参考IEC62321-6-2015中8.3.a gc column: non-polar (phenyl-arylene-polymer equivalent to 5 % phenyl-methylpolysiloxane),
length 15 m; internal diameter 0,25 mm; film thickness 0,1 μm. A hightemperature
column (maximum = 400 ?C) shall be used for the stated gc conditions in the
method.
柱子15mX0.25mmX0.1um
