scikust
第7楼2007/08/29
The detection limit for the UV-vis is really depend on the wavelength using and also the compound to be analyzed. for example, if the analyte is highly conjugated one, the detection limit is pretty lower than non-conjugated one.
Generally speaking, DL is about sub-ppm level
