离子色谱法同时测定药品中巴比妥酸和5种无机阴离子的研究
离子色谱(IC)
  • 离子色谱法同时测定药品中巴比妥酸和5种无机阴离子的研究
    黄选忠
    (湖北兴山县疾病预防控制中心,湖北兴山,443700)
    摘要 建立离子色谱-抑制电导检测法同时测定巴比妥酸和F-、Cl-、NO3-、H2PO4-和SO42-等5种无机阴离子的新方法。以SH-AP-2型阴离子交换柱为分离柱,以6.0mmol/LNa2CO3-1.0mmol/LNaHCO3溶液为淋洗液,流量为0.80 mL/min,采用等度洗脱的方式可将巴比妥酸与F-、Cl-、NO3-、H2PO4-和SO42-等5种常见无机阴离子完全分离,巴比妥酸和SO42-,NO3-、Cl-和H2PO4-,F-的峰面积与其质量浓度分别在0.10~20.0mg/L、0.05~10.0mg/L和0.04~8.0mg/L范围内呈良好的线性关系,相关系数r在0.9994~0.9999,方法应用于巴比妥、苯巴比妥和维生素B12等药品中巴比妥酸和F-、Cl-、NO3-、H2PO4-和SO42-等无机阴离子的同时测定,加标回收率在92.6%~104.0%,5次平行测定结果的相对标准偏差(RSD)在1.06%~3.89%,最低检出限在0.01mg/L~0.06mg/L,方法回收率较高、重现性良好,操作简便快速,可用于巴比妥、苯巴比妥和维生素B12等样品中巴比妥酸和F-、Cl-、NO3-、H2PO4-和SO42-无机阴离子的定量分析。
    关键词 离子色谱法;巴比妥酸无机阴离子;巴比妥;苯巴比妥;维生素B12
    中图分类号:O652.63 文献标识码: 文章编号:
    Ion chromatography for the simultaneous determination of barbituric acid
    and five inorganic anions in pharmaceutical products
    HUANG Xuanzhong
    (Prevention and Health Protection Centre of Hubei Xingshan County,HubeiXingshan 443700, China)
    A new method for the simultaneous determination of barbituric acid and F-, Cl-, NO3-, H2PO4- and SO42- by ion chromatography-suppressed conductivity detection was established. With SH-AP-2 anion exchange column as the separation column and 6.0mmol/LNa2CO3-1.0mmol/LNaHCO3 solution as the eluent, the flow rate was 0.80 mL/min, barbituric acid and five common inorganic anions such as F-, Cl-, NO3-, H2PO4- and SO42- were completely separated by isocratic elution, The peak area of barbituric acid and SO42- , NO3-, Cl- and H2PO4-, F- showed a good linear relationship with their mass concentrations in the range of 0.1020.0mg/L, 0.0510.0mg/L and 0.048.0mg/L , and the correlation coefficient r was 0.99940.9999, respectively.The method was applied to the simultaneous determination of barbituric acid and inorganic anions such as F-, Cl-, NO3-, H2PO4- and SO42- in barbiturates, phenobarbital and vitaminB12 drugs, with a recovery rate of 92.6%104.0%, a relative standard deviation (RSD) of 5 parallel measurement results of 1.06%3.89%, and the minimum detection limit was 0.01mg/L0.06mg/L. It can be used for the quantitative analysis of barbituric acid and inorganic anions such as F-, Cl-, NO3-, H2PO4- and SO42- in samples such as barbiturates, phenobarbital and vitaminB12.
    Key words ion chromatography;barbituric acid;Inorganic anions;barbiturates;phenobarbital;vitaminB12
    巴比妥酸(BA)是合成巴比妥、苯巴比妥等镇静催眠药和维生素B12等药品的中间体[1],在这些合成药品中可能残留有微量的BA而影响品质,F-、NO3-、H2PO4-等无机阴离子过量摄入会影响人体健康,因此监测巴比妥、苯巴比妥和维生素B12等药品中微量BA和F-、NO3-、H2PO4-等无机阴离子含量对保障用药安全具有重要意义。目前测定药品中微量BA的方法已报道的有化学发光法[2]和分光光度法[3],其中,化学发光法需要专用仪器,而分光光度法则灵敏度偏低。离子色谱法目前已成为测定无机阴离子的常用方法,已广泛应用于药品中无机阴离子的同时测定[4-10]。本实验研究用SH-AP-2型阴离子交换柱和CIC-100型色谱仪同时测定巴比妥等药品中的BA和F-、Cl-、NO3-、H2PO4-和SO42-等5种无机阴离子的色谱条件和可行性,结果表明,以SH-AP-2型阴离子交换柱为分离柱、6.0mmol/LNa2CO3-1.0mmol/LNaHCO3溶液为淋洗液,流量为0.80ml/min,采用等度洗脱的方式可使BA和F-、Cl-、NO3-、H2PO4-和SO42-等5种无机阴离子完全分离,且BA和SO42-,NO3-、Cl-和H2PO4-,F-的峰面积与其质量浓度分别在0.10~20.0mg/L、0.05~10.0mg/L和0.04~8.0mg/L范围内呈良好的线性关系,相关系数r≥0.9994,方法应用于巴比妥、苯巴比妥和维生素B12等样品中F-、Cl-、NO3-、BA、H2PO4-和SO42-的同时测定, 加标回收率分别为99.2%~100.9%、101.0%~103.8%、96.1%~103.0%、92.6%~104.0%、94.6%~101.9%和98.6%~101.0%,5次平行测定结果的RSD分别为1.23%~2.38%、1.15%~1.89%、1.06%~2.11%、1.11%~3.89%、2.05%~3.66%和1.09%~3.05%,按3倍信噪比(3N/b)计,最低检出限在0.01mg/L~0.06mg/L,方法适用于巴比妥、苯巴比妥和维生素B12等样品中F-、Cl-、NO3-、BA、H2PO4-和SO42-的同时测定。
    1 实验部分
    1.1 主要仪器与试剂
    离子色谱仪:CIC-100,青岛盛瀚色谱公司。抑制器:SHY-2型自再生抑制器,青岛盛瀚色谱公司。
    定量环体积:25μL;自动进样器:SHA—15型,青岛盛瀚色谱公司。0.45μm滤膜过滤器:13 mm,青岛盛瀚色谱公司。
    巴比妥酸(C4H4N2O3·2H2O):分析纯((含量98.5%)),国药集团化学试剂有限公司。
    BA标准溶液:1000mg/L,称取0.1301g巴比妥酸,溶解于高纯水,定容至100ml容量瓶。
    磷酸二氢钾、溴化钾:分析纯,国药集团化学试剂有限公司。
    H2PO4-和Br-标准溶液:1000 mg/L,按照文献[11]配制。
    NO3-、F-、Cl-、SO42-标准溶液:质量浓度均为1000 mg/L,编号分别为GBW(E)080264、GBW(E)080549、GBW(E)080268、GBW(E)080266;NO2-标准溶液:质量浓度为100 mg/L,编号为GBW(E)080223,北京中国计量科学研究院。
    无水碳酸钠、碳酸氢钠:分析纯,国药集团化学试剂有限公司。
    实验所用其它试剂均为AR级。
    实验用水为高纯水(电阻率为18.2ΜΩ·cm)。
    1.2 仪器工作条件
    色谱分离柱:SH-AP-2型阴离子交换柱(250×4.0mm i.d,青岛盛瀚色谱公司,批号:2004005);保护柱:SH-AP-2型保护柱(50×4.0mm i.d,青岛盛瀚色谱公司,批号:G200023)。淋洗液:6.0mmol/LNa2CO3-1.0mmol/LNaHCO3溶液,流量为0.80ml/min;柱箱温度:35℃;电流:75mA;检测器:电导检测器;自动进样器:全定量环取样,取样后清洗(每针之间),置换量70μL,取样量25μL,扎针深度4mm。
    1.3 实验方法
    1.3.1 标准溶液配制
    BA和F-、Cl-、NO3-、H2PO4-和SO42-混合标准应用液:临用前将各种标准溶液逐级稀释成含5.0mg/L的BA和SO42-、2.50mg/L的Cl-、NO3-、H2PO4-和2.0mg/L的F-(A液)和50.0mg/L的BA和SO42-、25.0mg/L的Cl-、NO3-、H2PO4-和20.0mg/L的F-(B液)标准应用液。
    取上述混合标准应用液A液0.20、1.00mL及B液0.20、0.40、1.0、2.0、4.0mL于7只10mL容量瓶中加纯水至刻度,混匀,配制成含BA和SO42-均为0.10、0.50、1.00、2.00、5.00、10.00、20.00mg/L,含Cl-、NO3-、H2PO4-均为0.05、0.25、0.50、1.00、2.50、5.00、10.00mg/L和含F-为0.04、0.20、0.40、0.80、2.00、4.00、8.00mg/L的系列标准工作溶液。
    1.3.2标准曲线绘制
    取1.3.1制备的系列标准工作溶液,各管1.5mL于样品瓶中,启动自动进样器进样,分别测定各组分的峰面积,以各组分的峰面积(y)为纵坐标,以色谱峰面积对应的组分质量浓度(x)为横坐标,绘制工作曲线。
    1.3.3 样品处理
    称取巴比妥0.250g加5mL无水乙醇溶解后,用高纯水定容至100ml,取该样液用高纯水稀释1倍并经0.45μm滤膜过滤后供测试,样品测试液中巴比妥的质量浓度为1250mg/L。
    取苯巴比妥片(30mg苯巴比妥/片)5片研碎加10mL无水乙醇充分研磨溶解后,用高纯水定容至100ml,滤去不溶物,滤液用高纯水稀释1倍并经0.45μm滤膜过滤后供测试,样品测试液中苯巴比妥的质量浓度为750mg/L。
    维生素B12片40片(含维生素B12约1000μg)用高纯水洗去表面糖衣后,加高纯水充分研磨溶解并定容至100ml,滤去不溶物,滤液0.45μm滤膜过滤后供测试,样品测试液中维生素B12的质量浓度为10mg/L。
    1.3.4样品测定
    取1.3.3的样品测试液1.5ml于样品瓶中,启动自动进样器进样测定各组分的峰面积,以标准曲线法定量,同时进行加标回收试验。
    2 结果与讨论
    2.1 色谱条件的选择
    2.1.1 淋洗液的选择
    试验分别以5.0mmol/L、6.0mmol/L、8.0mmol/L和10.0mmol/LNa2CO3溶液为淋洗液,考察了SH-AP-2型柱对BA和F-、Cl-、NO3-、H2PO4-和SO42-等常见阴离子的分离情况,结果表明,当Na2CO3溶液超过6.0mmol/L时,H2PO4-和SO42-二者合并为一个峰,这与文献[12]报道的情况相似,因此要将前述6种组分完全分离,不宜以单纯Na2CO3溶液为淋洗液,应以Na2CO3/NaHCO3混合溶液为淋洗液, Na2CO3与NaHCO3溶液浓度配比试验结果见表1,从表1可见,随着淋洗液中NaHCO3浓度的增加,NO3-的峰分离度(R)逐渐降低,BA的峰分离度则无明显的改变,而F-、Cl-和H2PO4-的峰分离度逐渐增加,为使NO3-与H2PO4-均有适宜的峰分离度,本试验以6.0mmol/LNa2CO3-1.0mmol/LNaHCO3溶液为淋洗液,在此淋洗条件下F-、Cl-、NO3-、BA、H2PO4-和SO42-的分离色谱图见图1。
    表1 Na2CO3与NaHCO3不同配比对各组分峰分离度(R)的影响(流量0.80 ml/min,柱箱温度35℃)
    组分
    Na2CO3+NaHCO3(mmol/L)
    6.0+0
    6.0+0.9
    6.0+1.0
    6.0+1.1
    6.0+2
    6.0+3.0
    F-
    2.90
    3.05
    3.06
    3.07
    3.15
    3.36
    Cl-
    5.74
    6.05
    6.06
    6.07
    6.45
    6.63
    NO3-
    2.02
    1.61
    1.53
    1.54
    1.27
    1.08
    BA
    3.97
    3.75
    3.57
    3.48
    3.55
    3.16
    H2PO4
    二者合并为一个峰
    1.47
    1.63
    1.62
    2.27
    2.88
    SO42-
    2.1.2 淋洗液流量的影响
    考察了淋洗液流量分别为0.70、0.80和0.90 mL/min时各组分的分离情况,试验结果见表2,从表2
    图1 F-、Cl-、NO3-、BA、H2PO4-和SO42-分离效果图
    可见,随着淋洗液流量的升高,各组分的保留时间(T)逐渐缩短,峰分离度(R)逐渐减小(NO3-和H2PO4-除外),
    表2 淋洗液流量的影响(6.0mmol/LNa2CO3-1.0mmol/LNaHCO3溶液,柱箱温度35℃)
    组分
    0.70ml/min
    0.80ml/min
    0.90ml/min
    T/min
    R
    峰面积
    T/min
    R
    峰面积
    T/min
    R
    峰面积
    F-
    5.955
    3.19
    836046
    5.212
    3.08
    735031
    4.666
    3.02
    672656
    Cl-
    8.155
    6.33
    883680
    7.137
    6.14
    775756
    6.397
    6.05
    695800
    NO3-
    12.156
    1.43
    940957
    10.633
    1.52
    854040
    9.536
    1.38
    730092
    BA
    13.299
    3.60
    521413
    11.657
    3.55
    456506
    10.440
    3.53
    403955
    H2PO4
    16.672
    1.89
    385185
    14.578
    1.67
    311122
    13.066
    1.83
    300895
    SO42-
    18.392
    1314478
    16.036
    1151063
    14.388
    1016420
    峰面积逐渐降低,为使组分有较短的保留时间、较高的峰分离度(≧1.5)和检测灵敏度、系统有较低的压力,综合考虑,本试验确定的淋洗液流量为0.80mL/min。
    2.1.3 柱箱温度的选择
    考察了柱箱温度为30℃、35℃、40℃时各组分的分离效果,结果见表3,从表3可见,随着柱温的升高,Cl-、NO3-和BA的T稍微缩短,而F-、H2PO4-和SO42-的T则稍微延长,各组分峰面积逐渐增加(BA除外),BA和H2PO4-R逐渐增加,而F-、Cl-先降后增,NO3-则反之综合考虑待测组分的检测灵敏度和峰分离度,本试验选择的柱箱温度为35℃。
    表3 柱箱温度选择试验结果(6.0mmol/LNa2CO3-1.0mmol/LNaHCO3溶液,流量0.80 ml/min)
    组分
    30℃
    35℃
    40℃
    T/min
    R
    峰面积
    T/min
    R
    峰面积
    T/min
    R
    峰面积
    F-
    5.207
    3.02
    739319
    5.218
    2.88
    794144
    5.239
    2.96
    863877
    Cl-
    7.184
    5.97
    730106
    7.162
    5.79
    754818
    7.087
    5.82
    850656
    NO3-
    10.757
    1.47
    816408
    10.611
    1.51
    841047
    10.426
    1.48
    904089
    BA
    11.905
    3.00
    451962
    11.705
    3.40
    452106
    11.416
    3.84
    440461
    H2PO4
    14.447
    1.43
    273433
    14.537
    1.64
    318123
    14.586
    1.85
    367593
    SO42-
    15.517
    1018577
    15.793
    1142753
    16.108
    1237767
    2.2 共存物质的影响
    分别取1.1所列各种标准溶液配制成含12mg/L的BA、4mg/L的NO3-、H2PO4-和SO42-1mg/L的F-2mg/L的Cl-、5mg/L的NO2-和Br-的混合标准溶液,以考察NO2-和Br-与6种待测组分的分离效果,见图2,从图2可知,在本试验条件下,NO2-和Br-与硝6种待测组分可以完全分离,均不影响 F-、Cl-、NO3-、BA、H2PO4-和SO42-等组分的测定。
    图2 BA与常见阴离子色谱
    2.3 线性方程、线性范围与检出限
    按照1.3.1配制标准系列,测定 F-、Cl-、NO3-、BA、H2PO4-和SO42-等组分的峰面积,以峰面积(y)为纵坐标,以其质量浓度(x)为横坐标绘制标准曲线,进行线性回归。测定仪器30min的基线噪声,以3倍基线噪声除以标准曲线的斜率(3N/b)计算各组分的最低检出限。其标准曲线的线性范围、回归方程、相关系数r(回归方程的截距、斜率和r均由仪器软件自动生成)、检出限列于表4。从表4可见,BA和SO42-,NO3-、Cl-和H2PO4-,F-的峰面积与其质量浓度分别在0.10~20.0mg/L、0.05~10.0mg/L和0.04~8.0mg/L范围内呈良好的线性关系,相关系数r在0.99940.9999,检出限分别为0.01mg/L0.06mg/L。其中,2.0mg/L的BA和SO42-、1.0mg/L的NO3-、Cl-和H2PO4-和0.80mg/L的F-的标准色谱图见图3。
    表4 BA等6种组分的线性范围、回归方程、相关系数和检出限
    组分
    线性范围/mg/L
    回归方程
    相关系数/r
    检出限/mg/L
    F-
    0.04~0.80
    S=608900C+172700
    0.9999
    0.01
    Cl-
    0.05~10.0
    S=369700C-7110
    0.9999
    0.01
    NO3-
    0.05~10.0
    S=101100C+2467
    0.9999
    0.02
    BA
    0.10~20.0
    S=34990C-2426
    0.9999
    0.06
    H2PO4-
    0.05~10.0
    S=83140C-2426
    0.9994
    0.03
    SO42-
    0.10~20.0
    S=270800C-9792
    0.9998
    0.01
    图3  F-、Cl-、NO3-、BA、H2PO4-和SO42-的标准色谱图
    2.4 样品测定及加标回收试验
    按1.3.3和1.3.4的步骤操作,测定巴比妥、苯巴比妥和维生素B12等样品中的 F-、Cl-、NO3-、BA、H2PO4-和SO42-的含量。并在3种样中分别添加混合标准应用液(B液)0.20、0.40和2.00mL配制成加标样品,各平行测定5次,计算加标回收率及测定结果的相对标准偏差(RSD),结果见表5。由表5可知, F-、Cl-、NO3-、BA、H2PO4-和SO42-的加标回收率分别为99.2%~100.9%、101.0%~103.8%、96.1%~103.0%、92.6%~104.0%、94.6%~101.9%和98.6%~101.0%,5次平行测定结果的RSD分别为1.23%~2.38%、1.15%~1.89%、1.06%~2.11%、1.11%~3.89%、2.05%~3.66%和1.09%~3.05%,方法的回收率较高、重现性良好,巴比妥、苯巴比妥和维生素B12加标样品色谱图见图4。
    图4 巴比妥(A)、苯巴比妥(B)和维生素B12(C)加标样品色谱图
    表5 巴比妥、苯巴比妥和维生素B12样品测定及加标回收试验结果
    组分
    巴比妥(1250mg/L
    苯巴比妥(750mg/L
    维生素B12(10mg/L
    本底/mg/L
    加入量/mg/L
    回收率/%
    RSD/%
    本底/mg/L
    加入量/mg/L
    回收率/%
    RSD/%
    本底/mg/L
    加入量/mg/L
    回收率/%
    RSD/%
    F-
    <0.01
    0.40
    100.9
    2.38
    0.091
    0.80
    99.2
    1.23
    <0.01
    4.00
    99.5
    1.26
    Cl-
    0.138
    0.50
    101.0
    1.15
    2.37
    1.00
    103.8
    1.89
    2.23
    5.00
    101.5
    1.55
    NO3-
    0.024
    0.50
    103.0
    2.11
    0.521
    1.00
    96.1
    1.68
    1.08
    5.00
    100.6
    1.06
    BA
    <0.06
    1.00
    92.6
    1.11
    <0.06
    2.00
    94.1
    3.89
    <0.06
    10.00
    104.0
    2.27
    H2PO4-
    <0.03
    0.50
    101.9
    2.37
    <0.03
    1.00
    94.6
    3.66
    0.182
    5.00
    98.3
    2.05
    SO42-
    0.258
    1.00
    101.0
    2.52
    0.626
    2.00
    98.6
    2.30
    3.15
    10.00
    100.8
    1.09
    3 结语
    建立了以SH-AP-2型阴离子交换柱为分离柱,以6.0mmol/LNa2CO3-1.0mmol/LNaHCO3溶液为淋洗液,流量为0.80 mL/min等度洗脱,离子色谱-抑制电导检测法同时测定F-、Cl-、NO3-、BA、H2PO4-和SO42-的新方法。方法应用于巴比妥、苯巴比妥和维生素B12等样品中F-、Cl-、NO3-、BA、H2PO4-和SO42-同时的测定,加标回收率在92.6%~104.0%,5次平行测定结果的相对标准偏差(RSD)在1.06%~3.89%,最低检出限在0.01mg/L~0.06mg/L,方法回收率较高、重现性良好,操作简便快速,可用于巴比妥、苯巴比妥和维生素B12等样品中BA等6种组分的定量分析。
    参考文献
    1)刘琪,梅洪波,刘野,等.镇静催眠药巴比妥酸的合成研究[J],辽宁化工,2019,48(1):33
    2)罗挽兰,高华,何治柯,等.钌(Ⅱ)-联吡啶-巴比妥酸-Ce(Ⅳ)化学发光体系测定巴比妥酸的研究[J],分析科学学报,1996,12(2):142-144
    3)黄选忠,郑林.巴比妥酸-NO2--Fe(Ⅱ)-CPB显色体系光度测定巴比妥酸的研究[J],分析科学学报,1999,15(3):238-241
    4)谢玉惠冉茂婷龙兴浩.加速溶剂萃取-离子色谱法同时测定复方益母草颗粒中9种无机阴离子含量[J],中南药学,2016,14(8):854-858
    5)谢玉惠,龙兴浩.离子色谱法同时测定附子理中丸中9种无机阴离子[J],安徽医药,2016,20(8):1490-1493
    6)王宇,黄勇.离子色谱法同时检测利咽灵片中9种无机阴离子[J],中药材,2017,40(10):2380-2382
    7)周伟娥杨立佼谢巍,等.离子色谱法同时测定感冒清热颗粒中9种无机阴离子[J],中国药房,2015,26(18):2546-2549
    8)蔡卓夫.离子色谱法定量测定硝酸异山梨酯片中硝酸盐的含量[J],中国药房,2014,25(1):78-79
    9)胡恩泽魏明黄正辉.加速溶剂萃取-离子色谱法同时测定黄连上清片中9种常见无机阴离子的含量[J],中国药房,2017,28(12):1706-1710
    10)陈柳生,蔡自由,周伟明.离子色普法测定维生素B1注射液中的EDTA及硝酸根离子[J],中国实验方剂学杂志,2014,20(14):61-64
    11)《水质分析大全》编写组. 水质分析大全[M]. 重庆:科学技术文献出版社重庆分社,1989:115-118
    12)杜宏山,黄选忠,汪波,等.离子色谱法同时测定环境水样中硫氰酸盐等8种阴离子的方法应用[J].预防医学情报杂志,2021,37(9):1290-1296
附件:
