Journal of Separation Science 2011,34,1811-1819 Ec A = actinamine (impurity A); G = tetrahydroxyspectinomycin (impurity G); D = dihydroxyspectinomycin (impurity D); B = actinospectinoic acid (impurity B); S = spectinomycin; F = triol spectinomycin (impurity F); R=(4R)-dihydrospectinomycin; U = unknown impurity; C = (4 S)-dihydrospectinomycin (impurity C). Column:TSKgel ODS-100V (I.D.4.6 mm×250 mm,5um) Eluent: 5 mmol/L ammonium acetate (with TFA to adjust the pHto3) -ACN (98:2) Flow rate: 0.6mL/min Column Tem.: room temperature Detector: ELSD Detector parameter:gas flow rate:3.5 L/min; Evaporation temperature: 50℃ Sample: spectinomycin,concentration: 6 mg/ml Injection vol.: 20 uL
关闭产品配置单
东曹(上海)生物科技有限公司为您提供《盐酸大观霉素中杂质检测方案(液相色谱柱)》,该方案主要用于化药制剂中限度检查检测,参考标准《暂无》,《盐酸大观霉素中杂质检测方案(液相色谱柱)》用到的仪器有null。
