Time(min) | 0.0 | 2.0 | 2.1 | 3.1 | 6.0 |
B% | 5.0 | 5.0 | 60.0 | 5.0 | 5.0 |
检测方式:MRM多反应监测 Ion Source Type: H-ESI Positive Ion (V): 4000 Negative Ion (V): 3200 Sheath Gas (Arb): 40 Aux Gas (Arb): 10 Sweep Gas (Arb): 0 Ion Transfer Tube Temp (°C): 350 | Vaporizer Temp (°C): 300 Default Charge State: 1 Cycle Time (sec): 0.4 Q1 Resolution (FWHM): 0.7 Q3 Resolution (FWHM): 1.2 CID Gas (mTorr): 1.5 Source Fragmentation: 10 | ||||
Compound | Polarity | Precursor (m/z) | Product (m/z) | Collision Energy (V) | RF Lens (V) |
TMS+ | Positive | 202 | 122 | 7.82 | 72 |
tms- | Negative | 178 | 79.8 | 25.6 | 136 |
表3 样品加标回收率与方法精密度实验
样品本底值(mg/kg) | 加标量(mg/kg) | 回收率(%) | 平均回收率 (%) | RSD (%) | |||||
白酒(0.0058) | 0.03 | 79.6 | 76.2 | 69.1 | 77.7 | 72.4 | 72.8 | 74.6 | 5.2 |
0.10 | 78.7 | 77.2 | 76.9 | 79.1 | 75.9 | 79.1 | 77.8 | 1.7 | |
1.00 | 85.2 | 86.5 | 86.4 | 85.9 | 86.4 | 81.8 | 85.4 | 2.1 | |
葡萄酒(0.0045) | 0.03 | 95.0 | 101.6 | 102.4 | 104.3 | 106.0 | 108.5 | 102.9 | 4.5 |
0.10 | 93.5 | 95.2 | 93.3 | 99.5 | 94.2 | 92.4 | 94.7 | 2.7 | |
1.00 | 101.0 | 102.0 | 104.3 | 104.1 | 104.9 | 105.2 | 103.6 | 1.6 |
甜蜜素(ug/mL) | 进样量(uL) | 峰面积 | 峰面积均值 | RSD (%) | |||||
0.10 | 10.0 | 101.0 | 102.0 | 104.3 | 104.1 | 104.9 | 105.2 | 103.6 | 1.6 |
名称 | 上机液浓度 | 信噪比S/N |
甜蜜素 0.03 mg/kg | 3.0 ng/mL | 166 |
