【资料】UV650的相关资料
紫外可见分光光度计(UV)
  • Technical Library for LAMBDA 950/850/650 分光光度计资料
    Applications and Use of Integrating Spheres With the LAMBDA 650 and 850 UV/Vis and LAMBDA 950 UV/Vis/NIR Spectrophotometers
    The General Purpose Optical Bench (GPOB) for the LAMBDA 650 and 850 UV/Vis Spectrophotometers and LAMBDA 950 UV/Vis/NIR Spectrophotometer
    Polarizer/Depolarizer Options for the LAMBDA 650 and 850 UV/Vis Spectrophotometers and LAMBDA 950 UV/Vis/NIR Spectrophotometer
    Acquisition of High Quality Transmission Spectra of Ultra-Small Samples Using the LAMBDA 950 UV/Vis/NIR and LAMBDA 850 UV/Vis Spectrophotometers
    Design Considerations for a Variable Angle Absolute Reflectance Accessory For the LAMBDA 950/850/650 UV/Vis/NIR and UV/Vis Spectrophotometers
    UV650的相关资料
  • 初学者&九点虎
    第1楼2007/11/15
    怎么全是英文的,俺英语不好
