【求助】几个钢铁类单词的准确翻译
  • 南郭先生
    2007/09/25
专业英语
  • 在标准中常见到几个单词bar,rod,ingot,billet,bloom,forging,plate,sheet怎么准确翻译它们?
  • 何当奇
    第1楼2007/09/25
    什么标准,能放上来吗
  • poorlittle
    第2楼2007/09/26
    Since the heading is 钢铁类单词, I suggest the following translations:
    bar : (钢)条 (generally with rectangular cross section)
    rod : (钢)枝/棒 (generally with circular cross section)
    plate : (钢)板
    sheet : (钢)片 (薄钢板)
    But different standards will have different translations; for example, reinforcing bar (i.e. rebar) in concrete engineering is called 钢筋.
    I have no idea on the other terms.
  • 南郭先生
    第3楼2007/09/27
    ASTM 钢铁类标准中都会经常出现这类词,举个例E381中有很多。
    E381
    redanqi 发表:什么标准,能放上来吗
  • poorlittle
    第4楼2007/09/27
    The following is extracted from the Chinese version of Table of Content for ASTM:
    ASTM E 381-2001 Standard Method of Macroetch Testing Steel Bars, Billets, Blooms, and
    Forgings
    ASTM E 381-1998 由棒材、坯段、大方坯和锻件组成的钢制品的宏观浸蚀试验、检验及评定
    "Bar" here is translated as 棒材, which is better than what I suggested in 2/F (钢条).
  • poorlittle
    第5楼2007/09/27
    Please upload the ASTM which contains the word “ingot” in its title.
  • czq8
    第6楼2007/10/06
    plate 钢板
    sheet 钢薄板
    这两个可以确定,钢铁是最常见的工业品,应该是有术语的。
    xcy721626 发表:在标准中常见到几个单词bar,rod,ingot,billet,bloom,forging,plate,sheet怎么准确翻译它们?
