它山之石
第5楼2016/04/29
ASTM F963-11, EN71-3, ISO 8124-3 等都有,只是针对可溶性重金属(soluble),不是总含量(total).
H.5 Test portions (7.1, 7.3.3.2, 7.3.3.3, 7.3.3.6)
For category III toys (Scraped off) it is not always possible to obtain 100 mg of toy material. If less than 10 mg of toy material can be obtained, it is not required to analyse. From such a small amount of toy material the exposure to certain elements is considered to be negligible. If 10 mg to 100 mg of toy material is available, than the test shall be performed as if it were 100 mg of material. The migration is calculated as though 100 mg of the test portion had been used. This compensates for the low exposure to certain elements by migration from such low amounts of toy material. (EN71-3)
Nicole
第6楼2016/05/03
谢谢
