【求助】求助标准MIL-S-81824, AMS-DTL-23053, GJB2647
国外标准
  • 求助标准:
    MIL-S-81824“耐环境永久压接型电绝缘的铜拼接件”
    AMS-DTL-23053 热缩电绝缘套管通用规则
    GJB2647
    万分感谢!!!!
  • cqdate
    第2楼2007/11/20
    SAE-AMS-DTL-23053 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, GENERAL SPECIFICATION FOR
    SAE-AMS-DTL-23053/1 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, CROSSLINKED CHLORINATED POLYOLEFIN, FLEXIBLE
    SAE-AMS-I-23053/2 Active 5970 Insulation Sleeving, Electrical, Heat Shrinkable, Polyvinyl Chloride, Flexible Crosslinked and Non-Crosslinked
    SAE-AMS-I-23053/3 Active 5970 Insulation Sleeving, Electrical, Heat Shrinkable, Polyvinyl Chloride, Semi Rigid, Crosslinked and Non-Crosslinked
    SAE-AMS-DTL-23053/4 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, DUAL-WALL, OUTER WALL CROSSLINKED
    SAE-AMS-DTL-23053/5 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, FLEXIBLE, CROSSLINKED
    SAE-AMS-DTL-23053/6 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, SEMI-RIGID, CROSSLINKED
    SAE-AMS-DTL-23053/7 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, TEREPHTHALATE, NON-CROSSLINKED
    SAE-AMS-DTL-23053/8 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYVINYLIDENE FLUORIDE, SIMI-RIGID, CROSSLINKED
    SAE-AMS-DTL-23053/10 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, SILICONE RUBBER, FLEXIBLE
    SAE-AMS-DTL-23053/11 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, FLUORINATED ETHYLENE PROPYLENE, NON-CROSSLINKED
    SAE-AMS-DTL-23053/12 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYTETRAFLUOROETHYLENE
    SAE-AMS-DTL-23053/13 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINABLE, FLUOROELASTOMER, FLEXIBLE
    SAE-AMS-DTL-23053/14 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, ETHYLENE-TETRAFLUOROETHYLENE FLUOROPOLYMER, SEMI-RIGID
    SAE-AMS-DTL-23053/15 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, HEAVY-WALL, COATED, FLEXIBLE, OUTER WALL CROSSLINKED
    SAE-AMS-DTL-23053/16 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, CROSSLINKED, ELASTOMERIC POLYOLEFIN, FLEXIBLE
    SAE-AMS-DTL-23053/17 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, FLAME RETARDED, MODIFIED POLYOLEFIN, FLEXIBLE, CROSSLINKED
    SAE-AMS-DTL-23053/18 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, MODIFIED FLUOROPOLYMER, CROSSLINKED
    不知道有没有用先发六个,如果求助者感觉有用的话在CALL我,嘿嘿!
    [~70456~]
    [~70457~]
    [~70458~]
    [~70459~]
    [~70460~]
    [~70461~]
    [~70463~]
    hh2222 发表:求助标准:
    GJB2647
    万分感谢!!!!
  • james2058
    第4楼2007/11/21
    不知道有没有 DTL 关于同轴负载的标准?
  • cqdate
    第5楼2007/11/21
    自己找到标准号,去求助我兴许会帮上你的忙
    james2058 发表:不知道有没有 DTL 关于同轴负载的标准?
  • hh2222
    第6楼2007/11/21
    请问:
    GJB2647
    HB6676
    这两个标准可否找到?
    多谢!!!!!!!!!!
  • lilyonmoon
    第7楼2008/11/03
    楼主,我急需ASM-DTL-23053的相关标准,请您帮帮忙,给我我传一份吧,我的邮箱lldeemail@163.com
