做牛做马
第1楼2007/03/15
A193/A193M-06a Standard Specification for Alloy-Steel and Stainless Steel Bolting Materials for High Temperature or High Pressure Service and Other Special Purpose Applications
A194/A194M-07 Standard Specification for Carbon and Alloy Steel Nuts for Bolts for High Pressure or High Temperature Service, or Both
A197/A197M-00(2006) Standard Specification for Cupola Malleable Iron
A203/A203M-97(2003) Standard Specification for Pressure Vessel Plates, Alloy Steel, Nickel
A204/A204M-03 Standard Specification for Pressure Vessel Plates, Alloy Steel, Molybdenum
A209/A209M-03 Standard Specification for Seamless Carbon-Molybdenum Alloy-Steel Boiler and Superheater Tubes
A210/A210M-02 Standard Specification for Seamless Medium-Carbon Steel Boiler and Superheater Tubes
A213/A213M-06ae1 Standard Specification for Seamless Ferritic and Austenitic Alloy-Steel Boiler, Superheater, and Heat-Exchanger Tubes
A214/A214M-96(2005) Standard Specification for Electric-Resistance-Welded Carbon Steel Heat-Exchanger and Condenser Tubes
A216/A216M-04 Standard Specification for Steel Castings, Carbon, Suitable for Fusion Welding, for High-Temperature Service
A217/A217M-04 Standard Specification for Steel Castings, Martensitic Stainless and Alloy, for Pressure-Containing Parts, Suitable for High-Temperature Service
A220/A220M-99(2004) Standard Specification for Pearlitic Malleable Iron
A225/A225M-03 Standard Specification for Pressure Vessel Plates, Alloy Steel, Manganese-Vanadium-Nickel
A227/A227M-06 Standard Specification for Steel Wire, Cold-Drawn for Mechanical Springs
A228/A228M-02 Standard Specification for Steel Wire, Music Spring Quality
A229/A229M-99(2005) Standard Specification for Steel Wire, Oil-Tempered for Mechanical Springs
A230/A230M-05 Standard Specification for Steel Wire, Oil-Tempered Carbon Valve Spring Quality
A231/A231M-04 Standard Specification for Chromium-Vanadium Alloy Steel Spring Wire
A232/A232M-05 Standard Specification for Chromium-Vanadium Alloy Steel Valve Spring Quality Wire
A234/A234M-06a Standard Specification for Piping Fittings of Wrought Carbon Steel and Alloy Steel for Moderate and High Temperature Service
A239-95(2004) Standard Practice for Locating the Thinnest Spot in a Zinc (Galvanized) Coating on Iron or Steel Articles
A240/A240M-06c Standard Specification for Chromium and Chromium-Nickel Stainless Steel Plate, Sheet, and Strip for Pressure Vessels and for General Applications
A242/A242M-04e1 Standard Specification for High-Strength Low-Alloy Structural Steel
A247-06 Standard Test Method for Evaluating the Microstructure of Graphite in Iron Castings
A249/A249M-04a Standard Specification for Welded Austenitic Steel Boiler, Superheater, Heat-Exchanger, and Condenser Tubes
A250/A250M-05 Standard Specification for Electric-Resistance-Welded Ferritic Alloy-Steel Boiler and Superheater Tubes
A252-98(2002) Standard Specification for Welded and Seamless Steel Pipe Piles
A254-97(2002) Standard Specification for Copper-Brazed Steel Tubing
A255-02e1 Standard Test Methods for Determining Hardenability of Steel
A262-02ae3 Standard Practices for Detecting Susceptibility to Intergranular Attack in Austenitic Stainless Steels
A263-03 Standard Specification for Stainless Chromium Steel-Clad Plate
A264-03 Specification for Stainless Chromium-Nickel Steel-Clad Plate
A265-03 Standard Specification for Nickel and Nickel-Base Alloy-Clad Steel Plate
A266/A266M-03a Standard Specification for Carbon Steel Forgings for Pressure Vessel Components
A268/A268M-05a Standard Specification for Seamless and Welded Ferritic and Martensitic Stainless Steel Tubing for General Service
A269-04 Standard Specification for Seamless and Welded Austenitic Stainless Steel Tubing for General Service
A270-03a Standard Specification for Seamless and Welded Austenitic Stainless Steel Sanitary Tubing
A275/A275M-06 Standard Test Method for Magnetic Particle Examination of Steel Forgings
A276-06 Standard Specification for Stainless Steel Bars and Shapes
A278/A278M-01(2006) Standard Specification for Gray Iron Castings for Pressure-Containing Parts for Temperatures Up to 650°F (350°C)
A283/A283M-03 Standard Specification for Low and Intermediate Tensile Strength Carbon Steel Plates
A285/A285M-03 Standard Specification for Pressure Vessel Plates, Carbon Steel, Low- and Intermediate-Tensile Strength
A288-91(2003) Standard Specification for Carbon and Alloy Steel Forgings for Magnetic Retaining Rings for Turbine Generators
A289/A289M-97(2003) Standard Specification for Alloy Steel Forgings for Nonmagnetic Retaining Rings for Generators
A290/A290M-05 Standard Specification for Carbon and Alloy Steel Forgings for Rings for Reduction Gears
A291/A291M-05 Standard Specification for Steel Forgings, Carbon and Alloy, for Pinions, Gears and Shafts for Reduction Gears
A295/A295M-05 Standard Specification for High-Carbon Anti-Friction Bearing Steel
A297/A297M-97(2003) Standard Specification for Steel Castings, Iron-Chromium and Iron-Chromium-Nickel, Heat Resistant, for General Application
A299/A299M-04 Standard Specification for Pressure Vessel Plates, Carbon Steel, Manganese-Silicon
A302/A302M-03 Standard Specification for Pressure Vessel Plates, Alloy Steel, Manganese-Molybdenum and Manganese-Molybdenum-Nickel
A304-05e2 Standard Specification for Carbon and Alloy Steel Bars Subject to End-Quench Hardenability Requirements
A307-04e1 Standard Specification for Carbon Steel Bolts and Studs, 60 000 PSI Tensile Strength
A308/A308M-06 Standard Specification for Steel Sheet, Terne (Lead-Tin Alloy) Coated by the Hot-Dip Process
A309-01 Standard Test Method for Weight and Composition of Coating on Terne Sheet by the Triple-Spot Test
A311/A311M-04 Standard Specification for Cold-Drawn, Stress-Relieved Carbon Steel Bars Subject to Mechanical Property Requirements
A312/A312M-06 Standard Specification for Seamless, Welded, and Heavily Cold Worked Austenitic Stainless Steel Pipes
A313/A313M-03 Standard Specification for Stainless Steel Spring Wire
A314-97(2002) Standard Specification for Stainless Steel Billets and Bars for Forging
A319-71(2006) Standard Specification for Gray Iron Castings for Elevated Temperatures for Non-Pressure Containing Parts
做牛做马
第2楼2007/03/15
A320/A320M-05a Standard Specification for Alloy-Steel and Stainless Steel Bolting Materials for Low-Temperature Service
A321-90(2001) Standard Specification for Steel Bars, Carbon, Quenched and Tempered
A322-06 Standard Specification for Steel Bars, Alloy, Standard Grades
A323-05 Standard Specification for Ferroboron
A324-73(2004) Standard Specification for Ferrotitanium
A325M-05 Standard Specification for Structural Bolts, Steel, Heat Treated 830 MPa Minimum Tensile Strength [Metric]
A325-06 Standard Specification for Structural Bolts, Steel, Heat Treated, 120/105 ksi Minimum Tensile Strength
A327-91(2006) Standard Test Methods for Impact Testing of Cast Irons
A327M-91(2006) Standard Test Methods for Impact Testing of Cast Irons (Metric)
A328/A328M-05 Standard Specification for Steel Sheet Piling
A333/A333M-05 Standard Specification for Seamless and Welded Steel Pipe for Low-Temperature Service
A334/A334M-04a Standard Specification for Seamless and Welded Carbon and Alloy-Steel Tubes for Low-Temperature Service
A335/A335M-06 Standard Specification for Seamless Ferritic Alloy-Steel Pipe for High-Temperature Service
A336/A336M-06a Standard Specification for Alloy Steel Forgings for Pressure and High-Temperature Parts
A338-84(2004) Standard Specification for Malleable Iron Flanges, Pipe Fittings, and Valve Parts for Railroad, Marine, and Other Heavy Duty Service at Temperatures Up to 650°F (345°C)
A340-03a Standard Terminology of Symbols and Definitions Relating to Magnetic Testing
A341/A341M-00(2005) Standard Test Method for Direct Current Magnetic Properties of Materials Using D-C Permeameters and the Ballistic Test Methods
A342/A342M-04 Standard Test Methods for Permeability of Feebly Magnetic Materials
A343/A343M-03 Standard Test Method for Alternating-Current Magnetic Properties of Materials at Power Frequencies Using Wattmeter-Ammeter-Voltmeter Method and 25-cm Epstein Test Frame
A345-04 Standard Specification for Flat-Rolled Electrical Steels for Magnetic Applications
A348/A348M-05 Standard Test Method for Alternating Current Magnetic Properties of Materials Using the Wattmeter-Ammeter-Voltmeter Method, 100 to 10 000 Hz and 25-cm Epstein Frame
A350/A350M-04a Standard Specification for Carbon and Low-Alloy Steel Forgings, Requiring Notch Toughness Testing for Piping Components
A351/A351M-06 Standard Specification for Castings, Austenitic, for Pressure-Containing Parts
A352/A352M-06 Standard Specification for Steel Castings, Ferritic and Martensitic, for Pressure-Containing Parts, Suitable for Low-Temperature Service
A353/A353M-04 Standard Specification for Pressure Vessel Plates, Alloy Steel, 9 Percent Nickel, Double-Normalized and Tempered
A354-04e1 Standard Specification for Quenched and Tempered Alloy Steel Bolts, Studs, and Other Externally Threaded Fasteners
A355-89(2006) Standard Specification for Steel Bars, Alloys, for Nitriding
A356/A356M-05 Standard Specification for Steel Castings, Carbon, Low Alloy, and Stainless Steel, Heavy-Walled for Steam Turbines
A358/A358M-05 Standard Specification for Electric-Fusion-Welded Austenitic Chromium-Nickel Stainless Steel Pipe for High-Temperature Service and General Applications
A363-03 Standard Specification for Zinc-Coated (Galvanized) Steel Overhead Ground Wire Strand
A367-60(2005) Standard Test Methods of Chill Testing of Cast Iron
A368-95a(2004) Standard Specification for Stainless Steel Wire Strand
A369/A369M-06 Standard Specification for Carbon and Ferritic Alloy Steel Forged and Bored Pipe for High-Temperature Service
A370-06 Standard Test Methods and Definitions for Mechanical Testing of Steel Products
A372/A372M-03 Standard Specification for Carbon and Alloy Steel Forgings for Thin-Walled Pressure Vessels
A376/A376M-06 Standard Specification for Seamless Austenitic Steel Pipe for High-Temperature Central-Station Service
A377-03 Standard Index of Specifications for Ductile-Iron Pressure Pipe
A380-06 Standard Practice for Cleaning, Descaling, and Passivation of Stainless Steel Parts, Equipment, and Systems
A381-96(2005) Standard Specification for Metal-Arc-Welded Steel Pipe for Use With High-Pressure Transmission Systems
A384/A384M-02 Standard Practice for Safeguarding Against Warpage and Distortion During Hot-Dip Galvanizing of Steel Assemblies
A385-05 Standard Practice for Providing High-Quality Zinc Coatings (Hot-Dip)
A387/A387M-06a Standard Specification for Pressure Vessel Plates, Alloy Steel, Chromium-Molybdenum
A388/A388M-05 Standard Practice for Ultrasonic Examination of Heavy Steel Forgings
A389/A389M-03 Standard Specification for Steel Castings, Alloy, Specially Heat-Treated, for Pressure-Containing Parts, Suitable for High-Temperature Service
A390-06 Standard Specification for Zinc-Coated (Galvanized) Steel Poultry Fence Fabric (Hexagonal and Straight Line)
做牛做马
第3楼2007/03/15
A391/A391M-01 Standard Specification for Grade 80 Alloy Steel Chain
A392-06 Standard Specification for Zinc-Coated Steel Chain-Link Fence Fabric
A394-05e1 Standard Specification for Steel Transmission Tower Bolts, Zinc-Coated and Bare
A395/A395M-99(2004) Standard Specification for Ferritic Ductile Iron Pressure-Retaining Castings for Use at Elevated Temperatures
A400-69(2006) Standard Practice for Steel Bars, Selection Guide, Composition, and Mechanical Properties
A401/A401M-03 Standard Specification for Steel Wire, Chromium-Silicon Alloy
A403/A403M-06 Standard Specification for Wrought Austenitic Stainless Steel Piping Fittings
A407-93(2004) Standard Specification for Steel Wire, Cold-Drawn, for Coiled-Type Springs
A409/A409M-01(2005) Standard Specification for Welded Large Diameter Austenitic Steel Pipe for Corrosive or High-Temperature Service
A411-03 Standard Specification for Zinc-Coated (Galvanized) Low-Carbon Steel Armor Wire
A413/A413M-01 Standard Specification for Carbon Steel Chain
A414/A414M-06 Standard Specification for Steel, Sheet, Carbon, for Pressure Vessels
A416/A416M-06 Standard Specification for Steel Strand, Uncoated Seven-Wire for Prestressed Concrete
A417-93(2004) Standard Specification for Steel Wire, Cold-Drawn, for Zig-Zag, Square-Formed, and Sinuous-Type Upholstery Spring Units
A418/A418M-05 Standard Test Method for Ultrasonic Examination of Turbine and Generator Steel Rotor Forgings
A420/A420M-06 Standard Specification for Piping Fittings of Wrought Carbon Steel and Alloy Steel for Low-Temperature Service
A421/A421M-05 Standard Specification for Uncoated Stress-Relieved Steel Wire for Prestressed Concrete
A423/A423M-95(2004) Standard Specification for Seamless and Electric-Welded Low-Alloy Steel Tubes
A424-06 Standard Specification for Steel, Sheet, for Porcelain Enameling
A426/A426M-05 Standard Specification for Centrifugally Cast Ferritic Alloy Steel Pipe for High-Temperature Service
A427-02 Standard Specification for Wrought Alloy Steel Rolls for Cold and Hot Reduction
A428/A428M-06 Standard Test Method for Weight [Mass] of Coating on Aluminum-Coated Iron or Steel Articles
A434-06 Standard Specification for Steel Bars, Alloy, Hot-Wrought or Cold-Finished, Quenched and Tempered
A435/A435M-90(2001) Standard Specification for Straight-Beam Ultrasonic Examination of Steel Plates
A436-84(2006) Standard Specification for Austenitic Gray Iron Castings
A437/A437M-06 Standard Specification for Alloy-Steel Turbine-Type Bolting Material Specially Heat Treated for High-Temperature Service
A439-83(2004) Standard Specification for Austenitic Ductile Iron Castings
A447/A447M-93(2003) Standard Specification for Steel Castings, Chromium-Nickel-Iron Alloy (25-12 Class), for High-Temperature Service
A449-04be1 Specification for Hex Cap Screws, Bolts, and Studs, Steel, Heat Treated, 120/105/90 ksi Minimum Tensile Strength, General Use
A450/A450M-04a Standard Specification for General Requirements for Carbon, Ferritic Alloy, and Austenitic Alloy Steel Tubes
A451/A451M-06 Standard Specification for Centrifugally Cast Austenitic Steel Pipe for High-Temperature Service
A453/A453M-04 Standard Specification for High-Temperature Bolting Materials, with Expansion Coefficients Comparable to Austenitic Stainless Steels
A455/A455M-03 Standard Specification for Pressure Vessel Plates, Carbon Steel, High-Strength Manganese
A456/A456M-99(2003) Standard Specification for Magnetic Particle Examination of Large Crankshaft Forgings
A459-97(2003) Standard Specification for Zinc-Coated Flat Steel Armoring Tape
A460-94(2004)e1 Standard Specification for Copper-Clad Steel Wire Strand
A463/A463M-06 Standard Specification for Steel Sheet, Aluminum-Coated, by the Hot-Dip Process
A466/A466M-01 Standard Specification for Weldless Chain
A467/A467M-01(2006) Standard Specification for Machine and Coil Chain
A469/A469M-06 Standard Specification for Vacuum-Treated Steel Forgings for Generator Rotors
A470/A470M-05e1 Standard Specification for Vacuum-Treated Carbon and Alloy Steel Forgings for Turbine Rotors and Shafts
A471-06 Standard Specification for Vacuum-Treated Alloy Steel Forgings for Turbine Rotor Disks and Wheels
A472/A472M-05 Standard Test Method for Heat Stability of Steam Turbine Shafts and Rotor Forgings
A473-01 Standard Specification for Stainless Steel Forgings
A474-03 Standard Specification for Aluminum-Coated Steel Wire Strand
A475-03 Standard Specification for Zinc-Coated Steel Wire Strand
A476/A476M-00(2005) Standard Specification for Ductile Iron Castings for Paper Mill Dryer Rolls
A478-97(2002) Standard Specification for Chromium-Nickel Stainless Steel Weaving and Knitting Wire
A479/A479M-06a Standard Specification for Stainless Steel Bars and Shapes for Use in Boilers and Other Pressure Vessels
A480/A480M-06b Standard Specification for General Requirements for Flat-Rolled Stainless and Heat-Resisting Steel Plate, Sheet, and Strip
A481-05 Standard Specification for Chromium Metal
A482-05 Standard Specification for Ferrochrome-Silicon
A483-04 Standard Specification for Silicomanganese
A484/A484M-06b Standard Specification for General Requirements for Stainless Steel Bars, Billets, and Forgings
A485-03 Standard Specification for High Hardenability Antifriction Bearing Steel
A487/A487M-93(2003) Standard Specification for Steel Castings Suitable for Pressure Service
A488/A488M-06 Standard Practice for Steel Castings, Welding, Qualifications of Procedures and Personnel
A489-04e1 Standard Specification for Carbon Steel Lifting Eyes
A490-06 Standard Specification for Structural Bolts, Alloy Steel, Heat Treated, 150 ksi Minimum Tensile Strength
A490M-04ae1 Standard Specification for High-Strength Steel Bolts, Classes 10.9 and 10.9.3, for Structural Steel Joints [Metric]
A491-03 Standard Specification for Aluminum-Coated Steel Chain-Link Fence Fabric
A492-95(2004) Standard Specification for Stainless Steel Rope Wire
A493-95(2004) Standard Specification for Stainless Steel Wire and Wire Rods for Cold Heading and Cold Forging
A494/A494M-05 Standard Specification for Castings, Nickel and Nickel Alloy
A495-06 Standard Specification for Calcium-Silicon Alloys
A496/A496M-05 Standard Specification for Steel Wire, Deformed, for Concrete Reinforcement
A497/A497M-06e1 Standard Specification for Steel Welded Wire Reinforcement, Deformed, for Concrete
做牛做马
第4楼2007/03/15
A498-06 Standard Specification for Seamless and Welded Carbon Steel Heat-Exchanger Tubes with Integral Fins
A499-89(2002) Standard Specification for Steel Bars and Shapes, Carbon Rolled from "T" Rails
A500-03a Standard Specification for Cold-Formed Welded and Seamless Carbon Steel Structural Tubing in Rounds and Shapes
A501-01(2005) Standard Specification for Hot-Formed Welded and Seamless Carbon Steel Structural Tubing
A502-03 Standard Specification for Rivets, Steel, Structural
A503/A503M-01(2006) Standard Specification for Ultrasonic Examination of Forged Crankshafts
A504/A504M-04e1 Standard Specification for Wrought Carbon Steel Wheels
A505-00(2005) Standard Specification for Steel, Sheet and Strip, Alloy, Hot-Rolled and Cold-Rolled, General Requirements for
A506-05 Standard Specification for Alloy and Structural Alloy Steel, Sheet and Strip, Hot-Rolled and Cold-Rolled
A507-06 Standard Specification for Drawing Alloy Steel, Sheet and Strip, Hot-Rolled and Cold-Rolled
A508/A508M-05b Standard Specification for Quenched and Tempered Vacuum-Treated Carbon and Alloy Steel Forgings for Pressure Vessels
A510-06 Standard Specification for General Requirements for Wire Rods and Coarse Round Wire, Carbon Steel
A510M-06 Standard Specification for General Requirements for Wire Rods and Coarse Round Wire, Carbon Steel [Metric]
A511-04 Standard Specification for Seamless Stainless Steel Mechanical Tubing
A512-06 Standard Specification for Cold-Drawn Buttweld Carbon Steel Mechanical Tubing
A513-06b Standard Specification for Electric-Resistance-Welded Carbon and Alloy Steel Mechanical Tubing
A514/A514M-05 Standard Specification for High-Yield-Strength, Quenched and Tempered Alloy Steel Plate, Suitable for Welding
A515/A515M-03 Standard Specification for Pressure Vessel Plates, Carbon Steel, for Intermediate- and Higher-Temperature Service
A516/A516M-06 Standard Specification for Pressure Vessel Plates, Carbon Steel, for Moderate- and Lower-Temperature Service
A517/A517M-06 Standard Specification for Pressure Vessel Plates, Alloy Steel, High-Strength, Quenched and Tempered
A518/A518M-99(2003) Standard Specification for Corrosion-Resistant High-Silicon Iron Castings
A519-06 Standard Specification for Seamless Carbon and Alloy Steel Mechanical Tubing
A521/A521M-06 Standard Specification for Steel, Closed-Impression Die Forgings for General Industrial Use
A522/A522M-06 Standard Specification for Forged or Rolled 8 and 9% Nickel Alloy Steel Flanges, Fittings, Valves, and Parts for Low-Temperature Service
A523-96(2005) Standard Specification for Plain End Seamless and Electric-Resistance-Welded Steel Pipe for High-Pressure Pipe-Type Cable Circuits
A524-96(2005) Standard Specification for Seamless Carbon Steel Pipe for Atmospheric and Lower Temperatures
A529/A529M-05 Standard Specification for High-Strength Carbon-Manganese Steel of Structural Quality
A530/A530M-04a Standard Specification for General Requirements for Specialized Carbon and Alloy Steel Pipe
A531/A531M-91(2006) Standard Practice for Ultrasonic Examination of Turbine-Generator Steel Retaining Rings
A532/A532M-93a(2003) Standard Specification for Abrasion-Resistant Cast Irons
A533/A533M-93(2004)e1 Standard Specification for Pressure Vessel Plates, Alloy Steel, Quenched and Tempered, Manganese-Molybdenum and Manganese-Molybdenum-Nickel
A534-04 Standard Specification for Carburizing Steels for Anti-Friction Bearings
A536-84(2004) Standard Specification for Ductile Iron Castings
A537/A537M-06 Standard Specification for Pressure Vessel Plates, Heat-Treated, Carbon-Manganese-Silicon Steel
A540/A540M-06 Standard Specification for Alloy-Steel Bolting Materials for Special Applications
A541/A541M-05 Standard Specification for Quenched and Tempered Carbon and Alloy Steel Forgings for Pressure Vessel Components
A542/A542M-99(2004)e1 Standard Specification for Pressure Vessel Plates, Alloy Steel, Quenched-and-Tempered, Chromium-Molybdenum, and Chromium-Molybdenum-Vanadium
A543/A543M-93(2004)e1 Standard Specification for Pressure Vessel Plates, Alloy Steel, Quenched and Tempered Nickel-Chromium-Molybdenum
A550-06 Standard Specification for Ferrocolumbium
A551/A551M-05 Standard Specification for Steel Tires
A553/A553M-06 Standard Specification for Pressure Vessel Plates, Alloy Steel, Quenched and Tempered 8 and 9 Percent Nickel
A554-03 Standard Specification for Welded Stainless Steel Mechanical Tubing
A555/A555M-05 Standard Specification for General Requirements for Stainless Steel Wire and Wire Rods
A556/A556M-96(2005) Standard Specification for Seamless Cold-Drawn Carbon Steel Feedwater Heater Tubes
A560/A560M-05 Standard Specification for Castings, Chromium-Nickel Alloy
A561-71(2004) Standard Practice for Macrotech Testing of Tool Steel Bars
A562/A562M-06 Standard Specification for Pressure Vessel Plates, Carbon Steel, Manganese-Titanium for Glass or Diffused Metallic Coatings
A563-04a Standard Specification for Carbon and Alloy Steel Nuts
A563M-06 Standard Specification for Carbon and Alloy Steel Nuts [Metric)
A564/A564M-04 Standard Specification for Hot-Rolled and Cold-Finished Age-Hardening Stainless Steel Bars and Shapes
做牛做马
第5楼2007/03/15
A565/A565M-05a Standard Specification for Martensitic Stainless Steel Bars for High-Temperature Service
A568/A568M-06a Standard Specification for Steel, Sheet, Carbon, Structural, and High-Strength, Low-Alloy, Hot-Rolled and Cold-Rolled, General Requirements for
A571/A571M-01(2006) Standard Specification for Austenitic Ductile Iron Castings for Pressure-Containing Parts Suitable for Low-Temperature Service
A572/A572M-06 Standard Specification for High-Strength Low-Alloy Columbium-Vanadium Structural Steel
A573/A573M-05 Standard Specification for Structural Carbon Steel Plates of Improved Toughness
A574-04e1 Standard Specification for Alloy Steel Socket-Head Cap Screws
A574M-04e1 Standard Specification for Alloy Steel Socket-Head Cap Screws [Metric]
A575-96(2002) Standard Specification for Steel Bars, Carbon, Merchant Quality, M-Grades
A576-90b(2006) Standard Specification for Steel Bars, Carbon, Hot-Wrought, Special Quality
A577/A577M-90(2001) Standard Specification for Ultrasonic Angle-Beam Examination of Steel Plates
A578/A578M-96(2001) Standard Specification for Straight-Beam Ultrasonic Examination of Plain and Clad Steel Plates for Special Applications
A579/A579M-04a Standard Specification for Superstrength Alloy Steel Forgings
A580/A580M-06 Standard Specification for Stainless Steel Wire
A581/A581M-95b(2004) Standard Specification for Free-Machining Stainless Steel Wire and Wire Rods
A582/A582M-05 Standard Specification for Free-Machining Stainless Steel Bars
A586-04a Standard Specification for Zinc-Coated Parallel and Helical Steel Wire Structural Strand
A587-96(2005) Standard Specification for Electric-Resistance-Welded Low-Carbon Steel Pipe for the Chemical Industry
A588/A588M-05 Standard Specification for High-Strength Low-Alloy Structural Steel with 50 ksi [345 MPa] Minimum Yield Point to 4-in. [100-mm] Thick
A589/A589M-06 Standard Specification for Seamless and Welded Carbon Steel Water-Well Pipe
A592/A592M-04 Standard Specification for High-Strength Quenched and Tempered Low-Alloy Steel Forged Fittings and Parts for Pressure Vessels
A595/A595M-06 Standard Specification for Steel Tubes, Low-Carbon or High-Strength Low-Alloy, Tapered for Structural Use
A596/A596M-95(2004) Standard Test Method for Direct-Current Magnetic Properties of Materials Using the Ballistic Method and Ring Specimens
A597-87(2004) Standard Specification for Cast Tool Steel
A598/A598M-02 Standard Test Method for Magnetic Properties of Magnetic Amplifier Cores
A599/A599M-02 Standard Specification for Tin Mill Products, Electrolytic Tin-Coated, Cold-Rolled Sheet
A600-92a(2004) Standard Specification for Tool Steel High Speed
A601-05 Standard Specification for Electrolytic Manganese Metal
A602-94(2004) Standard Specification for Automotive Malleable Iron Castings
A603-98(2003) Standard Specification for Zinc-Coated Steel Structural Wire Rope
A604-93(2003) Standard Test Method for Macroetch Testing of Consumable Electrode Remelted Steel Bars and Billets
A606-04 Standard Specification for Steel, Sheet and Strip, High-Strength, Low-Alloy, Hot-Rolled and Cold-Rolled, with Improved Atmospheric Corrosion Resistance
A608/A608M-06 Standard Specification for Centrifugally Cast Iron-Chromium-Nickel High-Alloy Tubing for Pressure Application at High Temperature
A609/A609M-91(2002) Standard Practice for Castings, Carbon, Low-Alloy, and Martensitic Stainless Steel, Ultrasonic Examination Thereof
A610-79(2004) Standard Test Methods for Sampling and Testing Ferroalloys for Determination of Size
A612/A612M-03 Standard Specification for Pressure Vessel Plates, Carbon Steel, High Strength, for Moderate and Lower Temperature Service
A615/A615M-06a Standard Specification for Deformed and Plain Carbon-Steel Bars for Concrete Reinforcement
A618/A618M-04 Standard Specification for Hot-Formed Welded and Seamless High-Strength Low-Alloy Structural Tubing
A623-06a Standard Specification for Tin Mill Products, General Requirements
A623M-06a Standard Specification for Tin Mill Products, General Requirements [Metric]
A624/A624M-03 Standard Specification for Tin Mill Products, Electrolytic Tin Plate, Single Reduced
A625/A625M-03 Standard Specification for Tin Mill Products, Black Plate, Single Reduced
A626/A626M-03 Standard Specification for Tin Mill Products, Electrolytic Tin Plate, Double Reduced
A627-03 Standard Test Methods for Tool-Resisting Steel Bars, Flats, and Shapes for Detention and Correctional Facilities
做牛做马
第6楼2007/03/15
A630-03 Standard Test Methods for Determination of Tin Coating Weights for Electrolytic Tin Plate
A632-04 Standard Specification for Seamless and Welded Austenitic Stainless Steel Tubing (Small-Diameter) for General Service
A633/A633M-01(2006) Standard Specification for Normalized High-Strength Low-Alloy Structural Steel Plates
A635/A635M-06a Standard Specification for Steel, Sheet and Strip, Heavy-Thickness Coils, Hot-Rolled, Carbon, Structural, High-Strength Low-Alloy, and High-Strength Low-Alloy with Improved Formability, General Requirements for
A636-76(2004) Standard Specification for Nickel Oxide Sinter
A638/A638M-00(2004) Standard Specification for Precipitation Hardening Iron Base Superalloy Bars, Forgings, and Forging Stock for High-Temperature Service
A640-97(2002)e1 Standard Specification for Zinc-Coated Steel Strand for Messenger Support of Figure 8 Cable
A641/A641M-03 Standard Specification for Zinc-Coated (Galvanized) Carbon Steel Wire
A644-05 Standard Terminology Relating to Iron Castings
A645/A645M-05 Standard Specification for Pressure Vessel Plates, Five Percent Nickel Alloy Steel, Specially Heat Treated
A646/A646M-06 Standard Specification for Premium Quality Alloy Steel Blooms and Billets for Aircraft and Aerospace Forgings
A648-04a Standard Specification for Steel Wire, Hard Drawn for Prestressing Concrete Pipe
A649/A649M-04 Standard Specification for Forged Steel Rolls Used for Corrugating Paper Machinery
A650/A650M-03 Standard Specification for Tin Mill Products, Black Plate, Double Reduced
A653/A653M-06a Standard Specification for Steel Sheet, Zinc-Coated (Galvanized) or Zinc-Iron Alloy-Coated (Galvannealed) by the Hot-Dip Process
A656/A656M-05e1 Standard Specification for Hot-Rolled Structural Steel, High-Strength Low-Alloy Plate with Improved Formability
A657/A657M-03 Standard Specification for Tin Mill Products, Black Plate Electrolytic Chromium-Coated, Single and Double Reduced
A659/A659M-06 Standard Specification for Commercial Steel (CS), Sheet and Strip, Carbon (0.16 Maximum to 0.25 Maximum Percent), Hot-Rolled
A660-96(2005) Standard Specification for Centrifugally Cast Carbon Steel Pipe for High-Temperature Service
A662/A662M-03 Standard Specification for Pressure Vessel Plates, Carbon-Manganese-Silicon Steel, for Moderate and Lower Temperature Service
A663/A663M-89(2006) tandard Specification for Steel Bars, Carbon, Merchant Quality, Mechanical Properties
A664-06e1 Standard Practice for Identification of Standard Electrical Steel Grades in ASTM Specifications
A666-03 Standard Specification for Annealed or Cold-Worked Austenitic Stainless Steel Sheet, Strip, Plate, and Flat Bar
A667/A667M-87(2003) Standard Specification for Centrifugally Cast Dual Metal (Gray and White Cast Iron) Cylinders
A668/A668M-04 Standard Specification for Steel Forgings, Carbon and Alloy, for General Industrial Use
A671-06 Standard Specification for Electric-Fusion-Welded Steel Pipe for Atmospheric and Lower Temperatures
A672-06 Standard Specification for Electric-Fusion-Welded Steel Pipe for High-Pressure Service at Moderate Temperatures
A673/A673M-05a Standard Specification for Sampling Procedure for Impact Testing of Structural Steel
A674-05 Standard Practice for Polyethylene Encasement for Ductile Iron Pipe for Water or Other Liquids
A675/A675M-03e1 Standard Specification for Steel Bars, Carbon, Hot-Wrought, Special Quality, Mechanical Properties
A677-05e1 Standard Specification for Nonoriented Electrical Steel Fully Processed Types
A678/A678M-05 Standard Specification for Quenched-and-Tempered Carbon and High-Strength Low-Alloy Structural Steel Plates
A679/A679M-06 Standard Specification for Steel Wire, High Tensile Strength, Cold Drawn
A681-94(2004) Standard Specification for Tool Steels Alloy
A682/A682M-05 Standard Specification for Steel, Strip, High-Carbon, Cold-Rolled, General Requirements For
A683-05e1 Standard Specification for Nonoriented Electrical Steel, Semiprocessed Types
A684/A684M-06 Standard Specification for Steel, Strip, High-Carbon, Cold-Rolled
A686-92(2004) Standard Specification for Tool Steel, Carbon
做牛做马
第7楼2007/03/15
A688/A688M-04 Standard Specification for Welded Austenitic Stainless Steel Feedwater Heater Tubes
A689-97(2002) Standard Specification for Carbon and Alloy Steel Bars for Springs
A690/A690M-05 Standard Specification for High-Strength Low-Alloy Nickel, Copper, Phosphorus Steel H-Piles and Sheet Piling with Atmospheric Corrosion Resistance for Use in Marine Environments
A691-98(2002) Standard Specification for Carbon and Alloy Steel Pipe, Electric-Fusion-Welded for High-Pressure Service at High Temperatures
A693-06 Standard Specification for Precipitation-Hardening Stainless and Heat-Resisting Steel Plate, Sheet, and Strip
A694/A694M-03 Standard Specification for Carbon and Alloy Steel Forgings for Pipe Flanges, Fittings, Valves, and Parts for High-Pressure Transmission Service
A696-90a(2006) Standard Specification for Steel Bars, Carbon, Hot-Wrought or Cold-Finished, Special Quality, for Pressure Piping Components
A697/A697M-03 Standard Test Method for Alternating Current Magnetic Properties of Laminated Core Specimen Using Voltmeter-Ammeter-Wattmeter Methods
A698/A698M-02 Standard Test Method for Magnetic Shield Efficiency in Attenuating Alternating Magnetic Fields
A700-05 Standard Practices for Packaging, Marking, and Loading Methods for Steel Products for Shipment
A701-05 Standard Specification for Ferromanganese-Silicon
A702-89(2006) Standard Specification for Steel Fence Posts and Assemblies, Hot Wrought
A703/A703M-06 Standard Specification for Steel Castings, General Requirements, for Pressure-Containing Parts
A704/A704M-06 Standard Specification for Welded Steel Plain Bar or Rod Mats for Concrete Reinforcement
A705/A705M-95(2004) Standard Specification for Age-Hardening Stainless Steel Forgings
A706/A706M-06a Standard Specification for Low-Alloy Steel Deformed and Plain Bars for Concrete Reinforcement
A707/A707M-02 Standard Specification for Forged Carbon and Alloy Steel Flanges for Low-Temperature Service
A709/A709M-06a Standard Specification for Structural Steel for Bridges
A710/A710M-02 Standard Specification for Precipitation-Strengthened Low-Carbon Nickel-Copper-Chromium-Molybdenum-Columbium Alloy Structural Steel Plates
A711-04 Standard Specification for Steel Forging Stock
A712-97(2002) Standard Test Method for Electrical Resistivity of Soft Magnetic Alloys
A713-04 Standard Specification for Steel Wire, High-Carbon Spring, for Heat-Treated Components
A714-99(2003) Standard Specification for High-Strength Low-Alloy Welded and Seamless Steel Pipe
A716-03 Standard Specification for Ductile Iron Culvert Pipe
A717/A717M-06 Standard Test Method for Surface Insulation Resistivity of Single-Strip Specimens
A719/A719M-02 Standard Test Method for Lamination Factor of Magnetic Materials
A720/A720M-02 Standard Test Method for Ductility of Nonoriented Electrical Steel
A721/A721M-02 Standard Test Method for Ductility of Oriented Electrical Steel
A722/A722M-06 Standard Specification for Uncoated High-Strength Steel Bars for Prestressing Concrete
A723/A723M-02 Standard Specification for Alloy Steel Forgings for High-Strength Pressure Component Application
A724/A724M-04 Standard Specification for Pressure Vessel Plates, Carbon-Manganese-Silicon Steel, Quenched and Tempered, for Welded Layered Pressure Vessels
A726-05 Standard Specification for Cold-Rolled Magnetic Lamination Quality Steel, Semiprocessed Types
A727/A727M-02 Standard Specification for Carbon Steel Forgings for Piping Components with Inherent Notch Toughness
A729/A729M-06 Standard Specification for Alloy Steel Axles, Heat-Treated, for Mass Transit and Electric Railway Service
A732/A732M-05 Standard Specification for Castings, Investment, Carbon and Low Alloy Steel for General Application, and Cobalt Alloy for High Strength at Elevated Temperatures
A733-03 Standard Specification for Welded and Seamless Carbon Steel and Austenitic Stainless Steel Pipe Nipples
A734/A734M-87a(2003) Standard Specification for Pressure Vessel Plates, Alloy Steel and High-Strength Low-Alloy Steel, Quenched-and-Tempered
A735/A735M-03 Standard Specification for Pressure Vessel Plates, Low-Carbon Manganese-Molybdenum-Columbium Alloy Steel, for Moderate and Lower Temperature Service
A736/A736M-03 Standard Specification for Pressure Vessel Plates, Low-Carbon Age-Hardening Nickel-Copper-Chromium-Molybdenum-Columbium and Nickel-Copper-Manganese-Molybdenum-Columbium Alloy Steel
A737/A737M-99(2004) Standard Specification for Pressure Vessel Plates, High-Strength, Low-Alloy Steel
做牛做马
第8楼2007/03/15
A738/A738M-05 Standard Specification for Pressure Vessel Plates, Heat-Treated, Carbon-Manganese-Silicon Steel, for Moderate and Lower Temperature Service
A739-90a(2006) Standard Specification for Steel Bars, Alloy, Hot-Wrought, for Elevated Temperature or Pressure-Containing Parts, or Both
A740-98(2003) Standard Specification for Hardware Cloth (Woven or Welded Galvanized Steel Wire Fabric)
A741-98(2003) Standard Specification for Zinc-Coated Steel Wire Rope and Fittings for Highway Guardrail
A742/A742M-03 Standard Specification for Steel Sheet, Metallic Coated and Polymer Precoated for Corrugated Steel Pipe
A743/A743M-06 Standard Specification for Castings, Iron-Chromium, Iron-Chromium-Nickel, Corrosion Resistant, for General Application
A744/A744M-06 Standard Specification for Castings, Iron-Chromium-Nickel, Corrosion Resistant, for Severe Service
A745/A745M-94(2003) Standard Practice for Ultrasonic Examination of Austenitic Steel Forgings
A746-03 Standard Specification for Ductile Iron Gravity Sewer Pipe
A747/A747M-04 Standard Specification for Steel Castings, Stainless, Precipitation Hardening
A748/A748M-87(2003) Standard Specification for Statically Cast Chilled White Iron-Gray Iron Dual Metal Rolls for Pressure Vessel Use
A749/A749M-97(2002) Standard Specification for Steel, Strip, Carbon and High-Strength, Low-Alloy, Hot-Rolled, General Requirements for
A751-01(2006) Standard Test Methods, Practices, and Terminology for Chemical Analysis of Steel Products
A752-04 Standard Specification for General Requirements for Wire Rods and Coarse Round Wire, Alloy Steel
A752M-04 Standard Specification for General Requirements for Wire Rods and Coarse Round Wire, Alloy Steel [Metric]
A753-02 Standard Specification for Wrought Nickel-Iron Soft Magnetic Alloys (UNS K94490, K94840, N14076, N14080)
A754/A754M-06 Standard Test Method for Coating Weight (Mass) of Metallic Coatings on Steel by X-Ray Fluorescence
A755/A755M-03 Standard Specification for Steel Sheet, Metallic Coated by the Hot-Dip Process and Prepainted by the Coil-Coating Process for Exterior Exposed Building Products
A756-94(2001) Standard Specification for Stainless Anti-Friction Bearing Steel
A757/A757M-00(2004) Standard Specification for Steel Castings, Ferritic and Martensitic, for Pressure-Containing and Other Applications, for Low-Temperature Service
A758/A758M-00(2005) Standard Specification for Wrought-Carbon Steel Butt-Welding Piping Fittings with Improved Notch Toughness
A759-00(2005) Standard Specification for Carbon Steel Crane Rails
A760/A760M-06 Standard Specification for Corrugated Steel Pipe, Metallic-Coated for Sewers and Drains
A761/A761M-04 Standard Specification for Corrugated Steel Structural Plate, Zinc-Coated, for Field-Bolted Pipe, Pipe-Arches, and Arches
A762/A762M-00 Standard Specification for Corrugated Steel Pipe, Polymer Precoated for Sewers and Drains
A763-93(2004) Standard Practices for Detecting Susceptibility to Intergranular Attack in Ferritic Stainless Steels
A764-95(2001) Standard Specification for Metallic Coated Carbon Steel Wire, Coated at Size and Drawn to Size for Mechanical Springs
A765/A765M-04 Standard Specification for Carbon Steel and Low-Alloy Steel Pressure-Vessel-Component Forgings with Mandatory Toughness Requirements
A767/A767M-05 Standard Specification for Zinc-Coated (Galvanized) Steel Bars for Concrete Reinforcement
A768/A768M-05 Standard Specification for Vacuum-Treated 12 % Chromium Alloy Steel Forgings for Turbine Rotors and Shafts
A769/A769M-05 Carbon and High-Strength Electric Resistance Forge-Welded Steel Structural Shapes
A770/A770M-03 Standard Specification for Through-Thickness Tension Testing of Steel Plates for Special Applications
A772/A772M-00(2005) Standard Test Method for ac Magnetic Permeability of Materials Using Sinusoidal Current
A773/A773M-01 Standard Test Method for dc Magnetic Properties of Materials Using Ring and Permeameter Procedures with dc Electronic Hysteresigraphs
A774/A774M-06 Standard Specification for As-Welded Wrought Austenitic Stainless Steel Fittings for General Corrosive Service at Low and Moderate Temperatures
A775/A775M-06 Standard Specification for Epoxy-Coated Steel Reinforcing Bars
A778-01 Standard Specification for Welded, Unannealed Austenitic Stainless Steel Tubular Products
A779/A779M-05 Standard Specification for Steel Strand, Seven-Wire, Uncoated, Compacted, Stress-Relieved for Prestressed Concrete
A780-01(2006) Standard Practice for Repair of Damaged and Uncoated Areas of Hot-Dip Galvanized Coatings
做牛做马
第9楼2007/03/15
A781/A781M-06 Standard Specification for Castings, Steel and Alloy, Common Requirements, for General Industrial Use
A782/A782M-06 Standard Specification for Pressure-Vessel Plates, Quenched-and-Tempered, Manganese-Chromium-Molybdenum-Silicon Zirconium Alloy Steel
A786/A786M-05 Standard Specification for Hot-Rolled Carbon, Low-Alloy, High-Strength Low-Alloy, and Alloy Steel Floor Plates
A787-05 Standard Specification for Electric-Resistance-Welded Metallic-Coated Carbon Steel Mechanical Tubing
A788/A788M-06 Standard Specification for Steel Forgings, General Requirements
A789/A789M-05b Standard Specification for Seamless and Welded Ferritic/Austenitic Stainless Steel Tubing for General Service
A790/A790M-05b Standard Specification for Seamless and Welded Ferritic/Austenitic Stainless Steel Pipe
A792/A792M-06a Standard Specification for Steel Sheet, 55 % Aluminum-Zinc Alloy-Coated by the Hot-Dip Process
A793-96(2001) Standard Specification for Rolled Floor Plate, Stainless Steel
A794-06 Standard Specification for Commercial Steel (CS), Sheet, Carbon (0.16 % Maximum to 0.25 % Maximum), Cold-Rolled
A795/A795M-04 Standard Specification for Black and Hot-Dipped Zinc-Coated (Galvanized) Welded and Seamless Steel Pipe for Fire Protection Use
A796/A796M-06 Standard Practice for Structural Design of Corrugated Steel Pipe, Pipe-Arches, and Arches for Storm and Sanitary Sewers and Other Buried Applications
A798/A798M-01 Standard Practice for Installing Factory-Made Corrugated Steel Pipe for Sewers and Other Applications
A799/A799M-04 Standard Practice for Steel Castings, Stainless, Instrument Calibration, for Estimating Ferrite Content
A800/A800M-01(2006) Standard Practice for Steel Casting, Austenitic Alloy, Estimating Ferrite Content Thereof
A801-04 Standard Specification for Wrought Iron-Cobalt High Magnetic Saturation Alloys (UNS R30005 and K92650)
A802/A802M-95(2006) Standard Practice for Steel Castings, Surface Acceptance Standards, Visual Examination
A803/A803M-03 Standard Specification for Welded Ferritic Stainless Steel Feedwater Heater Tubes
A804/A804M-04 Standard Test Methods for Alternating-Current Magnetic Properties of Materials at Power Frequencies Using Sheet-Type Test Specimens
A805-93(2002) Standard Specification for Steel, Flat Wire, Carbon, Cold-Rolled
A807/A807M-02e1 Standard Practice for Installing Corrugated Steel Structural Plate Pipe for Sewers and Other Applications
A809-03 Standard Specification for Aluminum-Coated (Aluminized) Carbon Steel Wire
A810-01 Standard Specification for Zinc-Coated (Galvanized) Steel Pipe Winding Mesh
A811-03 Standard Specification for Soft Magnetic Iron Parts Fabricated by Powder Metallurgy (P/M) Techniques
A813/A813M-01(2005) Standard Specification for Single- or Double-Welded Austenitic Stainless Steel Pipe
A814/A814M-05 Standard Specification for Cold-Worked Welded Austenitic Stainless Steel Pipe
A815/A815M-04 Standard Specification for Wrought Ferritic, Ferritic/Austenitic, and Martensitic Stainless Steel Piping Fittings
A817-03 Standard Specification for Metallic-Coated Steel Wire for Chain-Link Fence Fabric and Marcelled Tension Wire
A818-06 Standard Specification for Coppered Carbon Steel Wire
A820/A820M-06 Standard Specification for Steel Fibers for Fiber-Reinforced Concrete
A821/A821M-05 Standard Specification for Steel Wire, Hard Drawn for Prestressing Concrete Tanks
A822/A822M-04 Standard Specification for Seamless Cold-Drawn Carbon Steel Tubing for Hydraulic System Service
A823-99(2003) Standard Specification for Statically Cast Permanent Mold Gray Iron Castings
A824-01 Standard Specification for Metallic-Coated Steel Marcelled Tension Wire for Use With Chain Link Fence
A827/A827M-02 Standard Specification for Plates, Carbon Steel, for Forging and Similar Applications
A829/A829M-06 Standard Specification for Alloy Structural Steel Plates
A830/A830M-06 Standard Specification for Plates, Carbon Steel, Structural Quality, Furnished to Chemical Composition Requirements
A832/A832M-06 Standard Specification for Pressure Vessel Plates, Alloy Steel, Chromium-Molybdenum-Vanadium
A833-84(2001) Standard Practice for Indentation Hardness of Metallic Materials by Comparison Hardness Testers
A834-95(2006) Standard Specification for Common Requirements for Iron Castings for General Industrial Use
A835/A835M-84(2005) Standard Specification for Sizes of Ferroalloys and Alloy Additives
A836/A836M-02 Standard Specification for Titanium-Stabilized Carbon Steel Forgings for Glass-Lined Piping and Pressure Vessel Service
A837/A837M-06 Standard Specification for Steel Forgings, Alloy, for Carburizing Applications
A838-02 Standard Specification for Free-Machining Ferritic Stainless Soft Magnetic Alloy Bar for Relay Applications
A839-02 Standard Specification for Iron-Phosphorus Powder Metallurgy (P/M) Parts for Soft Magnetic Applications
A840-06 Standard Specification for Fully Processed Magnetic Lamination Steel
A841/A841M-03a Standard Specification for Steel Plates for Pressure Vessels, Produced by Thermo-Mechanical Control Process (TMCP)
A842-85(2004) Standard Specification for Compacted Graphite Iron Castings
A844/A844M-04 Standard Specification for Steel Plates, 9 % Nickel Alloy, for Pressure Vessels, Produced by the Direct-Quenching Process
A847/A847M-05 Standard Specification for Cold-Formed Welded and Seamless High-Strength, Low-Alloy Structural Tubing with Improved Atmospheric Corrosion Resistance
A848-01(2006) Standard Specification for Low-Carbon Magnetic Iron
A849-00(2005) Standard Specification for Post-Applied Coatings, Pavings, and Linings for Corrugated Steel Sewer and Drainage Pipe
A852/A852M-03 Standard Specification for Quenched and Tempered Low-Alloy Structural Steel Plate with 70 ksi [485 MPa] Minimum Yield Strength to 4 in. [100 mm] Thick
A853-04 Standard Specification for Steel Wire, Carbon, for General Use
A854/A854M-98(2003) Standard Specification for Metallic-Coated Steel Smooth High-Tensile Fence and Trellis Wire
A855/A855M-03 Standard Specification for Zinc-5% Aluminum-Mischmetal Alloy-Coated Steel Wire Strand
做牛做马
第10楼2007/03/15
A856/A856M-03 Standard Specification for Zinc-5% Aluminum-Mischmetal Alloy-Coated Carbon Steel Wire
A857/A857M-05 Standard Specification for Steel Sheet Piling, Cold Formed, Light Gage
A858/A858M-06 Standard Specification for Heat-Treated Carbon Steel Fittings for Low-Temperature and Corrosive Service
A859/A859M-04 Standard Specification for Age-Hardening Alloy Steel Forgings for Pressure Vessel Components
A860/A860M-00(2005) Standard Specification for Wrought High-Strength Low-Alloy Steel Butt-Welding Fittings
A861-04 Standard Specification for High-Silicon Iron Pipe and Fittings
A862/A862M-98(2003) Standard Practice for Application of Asphalt Coatings to Corrugated Steel Sewer and Drainage Pipe
A865/A865M-06 Standard Specification for Threaded Couplings, Steel, Black or Zinc-Coated (Galvanized) Welded or Seamless, for Use in Steel Pipe Joints
A866-01 Standard Specification for Medium Carbon Anti-Friction Bearing Steel
A867-03 Standard Specification for Iron-Silicon Relay Steels
A871/A871M-03 Standard Specification for High-Strength Low-Alloy Structural Steel Plate With Atmospheric Corrosion Resistance
A872/A872M-07 Standard Specification for Centrifugally Cast Ferritic/Austenitic Stainless Steel Pipe for Corrosive Environments
A874/A874M-98(2004) Standard Specification for Ferritic Ductile Iron Castings Suitable for Low-Temperature Service
A875/A875M-06 Standard Specification for Steel Sheet, Zinc-5 % Aluminum Alloy-Coated by the Hot-Dip Process
A876-03 Standard Specification for Flat-Rolled, Grain-Oriented, Silicon-Iron, Electrical Steel, Fully Processed Types
A877/A877M-05 Standard Specification for Steel Wire, Chromium-Silicon Alloy Valve Spring Quality
A878/A878M-05 Standard Specification for Steel Wire, Modified Chromium Vanadium Valve Spring Quality
A879/A879M-06 Standard Specification for Steel Sheet, Zinc Coated by the Electrolytic Process for Applications Requiring Designation of the Coating Mass on Each Surface
A881/A881M-05 Standard Specification for Steel Wire, Deformed, Stress-Relieved or Low-Relaxation for Prestressed Concrete Railroad Ties
A882/A882M-04a Standard Specification for Filled Epoxy-Coated Seven-Wire Prestressing Steel Strand
A884/A884M-06 Standard Specification for Epoxy-Coated Steel Wire and Welded Wire Reinforcement
A886/A886M-05 Standard Specification for Steel Strand, Indented, Seven-Wire Stress-Relieved for Prestressed Concrete
A887-89(2004) Standard Specification for Borated Stainless Steel Plate, Sheet, and Strip for Nuclear Application
A888-07a Standard Specification for Hubless Cast Iron Soil Pipe and Fittings for Sanitary and Storm Drain, Waste, and Vent Piping Applications
A889/A889M-03 Standard Test Method for Alternating-Current Magnetic Properties of Materials at Low Inductions Using the Wattmeter-Varmeter-Ammeter-Voltmeter Method and 25-cm (250-mm) Epstein Frame
A890/A890M-99(2003) Standard Specification for Castings, Iron-Chromium-Nickel-Molybdenum Corrosion-Resistant, Duplex (Austenitic/Ferritic) for General Application
A891-98(2003) Standard Specification for Precipitation Hardening Iron Base Superalloy Forgings for Turbine Rotor Disks and Wheels
A892-06 Standard Guide for Defining and Rating the Microstructure of High Carbon Bearing Steels
A893/A893M-03 Standard Test Method for Complex Dielectric Constant of Nonmetallic Magnetic Materials at Microwave Frequencies
A894/A894M-00(2005) Standard Test Method for Saturation Magnetization or Induction of Nonmetallic Magnetic Materials
A895-89(2004) Standard Specification for Free-Machining Stainless Steel Plate, Sheet, and Strip
A896-89(2004) Standard Practice for Conducting Case Studies on Galvanized Structures
A897/A897M-06 Standard Specification for Austempered Ductile Iron Castings
A898/A898M-91(2001) Standard Specification for Straight Beam Ultrasonic Examination of Rolled Steel Structural Shapes
