Accuracy should be assessed using a minimum of 9 determinations over a minimum of 3 concentration levels covering the specified range (e.g., 3 concentrations/3 replicates each of the total analytical procedure). Repeatability should be assessed using: a) a minimum of 9 determinations covering the specified range for the procedure (e.g., 3 concentrations/3 replicates each);
