黄鹤楼 2007/08/20
ASTM E537-02用热温差法分析对化学用品中热稳定性评价的试验方法: http://www.instrument.com.cn/show/download/shtml/051346.shtml
cosmo4411110 2007/08/20
版主快个我积分啊,我都解决了。 楼上的朋友可以去我的帖子里面跟贴你要的标准的,我基本上都有的。http://www.instrument.com.cn/bbs/shtml/20070820/949411/
ziliao 2007/08/20
[quote]原文由 [B]tanww[/B] 发表: E0487-99 Constant Temperature Stability of Chemical Materials E0537-98 Assessing the Thermal Stability of Chemicals by Means of DTA E0698-99 Arrhenius Kinetic Constants for Thermally Unstable Materials [em02] [em61][/quote] 只有01版的 [img]https://www.instrument.com.cn/bbs/images/affix.gif[/img][url=http://www.instrument.com.cn/bbs/download.asp?ID=61313]E698-01[/url]
飞花刀语 2007/08/20
ASTM E487-99 化学材料的恒温稳定性的试验方法 http://www.instrument.com.cn/show/download/shtml/051351.shtml
cosmo4411110
第8楼2007/08/20
E537 - Standard Test Method for The Thermal Stability Of Chemicals By Differential Scanning Calorimetry.pdfE537 - Standard Test Method for The Thermal Stability Of Chemicals By Differential Scanning Calorimetry.pdf
