化妆品原料中的生育三烯酚Tocotrienol発行日:2014年2月発行人:株式会社資生堂7p//7仁)X事業部 生育三烯酚也叫“超级维生素E”, 其抗氧化性是维生素E的数十倍,被加入到许多保健品当中。使用 CAPCELL CORE C18 S2.7(2.1 mm i.d. x150mm)色谱柱,在配有双重结构参比电极,无水流动相下也可稳定使用的电化学检测器(3005,资生堂)上,对含有生育三烯酚的化妆品原料进行了分析。 Tocotrienol, also called“Super Vitamin E”, is known to show an anti-oxidization effectdozens of times stronger that of vitamin E, and is formulated into many food supplements.One of the tocotrienol-containing low materials (oil) for cosmetic products was analyzed withCAPCELL CORE C18 S2.7 (2.1 mm i.d. x 150 mm), using 3005 Electrochemical detector(Shiseido, Tokyo, Japan), a detector equipped with a double-layered reference electrodecompatible to non-aqueous mobile phases. Column : CAPCELL CORE C18 S2.7;2.1 mm i.d. x150 mmMobile phase : 50 mmol/L NaCIO4, CH3OH/CH3CN=80/20Flow rate : 200 uL/minTemperature :40CDetection : ECD 650 mVInj. vol. :1 pLSample dissolved in :5 mg of the low material was dissolved 50 mL of 2-pronanol.※ 1ug/mL=1 ppm
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《化妆品原料中生育三烯酚检测方案 》,该方案主要用于美容/修饰类化妆品中生育三烯酚检测,参考标准《暂无》,《化妆品原料中生育三烯酚检测方案 》用到的仪器有null。
