1前言
最近和几个DHI的朋友聊天,都知道测试清洗效率,也大概知道如何测,但还的没有很透彻的理解何为清洗效率,并且将乳成分和体细胞的清洗效率混淆。
清洗效率和残留测试概念一样,都是检查DHI仪器是否有残留,清洗效率越高,则残留越低,反之亦然。两者的和为100%。比如清洗效率98%,则残留为100%-98%=2%。
何为残留? 用官方的话讲,就是连续两个样品之间交叉污染的程度。举个生活中的例子来说明。当你吃了一个柠檬,再吃西瓜的时候,发现西瓜很甜。当你吃了一块冰糖,再吃同一块西瓜的时候,就没那么甜了,这就是残留。
2标准规定
因为乳成分分析仪和体细胞测试方法都不是中国国家标准规定方法,先将国际标准规定和中国农业部标准规定和大家分享。
2.1乳成分分析国际标准
乳成分国际标准名称:Milk and liquid milk products-Guidelines for the
application of mid-infrared spectrometry。其标准号为BS ISO 9622:2013。
对残留测试的规定如下:
Carry-over
Carry-over isdefined as the residual volume of the previous sample as a percentage of t he total volume of the instrument cell after a single pumpingsequence of a sample through the instrument cell. Internal factors/issues affecting carry-over includepump settings, flow system deficiencies and
compensationfactors. External factors affecting carry-over include transfer from thestirrer and pipette.
To assesscarry-over for the complete system, including carry-over from the eventuallyapplied automatic sampling system, run the samples from 20 separate vials usingthe complete system.
To assesscarry-over for the flow system alone, run the samples manually, thereby wiping the pipette
clean betweencycles.
To check the carry-over, analyse 20 consecutive samples of water and whole (Be cautiouswith raw
milk; it has tobe homogenous.) milk, using the sequence: water, water, milk, milk, water,water, etc., and record for each sample of water and milk, the readings foreach of the major compositional parameters.Calculate for each parameter, thewater-to-milk, Ew, and the milk-to-water carry-over, EM, byusing Formula (2) and (3):
![](https://ng1.17img.cn/bbsfiles/images/2016/08/201608261019_606846_1644065_3.jpg)
2.2体细胞测试国际标准
体细胞国际标准名称:Milk-Enumerationof somatic cells-
Part 2:Guidance on the operation offluoro-opto-electronic counters
标准号为:ISO13366-2:2006(E) IDF148-2:2006(E)
对残留测试的规定如下:
![](https://ng1.17img.cn/bbsfiles/images/2016/08/201608261019_606847_1644065_3.png)
3测试周期
清洗效率必须每周检查。如果发现可疑,应该马上检查,可作为校准前的检查项目。清洗效率必须>99%,即残留率小于1%。
4乳成分测试程序
4.1测试程序
用200ml的混合均匀的生乳样品,倒入10个样品瓶中,加热到40℃。取200ml的干净的蒸馏水。将水倒入10个样品瓶中,并加热到40℃。按2个水2个奶的顺序将样品瓶放到样品架上。
建立样品测定批次,选择carryover选项,批次默认为残留测试状态,选择乳成分模块和自动进样器,点击测定,仪器会自动测定。测定完毕后,点击报告,仪器自动计算清洗效率的结果。
4.2结果计算
计算所有第一个水样的总和W1=#1+#5+#9+#13+#17
计算所有第二个水样的总和W2=#2+#6+#10+#14+#18
计算所有第一个奶样的总和M1=#3+#7+#11+#15+#19
计算所有第一个奶样的总和M2=#4+#8+#12+#16+#20
水-奶的清洗效率=(M1-W2)/(M2-W2)×100
奶-水的清洗效率=(W1-M2)/(W2-M2) ×100
乳成分分析仪清洗效率原始记录 |
名称 | 脂肪 | 蛋白 | 乳糖 |
水1 | 0.00 | 0.00 | 0.00 |
水2 | 0.00 | 0.00 | 0.00 |
奶1 | 4.43 | 2.97 | 259.00 |
奶2 | 4.45 | 3.00 | 270.00 |
水3 | 0.02 | 0.02 | 3.00 |
水4 | 0.00 | 0.00 | 0.00 |
奶3 | 4.43 | 2.97 | 248.00 |
奶4 | 4.44 | 2.99 | 249.00 |
水5 | 0.03 | 0.02 | 5.00 |
水6 | 0.00 | 0.00 | 0.00 |
奶5 | 4.43 | 2.97 | 259.00 |
奶6 | 4.45 | 3.00 | 253.00 |
水7 | 0.03 | 0.02 | 2.00 |
水8 | 0.00 | 0.00 | 0.00 |
奶7 | 4.43 | 2.98 | 258.00 |
奶8 | 4.45 | 3.00 | 264.00 |
水9 | 0.03 | 0.02 | 2.00 |
水10 | 0.00 | 0.00 | 0.00 |
奶9 | 4.43 | 2.98 | 258.00 |
奶10 | 4.44 | 2.99 | 268.00 |
W1 | 0.11 | 0.08 | 12.00 |
W2 | 0.0 | 0.0 | 0.0 |
M1 | 22.15 | 14.87 | 1282.00 |
M2 | 22.23 | 14.98 | 1304.00 |
残留 | 0.36% | 0.73% | 1.69% |
水-奶清洗效率 | 99.64% | 99.27% | 98.31% |
测试结论 | 合格 |
测定日期 | |
测定人 | | 审核人 | |
5体细胞测试程序
5.1测试程序
用200 mL的混合均匀的生乳样品,倒入5个样品瓶中,加热到40℃。取200mL的干净的蒸馏水。将水倒入10个样品瓶中,并加热到40℃。按1个奶2个水的顺序将样品瓶放到样品架上。
建立样品测定批次,选择carryover选项,批次默认为残留测试状态,选择体细胞模块和自动进样器,点击测定,仪器会自动测定。测定完毕后,点击报告,仪器自动计算清洗效率的结果。
5.2结果计算
计算所有第一个水样的总和W1=#2+#5+#8+#11+#14
计算所有第二个水样的总和W2=#3+#6+#9+#12+#15
计算所有第一个奶样的总和M1=#1+#4+#7+#10+#13
清洗效率=(W1-W2)/(M1-W2) ×100
体细胞测定仪清洗效率原始记录 |
| 体细胞SCC |
奶1 | 270 |
水1 | 6 |
水2 | 0 |
奶2 | 261 |
水1 | 2 |
水2 | 0 |
奶3 | 259 |
水1 | 6 |
水2 | 0 |
奶4 | 256 |
水1 | 9 |
水2 | 0 |
奶5 | 235 |
水1 | 5 |
水2 | 0 |
W1 | 28 |
W2 | 0 |
M1 | 1281 |
残留 | 2.19% |
仪器要求 | ≤1% |
测试结论 | 不合格 |
测定日期 |
测定人 | |
审核人 | |
