ISO 811:2018 Textiles -- Determination of resistance to water penetration -- Hydrostatic pressure test 纺织品—抗渗水性的测定--静水压试验
ISO 1833-6:2018 Textiles -- Quantitative chemical analysis-- Part 6: Mixtures of viscose, certain types of cupro, modal or lyocell with certain other fibres (method using formic acid and zinc chloride) 纺织品--定量化学分析--第6部分:粘胶纤维、某些铜氨纤维、莫代尔或莱赛尔与某些其他纤维的混合物(甲酸和氯化锌法)
ISO 1833-20:2018 Textiles -- Quantitative chemical analysis-- Part 20: Mixtures of elastane with certain other fibres (method using dimethylacetamide) 纺织品--定量化学分析--第20部分:弹性纤维与某些其他纤维的混合物(二甲基乙酰胺法)
ISO 1833-27:2018 Textiles -- Quantitative chemical analysis-- Part 27: Mixtures of cellulose fibres with certain other fibres (method using aluminium sulfate) 纺织品--定量化学分析--第27部分:纤维素纤维与某些其他纤维的混合物(硫酸铝法)
ISO 3175-4:2018 Textiles -- Professional care, drycleaning and wetcleaning of fabrics and garments -- Part 4: Procedure for testing performance when cleaning and finishing using simulated wetcleaning 纺织品—纺织品和服装的专业维护、干洗和湿洗--第4部分:使用模拟湿洗法清洗和整理时性能试验的程序
ISO 8559-3:2018 Size designation of clothes -- Part 3:Methodology for the creation of body measurement tables and intervals 服装号型--第3部分:创建身体测量表和间隔的方法
ISO 10290:2018 Textiles -- Cotton yarns -- Basis for specification 纺织品--棉纱线—分类基础
ISO 15487:2018 Textiles -- Method for assessing appearanceof apparel and other textile end products after domestic washing and drying 纺织品--服装和其他纺织制品经家庭洗涤和干燥后评估外观的方法
ISO 15496:2018 Textiles -- Measurement of water vapour permeability of textiles for the purpose of quality control 纺织品--质量控制用的纺织品透湿性测试方法
ISO/TR 17881-3:2018 Textiles -- Determination of certain flameretardants -- Part 3: Chlorinated paraffin flame retardants 纺织品--某些阻燃剂的测定第3部分:氯化石蜡阻燃剂
ISO 18254-2:2018 Textiles -- Method for the detection and determination of alkylphenol ethoxylates (APEO) --Part 2: Method using NPLC 纺织品--烷基酚聚氧乙烯醚(APEO)的检测与测定方法 第2部分:NPLC法
ISO 18890:2018 Clothing -- Standard method of garment measurement 服装--服装测量的标准方法 ISO 20158:2018 Textiles -- Determination of water absorption time and water absorption capacity of textile fabrics 纺织品—织物吸水时间和吸水能力的测定
ISO 20418-1:2018 Textiles -- Qualitative and quantitative proteomic analysis of some animal hair fibres -- Part 1: Peptide detectionusing LC-ESI-MS with protein reduction 纺织品--某些动物毛纤维的定性和定量蛋白质组学分析--第1部分:用带蛋白质还原的液相色谱质谱(LC-ESI-MS)进行肽测定
ISO 20418-2:2018 Textiles -- Qualitative and quantitative proteomic analysis of some animal hair fibres -- Part 2: Peptide detectionusing MALDI-TOF MS 纺织品--某些动物毛纤维的定性和定量蛋白质组学分析--第2部分:用激光辅助基质解析电离飞行时间质谱(MALDI-TOF-MS)进行肽测定
ISO 20754:2018 Textiles -- Man-made fibres -- Determination of shape factors in cross section 纺织品--化学纤维--截面异形度的测定
ISO 20920:2018 Textiles -- Man-made fibres --Determination of dye uptake of cationic dyeable modified polyester fibres 纺织品--化学纤维--阳离子染料可染改性涤纶上色率的测定
ISO 20932-1:2018 Textiles -- Determination of the elasticity of fabrics -- Part 1: Strip tests 纺织品--织物弹性的测定--第1部分:条样试验
ISO 20932-2:2018 Textiles -- Determination of the elasticity of fabrics -- Part 2: Multiaxial tests 纺织品--织物弹性的测定--第2部分:多轴试验
ISO 20932-3:2018 Textiles -- Determination of the elasticity of fabrics -- Part 3: Narrow fabrics 纺织品--织物弹性的测定--第3部分:窄幅织物
ISO 21046:2018 Silk -- Test method for determining the size of silk yarns 丝--蚕丝纱线纤度试验方法
ISO 21232:2018 Textiles -- Determination of moisturizing effect of textile materials by measurement of microclimate between textiles andsimulated human skin using sweating guarded hotplate 纺织品—用热阻湿阻测试仪测量纺织品和模拟的人体皮肤之间的微气候来测定纺织材料的保湿效果
ISO 12957-1:2018 Geosynthetics -- Determination of friction characteristics -- Part 1: Direct shear test 土工合成材料--摩擦特性的测定--第1部分:直接剪切试验
ISO 13438:2018 Geosynthetics -- Screening test method for determining the resistance of geotextiles and geotextile-related products tooxidation 土工合成材料--测定土工织物及其相关产品抗氧化性的筛选试验方法
ISO 1419:2018 Rubber- or plastics-coated fabrics --Accelerated-ageing tests 橡胶或塑料涂覆织物--加速老化试验
ISO 32100:2018 Rubber- or plastics-coated fabrics --Physical and mechanical tests -- Determination of flex resistance by the flexometer method 橡胶或塑料涂覆织物--物理和机械试验—用挠度仪测定耐折性能
ISO 10325:2018 Fibre ropes -- High modulus polyethylene --8-strand braided ropes, 12-strand braided ropes and covered ropes 纤维绳-高模量聚乙烯--8股、12股编绳和复编绳索
ISO 18692-1:2018 Fibre ropes for off shore station keeping --Part 1: General specification 海上定位用纤维绳--第1部分:通用规范
