ELECTRICAL SPECIFICATIONS | |||||||||
Model No (Single Output) | AJC-3.3S | AJC-5S | AJC-9S | AJC-12S | AJC-15S | AJC-24S | |||
Max output wattage (W) | 26.4W | 40W | 40W | 40W | 40W | 40W | |||
Output | Voltage (V.DC | 3.3V | 5V | 9V | 12V | 15V | 24V | ||
Current (mA)max | 8000 | 8000 | 4444 | 3333 | 2666 | 1667 | |||
Voltage set accurac | ±3% | ±2% | ±2% | ±2% | ±2% | ±2% | |||
Line regulation (typ.) | 0.5% | 0.5% | 0.5% | 0.5% | 0.5% | 0.5% | |||
Load regulation (1-100%)(typ. | 1% | 1% | 1% | 1% | 1% | 1% | |||
Minimum load | 1% | 1% | 1% | 1% | 1% | 1% | |||
Maximum Capacitive Load (at 230VAC) | 60000 uF | 40000 uF | 7200 uF | 8600 uF | 6600 uF | 1400 uF | |||
Eficiency(typ | 74% | 81% | 82% | 84% | 83% | 83% | |||
Model No (Dual Output) | AJC-5D | AJC-12D | AJC-15D | ||||||
Max output wattage (W) | 40W | 40W | 40W | ||||||
Output | Output 1 | Output 2 | Output 1 | Output 2 | Output 1 | Output 2 | |||
Voltage V.DC. | +5V | -5V | +12V | -12V | +15V | -15V | |||
Current (mA)max | 4000 | 4000 | 1666 | 1666 | 1333 | 1333 | |||
Voltage set accuracy | ±2% | ±2% | ±2% | ||||||
Line regulation (typ.) | 0.5% | 0.5% | 0.5% | ||||||
Load regulation (10-100%)(typ.) | 1%(symmetric load) | 1%(symmetric load) | 1%(symmetric load | ||||||
Cross regulation (15-100%)(typ. | ±5% | ±5% | ±5% | ||||||
Minimum load | 10% | 10% | 10% | ||||||
Maximum Capacitive Load (at 230VAC) | ±12000 uF | ±4400 uF | ±1000 uF | ||||||
Efficlency (typ | 81% | 83% | 83% | ||||||
Model No. (Dual Output) | AJC-5S12S | AJC-5S24S | |||||||
Max output wattage (W) | 40W | 40W | |||||||
Output | Output 1 | Output 2 | Qutput | Output 2 | |||||
Voltage (V.DC.) | 5V | 12V | 5V | 24V | |||||
Current (mA)max | 5000 | 1250 | 5000 | 625 | |||||
Voltage set accuracy | ±3% | ±5% | ±3% | ±5% | |||||
Line regulation (typ. | 0.5% | 5% | 0.5% | 5% | |||||
Load regulation (25-100%)(typ.) | 2%(symmetric load) | 6%(symmetric oad) | 2%(symmetric load) | 6%(symmetric load) | |||||
Cross regulation(25-100%)(typ.) | ±1% | ±7% | ±1% | ±7% | |||||
Minimum load | 25% | 25% | |||||||
Maximum Capacitive Load (at 230VAC | 10000 uF | 470 uF | 10000 uF | 400 uF | |||||
EMiciency(typ. | 82% | 82% |
Model No. (Triple Output) | AJC-5S12D | AJC-5S15D | |||||
Output | Output 2 | Output 3 | Output 1 | Output 2 | Output 3 | ||
Voltage (V.DC.) | +12 | -12 | 5 | +15 | -15 | ||
Current (mA)ma | 600 | 600 | 5000 | 500 | 500 | ||
Voltage set accurac | ±5% | ±3% | ±5% | ||||
Line regulation (typ. | 5% | 0.5% | 5% | ||||
Load regulation (25-100%)(typ. (symmetric load | 7% | 3% | 7% | ||||
Cross regulation (typ. | ±10% | ±3% | ±10% | ||||
Maximum Capacitive Load | 780 uF | 10000 uF | 900 uF | ||||
Efficiency(typ | 80% | 81% |
