刘彦刚
第4楼2014/02/13
一般来说,给出示值误差△的测量不确定度U95或k=2时的U与评定测量仪器的最大允许误差的绝对值(MPEP)之比小于或等于1:3时,合格与否的评定可忽略示值误差△的测量不确定度,此时
合格判据为:|△|<= MPEV
不合格判据为:|△|>MPEV
当给出示值误差△的测量不确定度U95或k=2时的U与评定测量仪器的最大允许误差的绝对值(MPEP)之比不满足小于或等于1:3时,合格与否的评定不可忽略示值误差△的测量不确定度,此时
合格判据为:|△|<= MPEV - U95
不合格判据为:|△|>MPEV + U95
待定区:MPEV - U95 <|△|>=MPEV + U95 此时不能判定合格与否。
kangatang
第5楼2014/02/13
如果依据计量检定规程对测量仪器进行评定,是不是就不需要考虑示值误差△的测量不确定度?
poorlittle
第8楼2014/02/13
I have kept silent for several weeks in this forum because my Chinese character inputting device is out of order. May I answer your question in English, sorry.
“不需要考虑对示值误差评定的测量不确定度影响”because of the principle “规程对评定方法、计量标准、环境条件等已作出规定,并满足检定系统表量值传递的要求”. Therefore, no matter the “规程” is called JJG, or JJF, BS, ASTM, ISO……, “不需要考虑对示值误差评定的测量不确定度影响”as soon as the conditions of the above principle is fulfilled.
I have used BS and ISO to calibrate the universal testing machines for many years, uncertainty has never been applied in evaluating the grading of the machine.
刘彦刚
第9楼2014/02/14
虽说在一楼没有给出解说,但回答得所那个干脆!也让我佩服!
kangatang
第10楼2014/02/14
Thanks for your warm heart. 事实上我在写内校的WI文件。那段被我引用在我WI中,原文如下:
When the calibration of an equipment with normal performance is carried out according to the regulations of metrological verification or calibration (JJG & JJF standards)which claim the fixed verification methods, metrological standards, environment condition etc. and satisfy the traceability requirements of National Metrological Verification System, the measurement uncertainty of indication error (measured value – reference value) could be well controlled in a proper range. In this case, the uncertainty of indication error can be considered as unnecessary, and the criterion of acceptance is |x-A|≤MPEV.
