当前位置: 仪器社区 >质谱 > ICP-MS > 帖子详情
ICP-MS 用EPA的方法测试MDL
ICP-MS
  • 请教各位,我现在需要用Aglient 8800做MDL,参照了EPA的方法。我配制7个相同浓度的样品,测试完成后算MDL。在这个过程中,我加标的浓度是否可以低于我检量线的最小浓度,是否需要先做仪器的IDL,测试结果是否需要减去空白?谢谢!
    Step
    Action
    Estimate the expected MDL.
    Calculate the desired spike level such that MDL is between 10 to 100% of the spike.
    3
    Spike at least 7 replicate samples with analytes of interest. Complete the sample preparation steps for each replicate.
    4
    Calibrate the measurement tool. Measure the analytes. This is done within 1 day.
    Calculate the standard deviation of the 7 measurements. (s)
    6
    Determine the correct t-statistic tdf, 99
    Determine degrees of freedom (df=n-1)
    Find the one-tailed t-statistic for 99% confidence level
    · t-stat is 3.143 for 7 measurements.
    7
    Calculate MDL = t statistic x standard deviation x dilution factor (if not already included in the data).
    8
    Verify: 10% Spike level £ MDL £ Spike level
    9
    Validate that the calculated MDL makes sense.
  • poursuivre
    第1楼2017/03/19
    加标浓度介于2-8倍估计MDL。
    你疑惑的是扣什么空白?
