资料下载Carbon nanotubes have mechanical properties that are far in excess of conventional fibrous materials used in engineering polymer composites. Effective reinforcement of polymers using carbon nanotubes is difficult due to poor dispersion and alignment of the nanotubes along the same axis as the applied force during composite loading. This paper reviews the mechanical properties of carbon nanotubes and their polymer composites to highlight how many previously prepared composites do not effectively use the excellent mechanical behaviour of the reinforcement. Nanomechanical tests using atomic force microscopy are carried out on simple uniaxially aligned carbon nanotube-reinforced polyvinyl alcohol (PVA) fibres prepared using electrospinning processes. Dispersion of the carbon nanotubes within the polymer is achieved using a surfactant. Young’s modulus of these simple composites is shown to approach theoretically predicted values, indicating that the carbon nanotubes are effective reinforcements. However, the use of dispersant is also shown to lower Young’s modulus of the electrospun PVA fibres.
MVI Vista-IR 纳米红外成像与光谱
简介:傅立叶变化红外光谱(Fourier Transform infrared spectroscopy, FTIR)广泛应用于各种化学分析,尤其是聚合物和有机化合物分析,为现代化学提供了重要的分析手段。然而常规的傅立叶红外光谱仪由于受到光学衍射极限的限制,其空间分辨率也越来越无法满足科研人员在纳米尺度下对于样品化学分析及成分鉴定。在这一背景下,美国Molecular Vista应运而生,推出了全新一代纳米红外成像与光谱系统Vista-IR!
MVI原子力显微镜与可见-红外-拉曼联用系统
简介:原子力显微镜(Atomic Force Microscope, AFM)经过30多年的发展后,从形貌测试及其它常规功能来看已经非常成熟。然而常规的原子力显微镜也越来越无法满足科研人员在纳米尺度下对于样品进行多性质原位测试分析的更高需求,尤其在化学、光学、电学、热学、力学等领域。在这一背景下,美国Molecular Vista应运而生,推出了全新一代原子力显微镜VistaScope!在具备所有常规原子力显微镜功能的条件下,基于专利的光诱导力显微镜(Photo-induced Force Microscope, PiFM)技术,结合波长可调的可见-红外光源,从而实现10nm以下空间分辨可见~红外成像与光谱采集,无需远场光学接收器及光谱仪。此外,VistaScope原子力显微镜还可以与各类拉曼光谱仪进行联用,组成目前市场上功能最为强大的原子力显微镜与可见-红外-拉曼联用系统,以满足科研人员在纳米尺度下的各种测试需求。
FemtoTools部分产品资料
简介:Femto Tools是瑞士一家专门生产微纳测量和加工仪器的公司,主要的产品有压力传感器探针、纳米移动平台和定位系统、数据采集和控制系统等。产品主要应用于生物与生物工程、材料科学、MEMS 表征、微型机器手臂、纳米技术等。
FemtoTools产品相关介绍
简介: Femto Tools是瑞士一家专门生产微纳测量和加工仪器的公司,主要的产品有压力传感器探针、纳米移动平台和定位系统、数据采集和控制系统等。产品主要应用于生物与生物工程、材料科学、MEMS 表征、微型机器手臂、纳米技术等。
50nm氮化硅薄膜窗口实现原子分辨
简介:Silicon nitride membranes can be used for windows of environmental chambers for in situ electron microscopy.WereportthataberrationcorrectedscanningtransmissionelectronmicroscopySTEM achieved atomic resolution on gold nanoparticles placed on both sides of a 50-nm-thick siliconnitride membrane at 200 keV electron beam energy. Spatial frequencies of 1/1.2 A were visible for a beam semi-angle of 26.5 mrad. Imaging though a 100-nm-thick membrane was also tested. The achieved imaging contrast was evaluated using Monte Carlo simulations of the STEM imaging of a sample of with a representative geometry and composition.
Zeta三维光学轮廓仪
Denton(丹顿)PE-CVD
LUMINA光学表面缺陷分析仪
Norcada电镜原位偏压加热系统
Elionix离子束刻蚀系统
Elionix电子束曝光系统
KLA高温原位纳米压痕仪I nSEM HT
NenoVision原位原子力显微镜LiteScope
filmetrics 台式膜厚测试仪 F20
KLA-Tencor先进的探针式台阶仪
Agilent UTM T150纳米拉伸试验机
KLA Gemini压痕力学测试系统
KLA纳米压痕原位力学测试模块NanoFlip
