anycontrol
第2楼2007/05/24
农残分析中LOD和LOQ的计算实例
传了二十分钟了,传了五六次也传不上去,这次是传上去了吧
真辛苦啊,还希望对同行们有用,大家多探讨吧,也别忘了顶一下哟
loacao
第13楼2007/06/06
楼主的EPA方法,在国内一般是不按照其计算LOD及LOQ的。
LOD的具体计算方法,现在的确莫衷一是,国内的做法一般是认为3倍基线噪声时的浓度,并换算为进样量即检出限;而有些国家的做法是稀释基质标样,直到峰高是3倍噪声为止,认为这时的进样量为检出限。我们从以上两种方法可知,第二种方法更科学可靠。 而欧盟是进7针基质空白,算出SD,认为LOD即3SD,仅供参考。
LOQ最低检出浓度即检测限,表示采用某一检测方法所能检出待测物的最低含量。较为科学的做法,最低检出浓度的计算一般采用实际添加可达到定量检测的最小水平。而非公式计算或S/N为10。
个人建议,有待讨论
sunrain001
第34楼2007/11/30
有一个问题,在欧盟METHOD VALIDATION AND QUALITY CONTROL PROCEDURES FOR PESTICIDE RESIDUES ANALYSIS IN FOOD AND FEED 文件中,认为LOD与LOQ是一个东西--定量测定限,检出限用limit of detection 表示,LOD是limit of determination,原文释义如下:LOQ--Limit of quantitation (quantification) (also known as limit of determination, LOD). The minimum concentration or mass of the analyte that can be quantified with acceptable accuracy and precision. Should apply to the complete analytical method. Variously defined but must be a value greater than the limit of detection. With most methods and determination systems, the LOQ has no fixed value. LOQ is preferable to LOD because it avoids possible con-fusion with “limit of detection”. However, in legislation MRLs that are set at the limit of quantification/determination are referred to as “LOD MRLs”, not“LOQ MRLs”.
