Transmission Kikuchi diffraction (TKD) is a relatively recent development in EBSD that allows high resolution analysis of electron
transparent samples. Most applications in the literature have used TKD for targeted measurements of relatively small areas, on
samples where conventional EBSD struggles to deliver the required resolution [1]. These samples are typically nanocrystalline
metals and alloys, although increasingly the technique is also being used to characterise highly
方案
纳米晶金属和合金中表征检测方案(EBSD系统)
