bingdian1010
第1楼2007/09/01
还有这个怎么理解哈,不懂怎么控制!
After mixing CdCl2with thioacetamide,the solution was placed in a microwave refluxing(650 W).system for 10 min with power 20%(About 20%:it means that if microwave works in a 30-s regime, it works 6s, and does not work 24s. This is some kind of pulse regime, but the total power is still 100%).
这个反应就是100度啊,看他怎么不连续加热哈,搞不明白了!请指教哈
