hothot
第5楼2014/04/08
你碰到的问题应该是瓶盖太大(瓶盖下缘突起),vial应该是OK,vial 8/9/10/11mm都放得进Clarus 680。
2012-2013消耗品手册把部分LC的瓶盖放到GC的区域了。
请参考2010年手册的才不会买错。
或是参考以下几项也可以。
Description Pkg Part No.
Crimp Top Vials:
2 mL 11 mm Crimp Top Clear Glass Vials 100 N9301385
2 mL 11 mm Crimp Top Amber Glass Vials 100 N9302680
Crimp Top Septa:
11 mm Blue Crimp Caps with Teflon®/Rubber Septa 100 N9302686
11 mm Green Crimp Caps with Teflon®/Rubber Septa 100 N9302684
11 mm Red Crimp Caps with Teflon®/Rubber Septa 100 N9302685
11 mm Silver Crimp Caps with Teflon®/Rubber Septa 100 N9306015
11 mm Silver Crimp Cap with Black Viton® Septa 1000 N9302784
Screw Top Vials/Caps/Septa:
2 mL 8 mm Screw Top Clear Glass Vials 100 N9302945
8 mm Screw Caps 100 N9303441
2 mL 9 mm Screw Top Amber Vials 100 N9306220
PTFE-Coated Butyl Rubber Septa for 8 mm Screw Top Vials 100 N9303442
