happyjyl
第4楼2006/12/29
Note之后的:
Using a one-quarter inch wrench disconnect the valve capillary from the outlet ball valve. Using a 14 mm's wrench loosen the valve and remove it from the pump body. Check that the new valve is assembled correctly and that the gold seal is present. Reinstall the outlet ball valve and tighten the valve. Reconnect the valve capillary.
视频里有详细演示,就不翻译成中文了.
深海的海豚
第5楼2006/12/29
真是太厉害了,佩服!非常佩服!偶快崇拜happyjyl了
唉,我听了好几遍,只对alcohol能明白 ,
呵呵,以后要多多向两位版主学习了。
poorlittle
第8楼2007/02/15
(小弟可勉强看懂简体汉字,但用键盘输入汉字则很因难。以下用英文或中英混合表述,请谅。)
真是太厉害了,佩服!非常佩服!
A person without technical background (even though who may have Ph. D degree in linguistics) will probably translate “sonic bath” as 声波槽. In fact, “sonic” sometimes may imply both sonic and ultrasonic in oral English. However, only "ultrasonic" is used for cleaning.
Therefore, Happyjyl’s translation (i.e. "超声"清洗, not 声波清洗) is very appropriate and this case also substantiate that technical paper / speech should be translated by technical personnel.
