名称Name | CAS No. | 来源Source | 纯度Purity |
苯Benzene | 71-43-2 | Chem Service or equivalent | 99.5% |
甲苯Toluene | 108-88-3 | Chem Service or equivalent | 99.5% |
乙苯Ethylbenzene | 100-41-4 | Chem Service or equivalent | 99.5% |
对-二甲苯p-Xylene | 106-42-3 | Chem Service or equivalent | 99.5% |
间-二甲苯m-Xylene | 108-38-3 | Chem Service or equivalent | 99.5% |
邻-二甲苯o-Xylene | 95-47-6 | Chem Service or equivalent | 99.2% |
苯乙烯Styrene | 100-42-5 | Chem Service or equivalent | 99.5% |
正己烷Hexane | 110-54-3 | Chem Service or equivalent | 98.8% |
正十六烷Hexadecane | 544-76-3 | Sigma-Aldrich or equivalent | 98.8% |
热脱附条件 | 起始温度Initial Temperature | 30℃ |
延迟时间Delay time | 0.50 min | |
脱附升温程序1st rate | 60 ℃/min | |
脱附温度1st final temperature | 300 ℃ | |
脱附时间1st final time | 10 min | |
脱附流量Dersorption flow | 50 mL/min | |
脱附模式Flow mode | splitless | |
采样管分析模式Sample mode | standard | |
载气Carrier gas | Helium | |
冷阱条件 | 吸附剂Sorbent | Tenax TA |
冷阱温度Initial temp. | -90℃ | |
平衡时间Equilibration time | 0.50 min | |
脱附升温程序1st rate | 10 ℃/s | |
脱附时间1st final time | 5 min | |
分流模式Split | 60:1 | |
传输线温度Transfer line to CIS | 300 ℃ | |
气质仪条件 | 进样口温度Temperature of Inlet | 250 ℃ |
Vent Pressure 9 Psi | ||
色谱柱gc Column | Ultra 2 | |
50m×0.32mm×0.52μm | ||
柱温度Oven | 50℃ hold10min, 5℃/min to 250℃ hold 10min | |
流速Flow rate | 1.0 mL/min | |
分析模式Pneumatics(EPS) | (Const Follow) | |
采集模式MS-modus | (Scan) | |
扫描范围Scan mode(low/high mass) | 35~550 | |
离子源温度MS Source temperature MS | 230 ℃ | |
四级杆温度MS quad temperature MS | 150 ℃ | |
传输线温度(Aux-2 Temp) | 250 ℃ |
