挥发性脂肪酸和酚类在BP-FFAP上的分离与检测 min Column: NanoChrom BP-FFAP Dimension: 30mx0.53mmx0.5um Carrier: H2, Head Pressure: 4psi Inlet: Split, 240 ℃,split flow 50ml/min Oven: 80℃ (hold 1min) to 120℃at 6 °C/min to 205 ℃(hold 2min) at6℃/minInject volume: 1ul Detector: FID 260℃ Peak Compound Elution Time 1 Acetic acid (乙酸) 4.350 2 Acetic acid (丙酸) 5.064 3 Isobutyric acid (异丁酸) 5.299 4 Butyric acid (丁酸) 5.938 5 Isovaleric acid (异戊酸) 6.373 6 Isovaleric acid (戊酸) 7.199 Peak CompoundElution Time1Acetic acid(乙酸)4.3502Acetic acid(丙酸)5.0643Isobutyric acid(异丁酸)5.2994Butyric acid(丁酸)5.9385Isovaleric acid(异戊酸)6.3736Isovaleric acid(戊酸)7.199
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《脂肪酸中酚类检测方案 》,该方案主要用于其他中理化分析检测,参考标准《暂无》,《脂肪酸中酚类检测方案 》用到的仪器有纳谱分析 NanoChrom BP-FFAP 强极性毛细管柱。
