symmacros
第4楼2016/05/31
Model The m/z value (or TIC) used for determining the component peak shape. If adjacent peak subtraction has been activated (6.3.3 Deconv. (Deconvolution) Tab), the m/z value may be followed by one or two additional m/z values. These are masses, whose profiles have been subtracted from the model peak’s profile, to yield the component profile. The model peak is generally the ion (or TIC) that rises and falls the fastest.
