ian.cheng
第5楼2017/11/06
是的,是有针对性的,目前还在公众咨询中。
Bis (2-ethylhexyl) phthalate in rubber parts such as O-rings, seals, vibration dampers, gaskets, hoses,
grommets and cap-plugs that are used in engine systems including exhausts and turbochargers that are designed
for use in equipment that is not designed solely for consumer use."
