symmacros
第2楼2015/10/25
A Mohr pipette, also known as a Graduated pipette, is a type of pipette used to measure the volume of the liquid dispensed, although not as accurately as a volumetric pipette.[1] These use a series of marked lines (as on a graduated cylinder) to indicate the different volumes.[2] They come in a variety of sizes, and are used much like a burette, in that the volume is found by calculating the difference of the liquid level before and after.
The last graduation mark is some distance from the tip, to avoid errors in measuring the narrower volume of the nozzle.[3] It was invented by Karl Friedrich Mohr, the Father of Volumetric Analysis.
度过冰河时期的远古族人
第6楼2015/11/03
同版主,参加竞赛。请问莫尔吸量管在哪里可以买到?或者普通的吸量管参数和他一样吗,可不可以用普通的代替,拜谢!
度过冰河时期的远古族人
第7楼2015/11/03
