symmacros
第7楼2016/12/23
Hydroxy-alpha sanshool is a molecule found in plants from the genus Zanthoxylum. It is believed to be responsible for the numbing and tingling sensation caused by eating food cooked with Sichuan peppercorns.
The term sanshool in the compound's name is derived from the Japanese term for the Sichuan pepper, sanshō (山椒?) (literally, Mountain Pepper), to which was appended the suffix -ol, indicating an alcohol.
Mechanism
Though the chemical structure is similar to that of capsaicin, the mechanism of action by which hydroxy-alpha sanshool induces sensations have been a matter of debate. Although the compound is an agonist at the pain-integrating cation channels TRPV1 and TRPA1 as is capsaicin, newer evidence suggests that the Tandem pore domain potassium channels KCNK3, KCNK9, and KCNK18 are primarily responsible for the molecule's effects.[1]
Hydroxy-alpha sanshool excites D-hair afferent nerve fibers, a distinct subset of the sensitive light touch receptors in the skin, and targets novel populations of Aβ and C-fiber nerve fibers.[2]
symmacros
第10楼2016/12/23
Hydroxy alpha sanshool
IUPAC name
(2E,6Z,8E,10E)-N-(2-hydroxy-2-methylpropyl)dodeca-2,6,8,10-tetraenamide
Identifiers
CAS number
83883-10-7
PubChem
10084135
ChemSpider
39144022
Jmol-3D images
Image 1
SMILES
CC=CC=CC=CCCC=CC(=O)NCC(C)(C)O
Properties
Molecular formula
C16H25NO2
Molar mass
263.19 g/mol
Except where noted otherwise, data are given for materials in their standard state (at 25 ?C, 100 kPa)
Infobox references
Hydroxy-alpha sanshool is a bioactive component of plants from the Xanthoxylum genus, including the Sichuan pepper. It is believed to be responsible for the numbing, tingling sensation (paresthesia) caused by eating food cooked with Sichuan peppercorns.
The molecular mechanisms by which hydroxy-alpha sanshool induces these sensations have been a matter of debate. Although the compound is an agonist at the pain-integrating cation channels TRPV1 and TRPA1, newer evidence suggests that the two-pore domain potassium channels KCNK3, KCNK9, and KCNK18 are primarily responsible for hydroxy-alpha sanshool's effects.[1]
The term sanshool in the compound's name is derived from the Japanese term for the Sichuan pepper, sanshō (山椒?) (literally, Mountain Pepper), to which was appended the suffix -ol, indicating a chemical alcohol.
