顶空气相色谱-质谱联用法直接测定药品包装材料中59种VOC
  • zhangyongmei
    2024/09/04
气质联用(GCMS)
  • 顶空气相色谱-质谱联用法直接测定药品包装材料中59挥发性有机物
    张永梅
    重庆市计量质量检测研究院重庆 401123
    摘要: 基于顶空气相色谱-质谱联用法对药品包装材料中的59挥发性有机物(volatile organic compoundsVOC)进行检测直接将药品包装材料剪碎混匀后,称取0.5 g药品包装材料于25 mL顶空瓶中,在顶空80℃条件下孵化30 min后,引入TG-624SilMS [ 60 m * 0.25 mm * 1.4 um] 石英毛细管柱进行分离,选择性离子检测(Selected ion MonitorSIM)模式检测,外标法定量。结果表明59VOC在各自的线性范围内相关系数良好定量限为4 ~ 12 μg/kg低(4 μg/kg 12 μg/kg)、中(40 μg/kg)、160 μg/kg三个添加水平下回收率为85.0% ~ 115.3%相对标准偏差为0.43% ~ 6.3%本方法适用于药品包装材料中59VOC的测定
    关键词:气相色谱-质谱联用仪;挥发性有机物;药品包装材料;
    Headspace gas chromatography-mass spectrometry was used for the direct determination of 59 volatile organic compounds in pharmaceutical packaging materials
    ZHANG Yongmei
    (Chongqing Academy of Metrology and Quality Inspection, Chongqing 401123)
    Abstract: A total of 59 volatile organic compounds (VOCs) were detected in pharmaceutical packaging materials based on headspace gas chromatography-mass spectrometry. After directly cutting and mixing the pharmaceutical packaging materials, 0.5 g of pharmaceutical packaging materials were weighed in a 25 mL headspace bottle, incubated at headspace 80°C for 30 min, and then introduced into a TG-624SilMS [60 m * 0.25 mm * 1.4 um] quartz capillary column for separation, detected by Selected ion Monitor (SIM) mode, and quantified by external standard method. The results showed that the correlation coefficient of the 59 VOCs was good in their respective linear ranges, and the limit of quantification was 4 ~ 12 μg/kg. The recoveries were 85.0% ~ 115.3% and the relative standard deviation was 0.43% ~ 6.3% at the three addition levels of low (4 μg/kg or 12 μg/kg), medium (40 μg/kg) and high (160 μg/kg). This method is suitable for the determination of 59 VOCs in pharmaceutical packaging materials.
    Keywords: Gas chromatography-mass spectrometry; Volatile organic compounds; Pharmaceutical packaging materials;
    挥发性有机物VOC是空气中常见的一类有害物质,主要来源于工业生产、汽车尾气、家居装修等[1]挥发性有机物不仅对人体健康造成威胁,还会对环境产生不良影响[2-5]化学药品注射剂与塑料包装材料相容性研究技术指导原则[6]指出,药品包装材料包括多种塑料材质,如聚乙烯(PE)、聚丙烯(PP)、聚对苯二甲酸乙二醇酯(PET)等。药品包装材料在生产和印刷过程中可能会残留挥发性有机物,这些溶剂可能会迁移到药物中,对人体健康造成潜在危害[7]因此进行药品包装材料中挥发性有机物的检测至关重要。
    挥发性有机物(VOC)的分析通常采用顶空进样,结合气相色谱GC)和气相色谱-质谱联用仪GC/MS)进行分析[8-15]例如,郝德凤[8]GC应用水环境检测进行全面的分析杨清[9]王璐[10]I建立吹扫捕集-GC/MS测定水质中挥发性有机物欧阳文瑜[11]李昊洋[12]基于固相微萃取结合GC/MS检测美甲产品、血液挥发性有机物王旭东[13]等建立GC/MS检测土壤中挥发性有机物谭岸[14]结合电子鼻和GC/MS明确化橘红中关键香气成分牛香[15]结合采用动态顶空套袋法采集和热脱附GC/MS分析6种园林植物挥发性有机物成分。这些方法均采用GCGC/MS园林、橘红、土壤、美甲产品、水分中的挥发性物质进行分析,对药品包装材料中挥发性有机物的研究鲜有报道。本研究基于顶空GC/MS直接对药品包装材料中挥发性有机物进行检测,前处理简单,准确度和灵敏度高,挥发性有机物的检测在药品包装材料中的分析是一个重要的议题,特别是在确保药品安全性和有效性的背景下可为药品包装材料的安全性提供方法参考
    1实验部分
    1.1 仪器与试剂
    QP-2020气相色谱-质谱联用仪(日本岛津公司);移液枪1 mL10 μL50 μL(德国Brand--Transferpette®);螺旋顶空瓶:25 mLQuintix224-1CN电子天平(德国赛多利斯公司);剪刀;甲醇(色谱级,北京百灵威科技有限公司);58VOC混合标准溶液(浓度均为1000 mg/L)和环己酮(纯度99.7%)(均购于北京曼哈格生物科技有限公司)。
    1.2 标准溶液的制备
    称取10 mg(精确至0.0001 g)环己酮标准品于10 mL容量瓶中,甲醇溶解并定容至刻度,得到浓度为1000 mg/L的环己酮标准储备液分别取1.0 mL浓度为1000 mg/L的环己酮标准储备液和浓度为1000 mg/L58VOC混合标准溶液于100 mL棕色容量瓶中,用甲醇定容至刻度,混匀,得到浓度为10 mg/L59VOC混合标准储备液I,用10 μL移液枪分别取0.200.601.02.04.06.08.010 μL 59VOC混合标准储备液I25 mL螺旋顶空瓶中,得到59VOC质量均为261020406080100 ng59VOC系列标准工作溶液。
    1.3 样品前处理
    Quintix224-1CN电子天平称取质量不低于10 g的药品包装材料,选取含有颜料部分进行剪碎,混匀,然后称取质量为0.5 g的剪碎后的药品包装材料于25 mL螺旋顶空瓶中,密封,引入QP-2020气相色谱-质谱联用仪中上机测试
    1.4 仪器条件
    1.4.1 色谱条件
    色谱柱TG-624SilMS [ 60 m * 0.25 mm * 1.4 um] 石英毛细管柱;孵化温度为80;孵化时间为30 min进样口温度250℃升温程序为初始温度40,保持5 min,以8 ℃/min升温至90,保持4 min,以6 ℃/min升温至200,保持15 min;分流进样分流比5:1载气氦气(纯度≥99.999%恒流模式流速1.0 mL/min进样体积1000 μL溶剂延迟时间为2 min
    1.4.2 质谱条件
    离子源温度300传输线温度250SIM分段扫描模式;59VOC的基本信息、定性参考离子和定量参考离子见表1
    7.0-9.7min扫描的质核比(m/z)为101,103,66,61,96,98,43,58,75,142,127,141,76,44,78
    9.7-12.0min扫描的质核比(m/z)为49,84,86,61,9666,98,63,65,83
    12.0-13.5min扫描的质核比(m/z)为77,97,41,96,61,98,43,72,57,49,130,128,83,85,47
    13.5-15.5min扫描的质核比(m/z)为97,99,61,117,119,82,75,39,110,78,77,52,62,64,49
    15.5-20.4min扫描的质核比(m/z)为95,130,132,63,62,41,93,174,83,85,47,43,58,57,91,92,65
    20.4-23.0min扫描的质核比(m/z)为83,97,61,166,129,131,76,41,78,43,58,57,127,107,109,93
    23.0-24.9min扫描的质核比(m/z)为112,77,114,131,11795,91,106,51,63,62,65
    24.9-26.9min扫描的质核比(m/z)为91,106,105,104,78,103,77,173,171,175,120,79
    26.9-28.4min扫描的质核比(m/z)为83,85,95,77,156,158,75,61,91,120,65,126,89,105,63
    28.4-30.5min扫描的质核比(m/z)为119,91,41,105,120,77,134,146,148,111
    30.5-38.3min扫描的质核比(m/z)为91,92,134,146,148,111,75,39,157,180,182,145,225,227,223,128,127
    1 59VOC基本信息和参考离子
    Table 1 Basic information and reference ions for 59 VOCs
    序号
    化合物
    英文名称
    化学文摘号
    特征离子碎片/m/z
    定性参考离子
    定量选择离子
    三氯氟甲烷
    Trichlorofluoromethane
    75-69-4
    89
    101
    1,1-二氯乙烯
    1,1-dichloroethene
    75-35-4
    87
    96
    3
    丙酮
    acetone
    67-64-1
    66
    75
    4
    碘甲烷
    iodo-methane
    74-88-4
    95
    142
    二硫化碳
    carbon disulfide
    75-15-0
    97
    76
    6
    反式-1,2-二氯乙烯
    trans-1,2-dichloroethene
    156-60-5
    89
    61
    7
    1,1-二氯乙烷
    1,1-dichloroethane
    75-34-3
    92
    63
    8
    2,2-二氯丙烷
    2,2-dichloropropane
    594-20-7
    82
    77
    9
    顺式-1,2-二氯乙烯
    cis-1,2-dichloroethene
    156-59-2
    78
    61
    10
    2-丁酮
    2-butanone
    78-93-3
    16
    72
    11
    溴氯甲烷
    bromochloromethane
    74-97-5
    76
    49
    12
    氯仿
    chloroform
    67-66-3
    90
    83
    13
    1,1,1-三氯乙烷
    1,1,1-trichloroethane
    71-55-6
    89
    97
    14
    四氯化碳
    carbon tetrachloride
    56-23-5
    35
    117
    15
    1,1-二氯丙烯
    1,1-dichloropropene
    563-58-6
    82
    75
    16
    benzene
    71-43-2
    85
    78
    17
    1,2-二氯乙烷
    1,2-dichloroethane
    107-06-2
    87
    62
    18
    三氯乙烯
    trichloroethylene
    79-01-6
    74
    95
    19
    1,2-二氯丙烷
    1,2-dichloropropane
    78-87-5
    80
    63
    20
    二溴甲烷
    dibromomethane
    74-95-3
    80
    93
    21
    一溴二氯甲烷
    bromodichloromethane
    75-27-4
    83
    83
    22
    4-甲基-2-戊酮
    4-methyl-2-pentanone
    108-10-1
    92
    43
    23
    甲苯
    toluene
    108-88-3
    91
    91
    24
    1,1,2-三氯乙烷
    1,1,2-trichloroethane
    79-00-5
    66
    83
    25
    四氯乙烯
    tetrachloroethylene
    127-18-4
    62
    166
    26
    1,3-二氯丙烷
    1,3-dichloropropane
    142-28-9
    86
    76
    27
    2-己酮
    2-hexanone
    591-78-6
    90
    43
    28
    二溴氯甲烷
    dibromochloromethane
    124-48-1
    77
    129
    29
    1,2-二溴乙烷
    1,2-dibromoethane
    106-93-4
    92
    107
    30
    氯苯
    chlorobenzene
    108-90-7
    88
    112
    31
    1,1,1,2-四氯乙烷
    1,1,1,2-tetrachloroethane
    630-20-6
    73
    131
    32
    乙苯
    ethylbenzene
    100-41-4
    74
    91
    33
    1,1,2-三氯丙烷
    1,1,2-trichloropropane
    598-77-6
    86
    63
    34
    环己酮
    Cyclohexanone
    108-94-1
    98
    55
    35
    间二甲苯
    m-xylene
    108-38-3
    82
    91
    36
    对二甲苯
    p-xylene
    106-42-3
    91
    91
    37
    邻二甲苯
    o-xylene
    95-47-6
    91
    91
    38
    苯乙烯
    styrene
    100-42-5
    104
    104
    39
    溴仿
    bromoform
    75-25-2
    173
    173
    40
    异丙苯
    isopropylbenzene
    98-82-8
    105
    105
    41
    溴苯
    bromobenzene
    108-86-1
    83
    83
    42
    1,1,2,2-四氯乙烷
    1,1,2,2-tetrachloroethane
    79-34-5
    77
    77
    43
    1,2,3-三氯丙烷
    1,2,3-trichloropropane
    96-18-4
    75
    75
    44
    正丙苯
    n-propylbenzene
    103-65-1
    91
    91
    45
    2-氯甲苯
    2-chlorotoluene
    95-49-8
    91
    91
    46
    1,3,5-三甲基苯
    1,3,5-trimethylbenzene
    108-67-8
    105
    105
    47
    4-氯甲苯
    4-chlorotoluene
    106-43-4
    91
    91
    48
    叔丁基苯
    tert-butylbenzene
    98-06-6
    119
    119
    49
    1,2,4-三甲基苯
    1,2,4-trimethylbenzene
    95-63-6
    105
    105
    50
    仲丁基苯
    sec-butylbenzene
    135-98-8
    105
    105
    51
    1,3-二氯苯
    1,3-dichlorobenzene
    541-73-1
    146
    146
    52
    4-异丙基甲苯
    p-isopropyltoluene
    99-87-6
    119
    119
    53
    1,4-二氯苯
    1,4-dichlorobenzene
    106-46-7
    146
    146
    54
    正丁基苯
    n-butylbenzene
    104-51-8
    91
    91
    55
    1,2-二氯苯
    1,2-dichlorobenzene
    95-50-1
    146
    146
    56
    1,2-二溴-3-氯丙烷
    1,2-dibromo-3-chloropropane
    96-12-8
    75
    75
    57
    1,2,4-三氯苯
    1,2,4-trichlorobenzene
    120-82-1
    180
    180
    58
    六氯丁二烯
    hexachlorobutadiene
    87-68-3
    225
    225
    59
    1,2,3-三氯苯
    1,2,3-Trichlorobenzene
    87-61-6
    180
    128
    2 结果与讨论
    2.1进样器的选择
    气相色谱常用的2种进样方式为液体进样和顶空进样,液体进样方式将样品溶解到合适的溶剂中,由于VOC通常易挥发、易分解,低于溶剂沸点和与溶剂沸点相识的物质容易受溶剂的干扰。顶空进样无溶剂的干扰、灵敏度高、样品处理简单、基质效应小、适合热不稳定化合物。综上,选择顶空进样的方式测定药品包装材料中的59VOC
    2.2孵化温度的选择
    样品中挥发性物质的释放与孵化温度有关,较高的孵化温度可以提高检测的灵敏度,缩短检测时间。但过高的孵化温度可能导致样品进入色谱柱前汽化不完全和分解,样品中过多的物质挥发出来,也增大了基质效应,所以选择合适孵化温度十分重要。实验考察了孵化温度为60657075808590℃7种条件下对59VOC灵敏度的影响。实验发现,当孵化温度为80℃时,57VOC的响应最高,且峰形尖锐对称。所以,选择孵化温度为80℃对药品包装材料中的59VOC进行检测。
    2.3孵化时间的选择
    孵化时间越长,样品平衡越充分,样品在检测过程中灵敏度越高,准确性和重复性越好,但是过长的孵化时间,可能导致样品中的某些成分发生分解,增加基质效应,且分析时间延长,工作效率降低。因此,在保证样品检测结果准确的前提下,尽可能缩短孵化时间。实验考察了孵化温度为152025303540 min6种条件下对59VOC的影响。实验发现,当孵化时间为30 min时,59VOC的响应最高,且有较好的准确性和重复性。最终,选择孵化时间为30 min对药品包装材料中59VOC进行检测。
    2.4色谱柱的选择
    色谱柱直接关系到样品分析的效率和准确性,是气相色谱分析中的关键因素。实验考察了TG-624SilMS [ 60 m * 0.25 mm * 1.4 um]TG-WAX MS [ 60 m * 0.25 mm * 1.4 um]TG-17Sil MS [ 60 m * 0.25 mm * 1.4 um]TG-5MS [ 60 m * 0.25 mm * 1.4 um]4石英毛细59VOC的影响结果发现,使用TG-WAX MS [ 60 m * 0.25 mm * 1.4 um]TG-17Sil MS [ 60 m * 0.25 mm * 1.4 um]TG-5MS [ 60 m * 0.25 mm * 1.4 um] 石英毛细时,一部分化合物灵敏度低具有相同离子对的化合物不能完全分离。使用TG-624SilMS [ 60 m * 0.25 mm * 1.4 um] 石英毛细时,59VOC均有较高的灵敏度,且含有相同离子对的化合物能够实现分离。综上,选择TG-624SilMS [ 60 m * 0.25 mm * 1.4 um] 石英毛细分离药品包装材料中的59VOC
    2.5 标准曲线和检出限
    采用1.4节的仪器条件,分别对1.2节配制的系列标准工作溶液进行测试。以59VOC的质量为横坐标(x, ng),定量离子峰面积为纵坐标(y)绘制标准曲线。在各自线性范围内,59VOC的线性相关系数R均大于0.997在药品包装材料空白基质中进行加标实验,以信噪比(S/N10)确定各目标物的定量限为4 ng/g~12 ng/g。结果如表2所示。
    2 59VOC线性和定量
    Table 2 Linearity and LOQ for 59 VOCs
    序号
    化合物
    线性范围/ng
    线性方程
    相关系数
    定量限/(ng/g)
    三氯氟甲烷
    6.0 ~ 100
    y=1.04×104x+16.22
    0.9997
    12
    1,1-二氯乙烯
    2.0 ~ 100
    y=2.49×104x-18.51
    0.9994
    4.0
    3
    丙酮
    6.0 ~ 100
    y =4.60×104x-14.82
    0.9992
    12
    4
    碘甲烷
    6.0 ~ 100
    y=1.99×104x–14.72
    0.9997
    12
    二硫化碳
    6.0 ~ 100
    y =1.71×104x+99.77
    0.9991
    12
    6
    反式-1,2-二氯乙烯
    6.0 ~ 100
    y =5.09×103x–79.80
    0.9998
    12
    7
    1,1-二氯乙烷
    6.0 ~ 100
    y =4.31 ×103x–33.71
    0.9993
    12
    8
    2,2-二氯丙烷
    6.0 ~ 100
    y =7.09 ×104x–28.87
    0.9986
    12
    9
    顺式-1,2-二氯乙烯
    6.0 ~ 100
    y =3.12×104x–70.50
    0.9998
    12
    10
    2-丁酮
    6.0 ~ 100
    y =1.94×104x+61.24
    0.9995
    12
    11
    溴氯甲烷
    6.0 ~ 100
    y=1.37×104x–36.01
    0.9994
    12
    12
    氯仿
    6.0 ~ 100
    y =2.14×104x–88.46
    0.9999
    12
    13
    1,1,1-三氯乙烷
    6.0 ~ 100
    y =7.15×103x+99.54
    0.9989
    12
    14
    四氯化碳
    2.0 ~ 100
    y =1.81×104x–204.2
    0.9973
    4.0
    15
    1,1-二氯丙烯
    6.0 ~ 100
    y =3.77×104x–12.40
    0.9999
    12
    16
    2.0 ~ 100
    y=1.04×104x+16.13
    0.9992
    4.0
    17
    1,2-二氯乙烷
    6.0 ~ 100
    y=2.49×104x-15.21
    0.9994
    12
    18
    三氯乙烯
    6.0 ~ 100
    y =4.03×104x-18.12
    0.9990
    12
    19
    1,2-二氯丙烷
    6.0 ~ 100
    y=1.95×104x–14.32
    0.9997
    12
    20
    二溴甲烷
    6.0 ~ 100
    y =1.12×104x+97.17
    0.9979
    12
    21
    一溴二氯甲烷
    6.0 ~ 100
    y =3.91×103x–79.80
    0.9998
    12
    22
    4-甲基-2-戊酮
    6.0 ~ 100
    y =6.13 ×103x–37.11
    0.9977
    12
    23
    甲苯
    6.0 ~ 100
    y =7.13 ×104x–28.97
    0.9986
    12
    24
    1,1,2-三氯乙烷
    6.0 ~ 100
    y =3.12×104x–73.50
    0.9985
    12
    25
    四氯乙烯
    6.0 ~ 100
    y =3.04×104x+62.34
    0.9995
    12
    26
    1,3-二氯丙烷
    6.0 ~ 100
    y=1.57×104x–36.30
    0.9994
    12
    27
    2-己酮
    6.0 ~ 100
    y =2.04×104x–88.36
    0.9995
    12
    28
    二溴氯甲烷
    6.0 ~ 100
    y =7.15×103x+92.54
    0.9973
    12
    29
    1,2-二溴乙烷
    6.0 ~ 100
    y =1.81×104x14.23
    0.9975
    12
    30
    氯苯
    6.0 ~ 100
    y =2.61×104x1.666
    0.9993
    12
    31
    1,1,1,2-四氯乙烷
    6.0 ~ 100
    y=2.44×104x+1.643
    0.9992
    12
    32
    乙苯
    6.0 ~ 100
    y=2.95×104x-185.1
    0.9994
    12
    33
    1,1,2-三氯丙烷
    6.0 ~ 100
    y =4.63×104x-148.3
    0.9990
    12
    34
    环己酮
    6.0 ~ 100
    y=4.92×104x–11.72
    0.9993
    12
    35
    间二甲苯
    6.0 ~ 100
    y=4.95×104x–14.72
    0.9990
    12
    36
    对二甲苯
    6.0 ~ 100
    y=3.95×104x–14.72
    0.9997
    12
    37
    邻二甲苯
    6.0 ~ 100
    y =1.71×104x+97.70
    0.9991
    12
    38
    苯乙烯
    6.0 ~ 100
    y =1.091×103x49.80
    0.9998
    12
    39
    溴仿
    6.0 ~ 100
    y =3.31 ×103x–37.10
    0.9971
    12
    40
    异丙苯
    6.0 ~ 100
    y =7.03 ×104x–28.17
    0.9982
    12
    41
    溴苯
    6.0 ~ 100
    y =3.42×104x–73.50
    0.9998
    12
    42
    1,1,2,2-四氯乙烷
    6.0 ~ 100
    y =2.94×104x+62.42
    0.9990
    12
    43
    1,2,3-三氯丙烷
    6.0 ~ 100
    y=1.30×104x–36.00
    0.9994
    12
    44
    正丙苯
    6.0 ~ 100
    y =2.14×104x–8.246
    0.9998
    12
    45
    2-氯甲苯
    6.0 ~ 100
    y =7.15×103x+9.541
    0.9982
    12
    46
    1,3,5-三甲基苯
    6.0 ~ 100
    y =3.88×104x–20.42
    0.9973
    12
    47
    4-氯甲苯
    6.0 ~ 100
    y =1.71×104x–14.68
    0.9997
    12
    48
    叔丁基苯
    6.0 ~ 100
    y=1.94×104x+16.43
    0.9992
    12
    49
    1,2,4-三甲基苯
    6.0 ~ 100
    y=2.49×104x-85.12
    0.9994
    12
    50
    仲丁基苯
    6.0 ~ 100
    y =4.69×104x-148.2
    0.9993
    12
    51
    1,3-二氯苯
    6.0 ~ 100
    y=1.95×104x–14.72
    0.9997
    12
    52
    4-异丙基甲苯
    6.0 ~ 100
    y =1.12×104x+9.977
    0.9996
    12
    53
    1,4-二氯苯
    6.0 ~ 100
    y =5.61×103x–72.80
    0.9998
    12
    54
    正丁基苯
    6.0 ~ 100
    y =4.13 ×103x–7.132
    0.9974
    12
    55
    1,2-二氯苯
    6.0 ~ 100
    y =7.93 ×104x–28.21
    0.9988
    12
    56
    1,2-二溴-3-氯丙烷
    6.0 ~ 100
    y =3.19×104x–70.59
    0.9998
    12
    57
    1,2,4-三氯苯
    6.0 ~ 100
    y =2.3104x+12.45
    0.9990
    12
    58
    六氯丁二烯
    6.0 ~ 100
    y=1.32×104x–36.80
    0.9994
    12
    59
    1,2,3-三氯苯
    6.0 ~ 100
    y =5.22×104x–8.462
    0.9996
    12
    2.6回收率和精密度
    在药品包装材料空白基质中加入低(4.0 ng/g12 ng/g)、中(40 ng/g)、高(160 ng/g3个浓度水平的混合标准储备液,每个浓度水平平行实验6次,结果见表359VOC的回收率为85.0% ~ 115.3%相对标准偏差为0.43% ~ 6.3%。回收率和精密度能满足药品包装材料59VOC的检测要求。
    3 59VOC的回收率和精密度(n=6
    Table 3 Recovery and precision of 59 VOCs (n=6)
    序号
    化合物
    加标浓度((ng/g)
    回收率/%
    精密度/%
    三氯氟甲烷
    12, 40, 160
    93.2-111.9
    1.2, 3.3, 5.8
    1,1-二氯乙烯
    4.0 40, 160
    88.2-101.8
    1.8, 3.0, 4.0
    3
    丙酮
    12, 40, 160
    97.1-114.6
    1.2, 1.6, 1.9
    4
    碘甲烷
    12, 40, 160
    93.8-106.1
    1.1, 2.1, 3.2
    二硫化碳
    12, 40, 160
    87.7-102.1
    1.6, 2.2, 3.7
    6
    反式-1,2-二氯乙烯
    12, 40, 160
    92.0-103.7
    1.3, 4.2, 5.8
    7
    1,1-二氯乙烷
    12, 40, 160
    94.7-114.2
    3.2, 5.1, 5.7
    8
    2,2-二氯丙烷
    12, 40, 160
    91.2-104.3
    0.91, 1.8, 3.0
    9
    顺式-1,2-二氯乙烯
    12, 40, 160
    89.3-107.7
    1.0, 1.6, 2.5
    10
    2-丁酮
    12, 40, 160
    90.0-110.5
    1.8, 2.2, 4.2
    11
    溴氯甲烷
    12, 40, 160
    93.7-101.2
    0.43, 0.98 5.0
    12
    氯仿
    12, 40, 160
    94.6-103.5
    2.4, 3.5, 5.3
    13
    1,1,1-三氯乙烷
    12, 40, 160
    90.0-111.8
    1.5, 4.0, 5.2
    14
    四氯化碳
    4.0 40, 160
    99.3-111.2
    2.0, 2.3, 3.7
    15
    1,1-二氯丙烯
    12, 40, 160
    93.8-110.0
    2.0, 4.8, 5.3
    16
    4.0 40, 160
    93.2-111.9
    1.2, 3.3, 5.8
    17
    1,2-二氯乙烷
    12, 40, 160
    88.2-101.8
    1.8, 3.0, 4.0
    18
    三氯乙烯
    12, 40, 160
    97.2-104.8
    1.8, 2.5, 6.3
    19
    1,2-二氯丙烷
    12, 40, 160
    87.4-115.3
    1.6, 3.2, 5.2
    20
    二溴甲烷
    12, 40, 160
    102.1-104.8
    1.4, 2.8, 6.0
    21
    一溴二氯甲烷
    12, 40, 160
    99.0-110.2
    1.7, 4.3, 5.1
    22
    4-甲基-2-戊酮
    12, 40, 160
    101.0-112.5
    2.1, 4.8, 6.0
    23
    甲苯
    12, 40, 160
    96.7-104.3
    1.9, 3.4, 5.7
    24
    1,1,2-三氯乙烷
    12, 40, 160
    100.3-108.6
    1.8, 2.3 5.8
    25
    四氯乙烯
    12, 40, 160
    93.0-109.8
    1.4, 2.8, 3.6
    26
    1,3-二氯丙烷
    12, 40, 160
    93.7-105.8
    2.0, 4.4, 5.4
    27
    2-己酮
    12, 40, 160
    92.2-104.3
    2.5, 3.5, 4.8
    28
    二溴氯甲烷
    12, 40, 160
    89.3-103.3
    1.1, 2.2, 4.7
    29
    1,2-二溴乙烷
    12, 40, 160
    92.7-106.4
    1.2, 3.3, 3.8
    30
    氯苯
    12, 40, 160
    90.7-108.0
    1.5, 4.0, 5.0
    31
    1,1,1,2-四氯乙烷
    12, 40, 160
    85.0-114.0
    1.5, 2.3, 4.7
    32
    乙苯
    12, 40, 160
    90.0-99.4
    2.8, 4.1, 4.3
    33
    1,1,2-三氯丙烷
    12, 40, 160
    97.2-104.8
    1.8, 2.5, 6.3
    34
    环己酮
    12, 40, 160
    89.8-113.9
    1.6, 3.9, 5.8
    35
    间二甲苯
    12, 40, 160
    87.8-113.3
    1.6, 3.1, 4.8
    36
    对二甲苯
    12, 40, 160
    87.4-115.3
    1.6, 3.2, 5.2
    37
    邻二甲苯
    12, 40, 160
    102.1-104.8
    1.4, 2.8, 6.0
    38
    苯乙烯
    12, 40, 160
    99.0-110.2
    1.7, 4.3, 5.1
    39
    溴仿
    12, 40, 160
    101.0-112.5
    2.1, 4.8, 6.0
    40
    异丙苯
    12, 40, 160
    96.7-104.3
    1.9, 3.4, 5.7
    41
    溴苯
    12, 40, 160
    100.3-108.6
    1.8, 2.3 5.8
    42
    1,1,2,2-四氯乙烷
    12, 40, 160
    93.0-109.8
    1.4, 2.8, 3.6
    43
    1,2,3-三氯丙烷
    12, 40, 160
    93.7-105.8
    2.0, 4.4, 5.4
    44
    正丙苯
    12, 40, 160
    92.2-104.3
    2.5, 3.5, 4.8
    45
    2-氯甲苯
    12, 40, 160
    89.3-103.3
    1.1, 2.2, 4.7
    46
    1,3,5-三甲基苯
    12, 40, 160
    92.7-106.4
    1.2, 3.3, 3.8
    47
    4-氯甲苯
    12, 40, 160
    106.0-115.2
    2.5, 3.2, 4.6
    48
    叔丁基苯
    12, 40, 160
    105.2-111.2
    1.1, 1.9, 2.4
    49
    1,2,4-三甲基苯
    12, 40, 160
    99.7-108.9
    0.63, 1.5, 4.4
    50
    仲丁基苯
    12, 40, 160
    106.8-110.4
    1.2, 3.8, 5.1
    51
    1,3-二氯苯
    12, 40, 160
    96.7-104.2
    1.1, 2.4, 2.9
    52
    4-异丙基甲苯
    12, 40, 160
    93.8-112.8
    1.3, 2.9, 5.1
    53
    1,4-二氯苯
    12, 40, 160
    97.2-111.7
    2.3, 2.6, 4.2
    54
    正丁基苯
    12, 40, 160
    93.5-106.5
    2.1, 2.7, 3.4
    55
    1,2-二氯苯
    12, 40, 160
    100.8-112.7
    0.72, 1.5, 5.9
    56
    1,2-二溴-3-氯丙烷
    12, 40, 160
    96.8-105.7
    1.2, 3.2, 4.9
    57
    1,2,4-三氯苯
    12, 40, 160
    90.2-109.2
    1.8, 3.3, 3.9
    58
    六氯丁二烯
    12, 40, 160
    85.3-104.3
    1.4, 3.0, 4.2
    59
    1,2,3-三氯苯
    12, 40, 160
    92.2-105.5
    1.7, 3.6, 4.3
    2.7 样品检测
    购买规格50 mL100 mL250 mL500 mL的药品包装材料各5个批次的样品,采用1.3节前处理方法和1.4节仪器条件对上述20批次样品进59VOC的检测。结果显示,有一个批次的药品包装材料中检测出乙苯(320 ng/g)、异丙苯(42 ng/g)、正丙苯(25 ng/g)、1,2-二溴-3-氯丙烷56 ng/g)共4种物质,其他批次均未检出。说明药品包装材料可能存在挥发性有机物的风险
    3 结论
    本实验采用顶空气相色谱-质谱联用法对药品包装材料中的59VOC进行检测,具有较高的准确性和灵敏度。本实验直接对药品包装材料进行检测,能够避免复杂的前处理过程带来干扰,该方法前处理简单,能够提高工作效率、降低实验成本。能够为药品包装材料中挥发性有机物的检测提供依据,为提高药品包装材料的质量做出贡献。
    参考文献
    [1] 孙金博, 杨娟娟, 陈海洋, 薛照先. VOC废气的低温冷凝回收工艺的设计[J]. 广东化工, 2024, 51(16): 113-115.
    [2] 徐庄浩, 冯晨 ,邵一泓, 徐正宁, 谢光照, 曲芳琪, 张飞, 熊春, 金玲玲, 王志彬. 海宁市VOCs污染特征、来源及其对臭氧生成的敏感性分析[J]. 环境科学学报, 1-13 [2024-09-04].
    [3] 汤奔, 苏惠旋. 化工类废气挥发性有机VOC的危害及催化氧化技术研究进展[J]. 广东化工, 2023, 50(09): 150-153.
    [4] 陶雨寒, 毛辉. 呼出气挥发性有机物在呼吸系统非感染性疾病中的应用[J]. 中国呼吸与危重监护杂志, 2024, 23(08): 599-604.
    [5] 李传鹏. 挥发性有机物检测技术在环境检测中的应用分析[J]. 化纤与纺织技术, 2024, 53(06): 53-55.
    [6] 国家药品监督管理局. 化学药品注射剂与塑料包装材料相容性研究技术指导原则(试行). (2012-09-07).
    [7] 覃丽娟. 化学药品包装材料与药物相容性研究策略与方法[J]. 生物化工, 2024,10(01): 188-191.
    [8] 郝德凤, 温瑞瑞. 水环境检测中气相色谱技术的应用[J]. 石河子科技, 2024,(04): 3-4.
    [9] 杨清. 吹扫捕集/气相色谱-质谱法快速测定水质中33种挥发性有机物[J]. 山西化工, 2024, 44(05): 60-62.
    [10] 王璐, 蔡德玲, 梁宁, 黄晶, 杨滨银. 吹扫捕集-气相色谱-质谱法快速测定生活饮用水中82种挥发性有机物[J]. 环境卫生学杂志, 2024, 14(06): 514-519.
    [11] 欧阳文瑜, 刘舒芹, 黄雅萱, 江瑞芬. 基于固相微萃取检测美甲产品中挥发性有机物[J]. 分析测试学报, 1-8 [2024-09-04].
    [12] 李昊洋, 张文骥, 韩祺瑞, 丁海媛, 于汇川, 罗颖超. 顶空固相微萃取/气相色谱-质谱法测定血液中15种挥发性有机物[J]. 分析测试学报, 1-8[2024-09-04].
    [13] 王旭东, 王泽宇, 魏义章. 气相色谱-质谱法检测土壤中挥发性有机物研究[J]. 实验室检测, 2024, 2(07):57-61.
    [14] 谭岸 ,陈杵生, 马雨茵, 吴迪, 阚启鑫, 宋明月. 化橘红精油香气成分分析及品质检测[J]. 现代食品科技, 1-9[2024-09-04].
    [15] 牛香,王兵,袁卿语, 郭雅君, 许庭毓, 张维康. 6种园林植物挥发性有机物成分分析[J]. 西南林业大学学报(自然科学), 2024, 44(02): 174-184.
  • wazcq
    第1楼2024/09/07
    定量限刚好是线性最低点的2倍,而且59 种voc 有56种定量限都一样?
  • zhangyongmei
    第2楼2024/09/07
    不对,曲线最低点是定量限哦!
    wazcq(wazcq) 发表:定量限刚好是线性最低点的2倍,而且59 种voc 有56种定量限都一样?
  • 一个小明
    第3楼2024/09/13
    请问在内标外标之间,为什么选择了外标呢?因子相似的水土voc,都是选择的内标。
    tg624上的间对二甲苯能分开吗?db和tg624上的应该都是分不开的吧.
  • wazcq
    第4楼2024/09/13
    标液顶空瓶没有固体,而样品是固体,这样顶空基质不匹配
