2000KN疲劳试验机
  • Amsler测试技术
    2022/03/30
试验机/硬度计
  • Machine UP 2000 PK-4
    Vertical, servo-hydraulic testing machine for static and dynamic applications
    Range of application:
    Precise, reproducible, demanding inspection tasks
    Material and component testing
    research and development
    quality inspection
    Test facilities:
    structural engineering, building construction, civil engineering and bridge building
    high-performance materials, prefabricated constructions
    innovative load-bearing structures with different materials (e.g. hybrid constructions)
    Application:
    for a variety of different applications due to the flexible design
    universal static, quasistatic, dynamic TENSION, COMPRESSION- and BENDING TEST according to accessories
    vertical and horizontal load arrangement is possible
    Fatigue and fracture mechanics tests are selected and offered from the wide range of possibilities for this series, depending on the customer's applications and test procedures.
  • 沧海青城
    第2楼2022/05/19
    试验精度和范围是怎样的呢
