷基苯酚等化学品,还可用作溶剂。 |
35 | 2-Methoxyethanol 乙二醇甲醚 | 109-86-4 | 10.0 | 用作涂料溶剂、渗透剂、匀染剂及有机合成中间体,也用作喷气燃料的添加剂; 也是各种油脂类硝基纤维素和合成树脂的溶剂。 |
36 | Ethylene glycol monoethyl ester 乙二醇单乙醚 | 110-80-5 | 10.0 | 用作硝基赛璐珞、假漆等的溶剂,皮革着色剂及乳化液稳定剂 |
37 | Tris(2-chloroethyl)phosphate 磷酸三(2-氯乙基)酯 | 115-96-8 | 50.0 | 主要用于聚氨酯泡沫阻燃以及聚氯乙烯阻燃增塑等;广泛用于化纤织物、醋酸纤维素作阻燃剂,除具有自熄性外,还可改善耐水性、耐寒性及抗静电性。 |
38 | DEHP; bis(2-ethylhexyl)phthalate 邻苯二甲酸二辛酯 | 117-81-7 | 20.0 | 最广泛使用的增塑剂,除了乙酸纤维素、聚乙酸乙烯外,与绝大多数工业上使用的合成树脂和橡胶均有良好的相容性。 |
39 | DOP (Di-n-octyl phthalata) 邻苯二甲酸二正辛酯 | 117-84-0 | 5.0 | 属无毒增塑剂,可用于制作食品包装材料。本品还用作溶剂和气相色谱固定液。 |
40 | Hexachlorobenzene 六氯苯 | 118-74-1 | 30.0 | 用于生产花炮,作焰火色剂。还用作五氯酚及五氯酚钠的原料。 |
41 | 3,3'-Dimethylbenzidine & Dyes Metabolized to same 3,3'-二甲基联苯胺 | 119-93-7 | 10.0 | 用于染料工业,分析试剂、吸附指示剂和氧化还原指剂,也作冰染染料的显色基、偶氮染料的中间体和树脂固化剂。 |
42 | Ethyl paraben 对羟基苯甲酸乙酯 | 120-47-8 | 30.0 | 用作食品防腐剂,也用于制药、皮革等行业。 |
43 | 1,4-Dioxane 1,4-二氧六环 | 123-91-1 | 1.0 | 用作醋酸纤维素、树脂、植物油、矿物油、溶性染料等的溶剂,用于制喷漆、清漆、增塑剂、润滑剂等。 |
44 | Perchlororethylene; tetrachloroethylene 四氯乙烯 | 127-18-4 | 0.5 | 广泛用于服装、毛皮、织物的干洗,金属脱脂及油脂抽提等方面,是重要的有机合成原料,有机分析中用作脂肪或脂肪类似物质的溶剂,有机合成。 |
45 | Benzophenone-2 2,2',4,4'-四羟基二苯甲酮 | 131-55-5 | 20 | 广泛用于聚丙烯、聚乙烯, 还可用于聚氯乙烯、有机玻璃、 ABS 树脂、涂料、石油制品和橡胶等制品。另适用于聚烯烃(特别是聚氯乙烯)、聚酯、苯乙烯类、聚酰胺、聚碳酸酯等聚合物。 |
46 | 4-tert-Octylphenol 辛基酚 | 140-66-9 | 10.0 | 用于生产辛基酚聚氧乙烯醚和辛基酚甲醛树脂,亦广泛用作非离子表面活性剂、纺织助剂、油田助剂、抗氧剂和橡胶硫化剂的原料。 |
47 | Estragole 4-烯丙基苯甲醚 | 140-67-0 | 10.0 | 主要供配制香辛料、啤酒香精和调味剂。用于焙烤制品、含醇及无醇饮料、胶姆糖、糖果、蜜饯、冰淇淋、鱼、沙拉、沙司、醋等。 |
48 | 2-Ethylhexanoic Acid 异辛酸 | 149-57-5 | 1.0 | 油漆和涂料催干剂的中间体,用作醇酸树脂改性剂,用于生产过氧化物以作为聚合反应(例如PE)的催化剂,用于润滑油酯和PVC稳定剂。 |
49 | Octamethylcyclotetrasiloxane 八甲基环四硅氧烷 | 556-67-2 | 10.0 | 该品为硅油,硅橡胶的中间体。用作制备硅油中间体,无线电零件的绝缘、防潮等; 制造高抗撕硅橡胶制品,也用于合成其他高分子化合物。 |
50 | Pentachlorobenzene 五氯苯 | 608-93-5 | 1.0 | 用于制备五氯硝基苯。 |
51 | C.I.Solvent Yellow 14 苏丹红一号 | 842-07-9 | 1.0 | 用于皮鞋油、地板蜡、油脂等的着色,也用于礼花、透明漆的制造; 动植物组织中类酯化合物的染色。 |
52 | N-Methylpyrrolidone N-甲基吡咯烷酮 | 872-50-4 | 50.0 | 广泛用作芳烃抽提、乙炔提浓、丁二烯分离和合成气的脱硫等过程中的萃取剂,同时也是农药、工程塑料、涂料、合成纤维、集成电路等生产中的溶剂,也可作工业用洗涤剂、分散剂、染色剂、润滑油抗冻剂等。 |
53 | 2,2',3,3',4,4',5,5',6,6',-Decabromodlphenyl ether 十溴联苯醚 | 1163-19-5 | 10.0 | 高效添加型阻燃剂,对HIPS、ABS、LDPE、橡胶、PBT等都具有优良的阻燃效果,亦可用于尼龙纤维及涤棉纺织物。 |
54 | Perfluorooctanyl sulphonic acid and its salts; PFOS 全氟辛烷磺酸盐 | 1763-23-1 | 1.0 | 化学试剂、精细化学品、医药中间体、材料中间体。 |
55 | 4-octyl phenol对辛基苯酚 | 1806-26-4 | 10.0 | 广泛用于制造油溶性酚醛树脂、表面活性剂、粘合剂等。 |
56 | 2-Ethyl-hexyl-4-methoxycinnamate 对甲氧基肉桂酸辛酯 | 5466-77-3 | 5.0 | 用于配制防晒霜(膏、乳、液)等护肤化妆品,用于配制防晒霜(膏、乳、液)等护肤化妆品;在工业上可作为塑料、油墨的抗老剂和紫外线吸收剂。 |
57 | Mercury & mercury compounds 汞及其化合物 | 7439-97-6 | 0.5 | 制造汞盐及汞剂、还原剂,有机化合物氧化反应催化剂,血液非蛋白氮生化检验,农药六六六的异丙体分析。广泛用于各种仪表和温度计。极谱分析滴汞电极。 |
58 | Molybdenum & molybdenum compounds 钼及其化合物 | 7439-98-7 | 1.0 | 用作热氢发生器、凝胶推进剂、燃烧活性剂、催化剂、水清洁吸附剂、烧结活性剂等; 还用于制合金钢及各种工具钢; 硅化钼电热元件原料。 |
59 | Antimony & Antimony compounds 锑及其化合物 | 7440-36-0 | 1.0 | 锑在冶金中主要用于制造合金;锑也用于半导体中;三氧化二锑还可作透明的珐琅质白颜料。也用于印刷和颜料行业。 |
60 | Arsenic & Arsenic compounds 砷及其化合物 | 7440-38-2 | 1.0 | 用于制取合金的添加物、特种玻璃、涂料、医药及农药等。 |
61 | Cadmium & cadmium compounds 镉及其化合物 | 7440-43-9 | 1.0 | 用作还原剂, 也用于镉盐及合金的制造。 |
62 | Cobalt & Cobalt compounds 钴及其化合物 | 7440-48-4 | 1.0 | 用于制超硬耐热合金和磁性合金、钴化合物、催化剂等。 |
63 | Butyated hydroxyanisole 叔丁基-4-羟基苯甲醚 | 25013-16-5 | 10.0 | 作为食品添加剂,用于油脂、猪油、鱼贝盐腌品、鱼贝干制品、椒盐饼干、炸马铃薯薄片、方便面、油炸点心等的油的抗氧化剂。也用作饲料添加剂和汽油添加剂。 |
64 | Hexabromocyclododecane 六溴环十二烷 | 25637-99-4 | 10.0 | 用作EPS(发泡聚苯乙烯)、聚丙烯纤维和苯乙烯树脂的阻燃剂,也可以作为聚乙烯、聚碳酸脂、不饱和聚脂等塑料的阻燃添加剂,还适用于织物、丁苯胶、粘合剂和涂料进行阻燃处理。 |
65 | DIDP; Diisodecyl Phthalate 邻苯二甲酸二异癸酯 | 26761-40-0 | 50.0 | 用作色谱固定液。 |
66 | DiNP (Di-iso-nonyl phthalate) 邻苯二甲酸二异壬酯 | 28553-12-0 | 50.0 | 是性能优良的通用型主增塑剂。 |
